Just got and installed my NSV Lightbar
Discussion in 'Lighting' started by FlipMonkey21, Aug 3, 2021.
  1. Aug 3, 2021 at 2:33 PM
    FlipMonkey21
    FlipMonkey21 [OP] New Member
    Mark
    SoCal Glendale
    2019 Toyota Tundra 4X4 Sport
    2019 Toyota Tundra Crewman TRD Sport Kings 2.5 Front & Rear suspension Camburg UCA Method Wheels MR312 18X9 +18 Offset 5x150 matte black w/toyo open country RT 35x12.5R18 tires Toyo Open Country RT 35X12.50 R18LT 123Q 10 P.R TRD Front Sway Bar (Removed) TRD Rear Sway Bar ( Removed) Carven Cat-Back Kit (torque 65lbs to 70lbs of torque) Windows tint Bakflip MX4 Bed Cover TRD CAI NSV air compressor AJT Design chrome delete NSV Light Bar Diode Dynamics 42" light bar Diode Dynamics SS3 Max Pod CBI Full Skid Plate CBI Lower Control Arm Shield Sibi Built regear Revolution 5.29 Harrop rear lockers Rigd mega swing Wheel lock Deaver springs U-748 King 3x16 650 Coil springs
    What's up All, I know this might have been ask before or posted but can't seem to find any related topic for troubleshooting the NSV lightbar with this issue.
    Just installed the NSV light bar with the 3 in 1 switch the lightbar works swipe is working, DLR is working, and the full light when highbeam is on is working. My issue is my left turn signal is hyperflashing/flickering the front signal light is not working but the back signal light is.
    Also notice that when lights are on Auto when I do the highbeam the lightbar does not turn on it only turns on when the lights are not on auto mode.
    Anybody with a 2019 Tundra installed this nsv lightbar? Did you run into this issue were the signal light is hyperflashing? Also is that normal the full light will not work when you have it on Auto?
    Thank you
  2. Aug 3, 2021 at 3:25 PM
    I would review the install video on HR's site and double check the connections. How long did it take you to receive the bar and the switch once you ordered them?
  3. Aug 3, 2021 at 3:29 PM
    FlipMonkey21
    Mark
    SoCal Glendale
    trust me I doubled checked my work multiple times. I think I have an idea what is wrong I will try it and update this later.
    I paid an extra $70.00 for 3 to 6 day shipping so I got it in less than a week
    they have options on how quick you want the delivery
  4. Aug 3, 2021 at 3:31 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I just checked the install guide - you may want to double check to make sure you connected the pins properly.
    Black Wolf and Tundra234 like this.
  5. Aug 3, 2021 at 4:34 PM
    GREENwithENVY
    GREENwithENVY New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Following.
    Anyway to reengineer the harnesses for the light bar to come on with dim lights? I very rarely use high beams...
    Also, I remember reading here in the forum the strobe function still worked if one of the harness pins was moved.
  6. Aug 3, 2021 at 4:40 PM
    You can't have it on while driving on public streets.
    chugs likes this.
  7. Aug 3, 2021 at 4:46 PM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Assume your comment refers to the full light bar on with low beams?
  8. Aug 3, 2021 at 6:04 PM
    Yes. I should have clarified that. :D
  9. Aug 3, 2021 at 6:16 PM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    On my 18, you can only trigger the light bar when high beams are on and not in Auto. Did you cut the blue wire? I think it goes to the turn signal.
  10. Aug 3, 2021 at 6:17 PM
    How is the light output with the lift?
  11. Aug 3, 2021 at 6:21 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Been there, done that. Lol, you can blame Toyota's crappy halogen bulbs for my light bar being on.
    Tundra234[QUOTED] likes this.
  12. Aug 3, 2021 at 6:21 PM
    November Sun
    Huntsville, Alabama
    Great, It really lights up the road, I did get pulled over for my DRLs and given a stern warning. lol
  13. Aug 3, 2021 at 6:23 PM
    November Sun
    Huntsville, Alabama
    Officer said my lights were too high off the ground, not that they were too bright. I'm like, huh, ok..
    Tundra234 likes this.
  14. Aug 4, 2021 at 10:03 AM
    FlipMonkey21
    Mark
    SoCal Glendale
    so I finally got the signal light hyperflashing issue taken care off now the power adjusting headlight motor is not working.
    Anyone got any idea on how to get that working again?
  15. Aug 4, 2021 at 3:40 PM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Dang...really want one of these light bars now...but don't want all the BS issues that seem to be occurring with the NSV harness.
  16. Aug 4, 2021 at 4:10 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Not to knock the NSV light bar, but the Nilight 41" fits under the hood bulge with some cutting.
    https://www.youtube.com/watch?v=xO96NngJq7w
  17. Aug 4, 2021 at 5:12 PM
    So the NSV can't be rewired to work as a standalone instead of being tied to only come on with the high beams?
  18. Aug 4, 2021 at 5:14 PM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Now you are thinking like me...
  19. Aug 4, 2021 at 5:23 PM
    I'll have to contact HR and see what they say.
  20. Aug 6, 2021 at 8:46 AM
    HR says it will only work with high beams on and there was no way around it. At least the BD S8 is an option.
    FlipMonkey21[OP] likes this.
  21. Aug 6, 2021 at 9:58 AM
    FlipMonkey21
    Mark
    SoCal Glendale
    yeah but the BD S8 doesn't do the swipe or DRL only the full light and fitment is not the same as the NSV you will need to do some cutting and even doing the cutting it is not as flush as the NSV. I got the NSV cause of the features but it would be nice if you can connect it directly to your switch. All good still happy with the NSV just need to get the headlight motor working and I'll be 100% satisfied. :)
    I actually got a hold with Jensen and he is asking around he got one guy that had the same issue.
    ElNopal likes this.
  22. Aug 6, 2021 at 10:29 AM
    I still don't know if HR is correct on the wiring. I don't want it if it will only power from high beams.
  23. Aug 6, 2021 at 10:44 AM
    FlipMonkey21
    Mark
    SoCal Glendale
  24. Aug 6, 2021 at 10:50 AM
  25. Aug 6, 2021 at 10:55 AM
    FlipMonkey21
    Mark
    SoCal Glendale
    just to let you know I did not tap or cut any factory cable the blue cable I cut is from the NSV cable so you shouldn't be tapping or cutting any wires from your Morimoto headlight.
    How do you like your Morimoto headlight?
    I'm thinking doing my headlight next eventually going with Morimoto or Alpharex.
  26. Aug 6, 2021 at 4:27 PM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
  27. Aug 6, 2021 at 4:28 PM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Agree with @FlipMonkey21 the blue wire is on the HR patch harness. I asked them too.
  28. Aug 6, 2021 at 4:30 PM
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    One of their vids said it was a safety feature...as a way to quickly turn the light bar off from the steering wheel instead of fumbling around in the dark to turn a switch off (said it was dangerous for the driver).
    I agree with you - there must be a way to direct wire it to power/ground/switch and it operate the same.
  29. Aug 7, 2021 at 9:35 AM
    FlipMonkey21
    Mark
    SoCal Glendale
    Yup cut the blue wire
  30. Sep 28, 2021 at 4:16 AM
    TundraTool13
    TundraTool13 New Member
    2020 Tundra Platinum
    Did you ever get your problem fixed? I just installed this lightbar on my 2020 and cut the blue wire and lost the function of my left turn signal. Reconnected the blue wire and got my turn signal back but now it looks like I blown my taillight fuse. I only knew to check my taillights cuz I contacted Headlight Revolution and warned me about the possiblity of the taillight fuse blowing. So I am not sure what is going on! :notsure:
