Just came back from a towing test - underwhelming!
Discussion in '1st Gen Tundras (2000-2006)' started by 1stGenOwner, Aug 30, 2025.
  1. Sep 3, 2025 at 7:17 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I did enjoy towing with my 3.4 Tacoma 5 speed. I like towing with the Tundra better, but I liked the Tacoma manual transmission, and especially the low gearing of 1st gear. But I wouldn't trade my auto 4.7 Tundra for a manual 3.4 Tundra. Same not-so-powerful V6 as the Tacoma, but in a bigger, heavier truck.
  2. Sep 3, 2025 at 7:19 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    I think my Tundra is rated at 271 horses.... but I haven't tested this to see what she is actually producing.
    So far, she's doing it all just fine. I have a little "squat" when hooked up to the 18 foot 2-axle when loaded with the two zero turns. So far, no issues with control. I don't use cruise control at all on anything that would make it downshift and even when I depress the pedal more I have to push it pretty far down to cause the tranny to shift into a lower gear.
    However, after reading this thread, I just now looked into a "weight distributing hitch." The article recommended it if the truck was squatting. However, this set up looks a bit expensive and annoying to deal with since we have to switch from the 2-axle to the 1-axle sometimes in the same day and the former is a 2 5/16" ball and the latter a 2" ball.
    I can run by the local trailer dealer and ask for some advice. Maybe tomorrow as it's supposed to rain and we won't be mowing.
    FrenchToasty likes this.
  3. Sep 3, 2025 at 7:54 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Western NC? I assume you had some pretty big hills to deal with there.
    I went to Georgia via Ashville, NC and back the same way last April. Very substantial hills around Ashville and those hills were on I-26 IIRC.
    Those hills were steep enough for me to consider returning via I-85 if I had bought that 7.3 L IDI diesel dump truck I had gone down to look at. (Didn't buy it, tranny's synchronizers where shot, something not disclosed by the seller).
    Is 3,000 rpm something of a "towing sweet spot?"
    So what upgrades would a 2006 4.7 L need to have a bit more power?
  4. Sep 3, 2025 at 8:34 PM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    Supercharger or LS swap.
  5. Sep 3, 2025 at 8:35 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    I'm not doing either of those. :rofl:
    What's an "LS swap?"
  6. Sep 3, 2025 at 8:40 PM
    Upshot Knothole
    Thatchery
    PDX OR
    Chevy LS series of engines. Common to swap them into everything.
  7. Sep 4, 2025 at 5:29 AM
    Peak torque for the 4.7 was around 3200rpm. So yeah, that’s the sweet spot for maximum engine power output.
  8. Sep 4, 2025 at 6:49 AM
    MT-Tundra
    Montana
    All our trucks in are slightly different condition, so we aren't comparing apples to apples. But for my truck, like I mentioned, there's a huge difference between just a couple miles per hour, a couple hundred rpm. Huge difference in how much it downshifts. 68-70mph, way more downshifting than 72mph. At 72mph I'm right at 3200 rpm, so that checks out. What speed your truck hits 3200 will depend on gearing and tire size. I think it's worth experimenting with if you typically tow at lower speeds, so long as you still have stability and the ability to stop and that's not way over the speed limit :)
  9. Sep 4, 2025 at 8:08 AM
    GenIII SBC. “LS” is misleading/common misnomer, LS, LM, LQ, etc. series of engines from GM. This is a former wheelhouse for me.
    Upshot Knothole likes this.
  10. Sep 4, 2025 at 8:13 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    3400 for non-vvti. 3600 for vvti (or maybe just sequoia, dont remember). Where did you find 3200? I havent seen a stock dyno in a while, so i’m just going by what articles said.
  11. Sep 4, 2025 at 8:29 AM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    At what weight payload would yall consider the threshold for consistently driving with OD off? If not weight, then what other indicator?
  12. Sep 4, 2025 at 8:34 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Wind. If youre pushing wind, drop the OD. No worries pulling 5klbs in overdrive while the road was flat, but it wasnt pushing TT wind. In the hills, i’d kill OD uphill, then coast downhill with OD on.
  13. Sep 4, 2025 at 6:20 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    I generally do 55 mph on the interstate, no matter what I am driving or towing.
    We may have one more chance to tow with the 2 axle and two mower loadout where we have to pull those big 5% grade hills. ("Southern Route").
    I will try the 3,200 RPM suggestion.
    In fact, now that we've dropped that one customer, we no longer have a need for the 2-axle on the "Northern Route," as we won't be using 2 mowers up there at the same time.
  14. Sep 4, 2025 at 10:08 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Since you're a 4wd get BOTH front diff and rear 3rd member from a 1st gen seqouia. They have OEM 4.10's and are a direct swap iirc.
    Bought2Pull[QUOTED] likes this.
  15. Sep 4, 2025 at 10:31 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Another forum member told me the same thing.
    I think about it......I don't guess it would change max towing capacity but would allow more torque to "get a load moving?" "Stronger towing pull on hills?"
  16. Sep 4, 2025 at 10:40 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Exactly. More low end off the line and through all the gears.
    Side benefit, I also get better mpg around town AND on the freeway.
  17. Sep 4, 2025 at 10:41 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    4.10 gears gives you better mpg over a 3.91?
  18. Sep 4, 2025 at 10:45 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Yep. Slightly higher rpms means the engine produces more torque with less load (throttle).
    I went from 12-13 around town to 15-16 and 16-17mpg on the freeway to 18-19mpg.
    Personal best at 60'ish mph was 20.6mpg.
    MT-Tundra likes this.
  19. Sep 4, 2025 at 10:48 PM
    #49
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    My best on interstate is 18.9 mpg but I wasn't towing and holding it at 55 mph.
    I may have to add this "upgrade" to my "list of planned changes." :)
    Thanks.
