Jumper cables hooked up WRONG
Discussion in 'General Tundra Discussion' started by Sircedric, Jul 19, 2019.
  1. Jul 19, 2019 at 6:40 PM
    Sircedric
    Sircedric [OP] New Member
    Cedric
    White Tundra SR5
    None
    Jumper cables were hooked up wrong changed battery and replaced blown fuses checked all known fuses inside and under the hood I have head lights and the dash lights up no taillights, no break lights and no power seats or locks or lights or radio inside the truck any suggestions please HELP
  2. Jul 19, 2019 at 6:51 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Back in the early sixties in the dead of winter had a guy hook up jumpers the wrong way and thought I was stupid for me trying to stop him and the battery blew up in our faces!! We were in the parking lot of a hospital so a quick trip into the ER and many doctors flushing our eyes out, the guy left with bandaged eyes I left with eye lids glued shut with ointment and I was much quicker so I had turned and took some plastic in the side! Thank goodness I had a heavy coat on! Sorry to hear you had troubles but consider yourself lucky?!:) I don’t even carry cables anymore!! that way I can’t mess up their vehicle or mine. Really hope you get it figured out. What a mess.
    Black Wolf likes this.
  3. Jul 19, 2019 at 6:52 PM
    AZTundra
    Paul
    Phoenix, AZ
    Sounds like there may be more fuses to be replaced.
    Mr Badwrench likes this.
  4. Jul 19, 2019 at 6:54 PM
    AZTundra
    Paul
    Phoenix, AZ
    What year Tundra do you have?
  5. Jul 19, 2019 at 6:59 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Black@Blue19 likes this.
  6. Jul 19, 2019 at 7:00 PM
    AZTundra
    Paul
    Phoenix, AZ
    I was also thinking to check the fuseable link.
    Randy Morton likes this.
  7. Jul 19, 2019 at 7:21 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Crossing DC polarity is never good. Hopefully there is a fuse or fuses blown. Keep us posted.
    ColoradoTJ likes this.
  8. Jul 20, 2019 at 9:10 AM
    Sircedric
    Cedric
    White Tundra SR5
    None
    Thanks guys I'm pulling it out now I'll let you all know what happens
    BTBAKER and AZTundra like this.
  9. Jul 25, 2019 at 5:25 PM
    Sircedric
    Cedric
    White Tundra SR5
    None
    Thanks Guys, I got the main fuse in and all power was restored except for my AC any ideas
  10. Jul 25, 2019 at 6:38 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Is there an AC fuse?
  11. Jul 25, 2019 at 6:55 PM
    Black@Blue19
    Ken
    SE Texas
    WOW!!! Good job!!
  12. Jul 25, 2019 at 6:58 PM
    Sircedric
    Cedric
    White Tundra SR5
    None
    Yea, I've checked the fuses
  13. Jul 25, 2019 at 6:58 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    X2^^
  14. Jul 25, 2019 at 7:00 PM
    AC relay??
    Sircedric[OP] likes this.
  15. Jul 25, 2019 at 7:04 PM
    Sircedric
    Cedric
    White Tundra SR5
    None
    Changed it out today the compressor is not locked up it spins freely but it doesn't come on rear defroster on the control as well as the AC nothing
  16. Aug 1, 2019 at 7:17 PM
    Sircedric
    Cedric
    White Tundra SR5
    None
    Well cant seem to figure out why the AC control aren't working checked all fuses still nothing checked compressor it has power no power other than the light son the dials
  17. Aug 1, 2019 at 7:26 PM
    AZTundra
    Paul
    Phoenix, AZ
    That sucks. What's the next move now?....dealership?
  18. Aug 1, 2019 at 7:33 PM
    Bif
    Bif New Member
    Bif
    2014-1794 Edition
    Stock
    That sucks Sircedric. Soon as I can I am gonna order OEM books. Electrical books first. Does your alternator still work,.?
  19. Aug 1, 2019 at 7:58 PM
    Sircedric
    Cedric
    White Tundra SR5
    None
    Yes every thing works except the AC
  20. Aug 1, 2019 at 8:11 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Maybe the ac fan motor got fried or died. When mine failed the ac didn't come on at all. To trouble shoot I disconnected the harness at fan, checked DC volts with a meter. The voltage was variable in increasing increments as the fan switch was increased. If no volts then power issue.
    tinman10101 likes this.
  21. Aug 2, 2019 at 2:07 AM
    Bif
    Bif New Member
    Bif
    2014-1794 Edition
    Stock
    It would be a first in my days but coulda blowed the clutch coil or a pressure switch. Check power and ground with the a-c kicked in maybe?
  22. Aug 2, 2019 at 2:35 AM
    Check to see if the compressor clutch actually engages using a jumper wire.
    Compressor clutch relay good?
    High/Low pressure switches good?
    Evaporator temp switch?
  23. Apr 10, 2020 at 12:32 AM
    Dolanator89
    Dolanator89 New Member
    2014 Silver Sky Metallic Tundra Platinum
    So my dumb ass did this today and I'm getting a fusible link to replace mine since I have the same symptoms you did. I haven't tested ac yet though. Did you end up figuring out what was wrong with yours?
