Judge this quote from Toyota
Discussion in '1st Gen Tundras (2000-2006)' started by Squeakyduck4, Mar 4, 2024.
  1. Mar 19, 2024 at 6:35 PM
    meeseeks55
    meeseeks55 New Member
    2002 SR5 Access Cab 3.4L V6
    Everything definitely seems overpriced to me. If you have the time you can likely do these things yourself with minimal tools and supplies.
  2. Mar 19, 2024 at 6:38 PM
    meeseeks55
    I would say not unless the vehicle is still under warranty, which obviously your 2006 wouldn't be. Theres a good chance if you find a good local mechain they'll actually do a better job for a lower price. I would also consider trying to do some of these things on your own if you have the time. There really aren't any specialty tools needed. A couple supplies such as tubing, etc for the brake fluid, but other than that pretty much basic tools and some replacement gaskets.
  3. Mar 20, 2024 at 5:23 AM
    socomoby
    socomoby New Member
    2006 DC V8/2WD SR5 LSD
    Definitely hosing you on the Tranny and Power steering for sure. Toyota dealer near me did a tranny drain and fill for $149 and power steering for $89 with no coupons. And hell I complained about that.
  4. Mar 20, 2024 at 9:39 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    PS flush takes a gallon of Dexron and some tubing. Like $15 if DYI. Similar with gearbox drain/fills. Front / rear diff and transfer oil changes take about 6 qts. of oil IIRC at about $10 each and new washers torqued to spec, so like $65 in parts/fluids.
  5. Mar 20, 2024 at 9:55 AM
    socomoby
    socomoby New Member
    Oh trust me I know. I’ve been so busy that I haven’t seriously had the time. Went in for drain and fill and threw the PS in there for convenience.
    I got took but those prices OP posted, buddy they can go to hell
