JL VX700/5i
Discussion in 'Audio & Video' started by Wreckt01, Apr 12, 2018.
  1. Apr 12, 2018 at 6:50 PM
    Wreckt01
    Wreckt01 [OP] New Member
    2018 Toyota Tundra SR5/TSS Crewmax, MGM
    17” All-Terrain Antenna
    anyone know if this amp/DSP will fit under the passenger seat in a 2018 crewmax?
    Thinking of using this with some Focals to fix this awful audio
    Non JBL for what its worth
  2. Apr 12, 2018 at 7:00 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I’ve got the JL XD1000/5v2 under the passenger seat, and it is bigger than the one you’re looking at. You should have no problems
    Black Wolf and Wreckt01[OP] like this.
  3. Apr 12, 2018 at 7:01 PM
    Wreckt01
    Thanks
  4. Apr 12, 2018 at 7:33 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    It looks smaller than the hd900/5 and has plenty of room under the front seat. Make a small amp rack for it (i have pictures of mine in the link in my signature)
    I had to google it....i didn't know they made an integrated processor in an amp.
  5. Apr 12, 2018 at 7:47 PM
    Wreckt01
    It’s fairly new, I think Kenwood makes one as well, but I’ve always used JL amps and have been happy.
  6. Apr 12, 2018 at 8:04 PM
    Danimal86
    Daniel
    Sacramento, CA
    I know audiocontrol made one.
  7. Apr 14, 2018 at 6:04 PM
    Wreckt01
    Anyone know how much of a difference the DSP makes. I like my music and my audiobooks, but don’t need cometition grade clarity. Just want a natural sound.
    Saves 500 bucks to drop the DSP, but everyone talks like it’s a worth the extra cash.
    smslavin likes this.
  8. Apr 14, 2018 at 6:17 PM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    If you’re keeping the factory HU it will probably be worth it. I have an audio control LC7i for this very reason
    Wreckt01[OP] likes this.
  9. Apr 24, 2018 at 2:39 PM
    Shelbie67
    Shelbie67 New Member
    Blake
    NorCal
    2018 tundra crewmax platinum
    RADFLO 2.5 suspension, apex rock sliders, BFG KO2, exhaust delete, Full Active Stereo
    DSP makes a HUGE difference. That is a great amp and has a very small footprint.
    What's the reason for Focal's? also, which model? did you consider Hertz?
  10. Apr 24, 2018 at 3:45 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Because Focal’s are F’ing awesome..... I mean that’s why I use them. They can get expensive but worth it if you spend the money on the front channels and have the power to drive them.
  11. Apr 24, 2018 at 5:10 PM
    Wreckt01
    I’ve always liked Focals for front and JL for thump. Just preference I guess. don’t have much experience with Hertz
    Also I’m not a full fledged audio guru so I go with what I know works and my local trusted shop uses.
  12. Apr 24, 2018 at 5:26 PM
    Shelbie67
    Blake
    NorCal
    Ok, nothing wrong with focal if you go high enough in there line. I’m a Hertz guy. I was just curious.
    And I agree on JL for the thump :) excellent clean deep power
  13. May 29, 2018 at 12:22 PM
    Wreckt01
    Got the amp on a great memorial day sale. Going to wire it up, grab a pair of Focal k2s for front and rear JL C5s, build a box for a 12” and get a local audio guru to help me tune it. Have never used a DSP integrated amp so it should be an adventure.
  14. May 29, 2018 at 12:33 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i can testify to a dsp. non-jbl in my truck. i went with a FiX and a TwK. the difference is significant. the TuN software is not difficult to use. i did a little write up.
  15. May 29, 2018 at 12:36 PM
    Wreckt01
    FYI your thread is amazing. So much good info. I hope to repay the favor as I move forward.
    smslavin[QUOTED] likes this.
  16. May 29, 2018 at 12:40 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    no worries. glad it's useful. the software is super easy to use. the one thing that makes the largest difference is the time delay. definitely fill in the speaker distances. also, use the parametric eq so you can get some overlap between the frequencies.
  17. May 29, 2018 at 12:43 PM
    Wreckt01
    My plan is to spend 2 weeks tweaking it, and then get the local expert to fix what I screwed up haha.
    Also I want to keep the center dash if possible, but it will have be be fed from the HU so I’m not sure it’ll work.
    I’ll use the tweeters from the k2 in the corners and maybe a JL C3 in the middle. Just need to figure out how to integrate the HU fed center with the Amp fed speakers....the time delay and source differential should prove an interesting dilemma.
  18. May 29, 2018 at 12:53 PM
    Danimal86
    Daniel
    Sacramento, CA
    You would have to figure out how to disconnect the signal going to the center in the dash and power it by your amp.
    If you leave it powered by the head unit, you will have a difference in volumes from the door speakers to the center. It makes your music sound terrible. Trust me...just ditch them.
  19. May 29, 2018 at 12:55 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    i disconnected all 3 dash speakers. i can't tell that they aren't there. i would just pull them out.
  20. May 29, 2018 at 12:58 PM
    Wreckt01
    I figured. I bet the ability to reset/image the source to center will outweigh actually using the center speaker. I’m an EE and a complete nerd, so I’ll tweak until I make it unusable and then get an expert to fix it....occupational hazard. FML haha
  21. May 29, 2018 at 1:00 PM
    Wreckt01
    Us lowly mortals can’t outsmart the almighty techno-jehovas. But dammit I’m gonna try.
  22. May 29, 2018 at 1:32 PM
    Beerdude77
    Beerdude77 New Member
    2018 Silver Sky Tundra Limited TRD CM
    Linex bed, "Toyota" Console Safe
    Do you measure from your head in your normal driving position to the speakers?
  23. May 29, 2018 at 1:36 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    you could. i went from the center of the center console cover at about shoulder height.
  24. Jun 4, 2018 at 6:56 AM
    Wreckt01
    1UPPER likes this.
  25. Jun 11, 2018 at 1:40 PM
    chefhow
    chefhow New Member
    Howard
    McKinney Tx
    08 CrewMax
    TRD Supercharger
    Where are you located? I may know someone in your area that can set up the DSP portion of the amp quickly for you.
  26. Jun 12, 2018 at 7:48 AM
    Wreckt01
    North Dallas
  27. Jun 12, 2018 at 7:54 AM
    chefhow
    chefhow New Member
    Howard
    McKinney Tx
    08 CrewMax
    TRD Supercharger
    Call SoundScape in Carrollton, I am pretty sure they are a JL dealer and the Owner Dan is pretty good at tuning SQ cars.
    If not Tony at Sound Creations in Durant is a dealer and can help you out.
  28. Jun 12, 2018 at 8:09 AM
    Wreckt01
    Thanks, was also considering Earmark in Plano, but will check out soundscape.
  29. Jun 12, 2018 at 8:32 AM
    chefhow
    chefhow New Member
    Howard
    McKinney Tx
    08 CrewMax
    TRD Supercharger
    I'm a fan of Dan and what he does at Soundscape.
    Stop by, give a call and set up a time to check it out. They do amazing work.
  30. Jun 18, 2018 at 3:35 PM
    Wreckt01
    Met with Dan, dude knows his stuff. Learned a lot and have a whole new set of options I hadn’t considered with equipment, staging etc. they don’t rep JL but he said he has no issues tuning it as he has done it many times.
    chefhow[QUOTED] likes this.
