JL 10-TW3, Audiofrog,Kenwood DMX1037s Build
Discussion in 'Audio & Video' started by Desolate, Feb 17, 2021.
  1. Mar 21, 2021 at 7:05 PM
    #61
    Randoo254
    Randoo254 Addicted to Upgrades
    Randy
    2020 TSS 4x4 SR5
    3 in leveling Kit
    I did when I first installed it It ended up being the gain on the amp going to my mids. I turned it down and completely gone.
    619Tundra likes this.
  2. Mar 21, 2021 at 7:06 PM
    #62
    Randoo254
    Randy
    2020 TSS 4x4 SR5
    3 in leveling Kit
    Dumb. I hate iPhones
  3. Mar 21, 2021 at 7:08 PM
    #63
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    So can anyone tell me which TW1s I should go with? 2 ohms or 4 ohms?
  4. Mar 21, 2021 at 7:16 PM
    #64
    Randoo254
    Randy
    2020 TSS 4x4 SR5
    3 in leveling Kit
    Are they the shallow mounted tw1?
  5. Mar 21, 2021 at 7:32 PM
    #65
    Yes shallow mount TW1s with a JL 900/5 amp.
  6. Mar 21, 2021 at 7:33 PM
    #66
    Rica25
    Ricardo
    Tulare
    Let me guess are you correctional officer up the in High Dessert?
  7. Mar 21, 2021 at 7:42 PM
    #67
    No
    Rica25[QUOTED] likes this.
  8. Mar 21, 2021 at 7:57 PM
    #68
    Rica25
    Ricardo
    Tulare
    Lots of CO'S there. Sorry for asking. I was in that for a few years but got out of it.
  9. Mar 22, 2021 at 1:19 AM
    #69
    Twinky
    07 double cab work horse
    Hd 900/5 or the JD 900/5? The HD is 1.5ohms stable and the JD is 2om stable on the sub channel.
    And Single voice coil subs right?
    If you are going with the HD then id check with JL about running the 2 2ohm subs wired parallel for a 1ohm load at the amp. Its kinda odd that its lowest impedance is 1.5ohms. Im not sure what combination of voice coils and subs you can wire up for that impedance.
    Well heres a diagram though for 2 svc 2ohm subs wired for a 1ohm load.
    Edit: if you are using the JD then 2 4ohm subs wired in parallel will be 2ohms at the amp. Just wire it the same as above.
  10. Mar 22, 2021 at 2:10 AM
    #70
    The JL amp I have has 2 positive and 2 negative ports or terminals for sub woofers. So if I were to run each sub on it's on independent positive and negative wire to the amp I should be able to run two 2 ohms subs and it be 2 ohms final value and the amp correct?
  11. Mar 22, 2021 at 2:10 AM
    #71
    Twinky
    Did you find the problem yet?
    If not, have you checked to see if the noise is still present while the engine is not running?
    Have you done the big 3 upgrade yet?
    Have you tried running the headunits ground to another ground that your system is already connected too? Like the ground your amp is using?
  12. Mar 22, 2021 at 2:24 AM
    #72
    Havent fixed the issue yet. Static is present even with the engine off. I have grounded it to another location on the truck and it did not help. Which big 3 are you talking about?
  13. Mar 22, 2021 at 2:31 AM
    #73
    Twinky
    Im pretty sure the sub channel will be mono outputs. That means they are internally parallel outputs.
    Basically if you have 2 subs that are 2ohm single voice coils with each one wired to it on set of + and - outputs, it will equal a 1ohm load. Its the same thing in the above diagram but in a much simpler way.
    2 subs, 4ohm single voice coils, wired to its own + and - will be a 2 ohm final load. Im pretty confident the TW1 4ohm subs are the correct subs for your amp.
  14. Mar 22, 2021 at 2:38 AM
    #74
    That makes sense. I will get the 4 ohms subs.
  15. Mar 22, 2021 at 2:40 AM
    #75
    Twinky
    The big 3 is when you run a new ground from your battery to the chassis. Then another ground from the chassis to the block. Then a positive from the battery to the alternator.
    The factory grounds that are used in the majority of vehicles are typically just suitable enough for the vehicle while stock. With an aftermarket system this upgrade can make a very noticeable improvement in keeping your voltage up and it helps to stop headlights from dimming as such.
  16. Mar 22, 2021 at 2:44 AM
    #76
    I'll look into upgrading those, thanks.
  17. Mar 22, 2021 at 5:49 AM
    #77
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Post a picture of the grounded wire you installed. It should be a short run from the unit.
  18. Mar 22, 2021 at 5:54 AM
    #78
    I only ran a wire from the engine bay grounding point to the HU to test it. It's back on the factory head unit ground (black wire)
  19. Mar 22, 2021 at 6:00 AM
    #79
    619Tundra
    The shorter the better. Find a spot near the unit.
