JL 10-TW3, Audiofrog,Kenwood DMX1037s Build
Discussion in 'Audio & Video' started by Desolate, Feb 17, 2021.
  1. Mar 21, 2021 at 11:57 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I meant just in general, i wouldn't run the dash speakers off the head unit.
    Check the ground on your head unit. I have no hiss on mine.
    Rica25 likes this.
  2. Mar 21, 2021 at 12:00 PM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    ground is connected to the maestro ground (black wire) connections is good, I am not sure what the issue is.
    Rica25 likes this.
  3. Mar 21, 2021 at 12:07 PM
    Danimal86
    Daniel
    Sacramento, CA
    Make sure on the head unit EQ everything is set to 0 (no gain adjustments).
    After that, you are just going to have to pull the head unit and start eliminating things.
    I'm wondering if its having to do with running speaker outputs and rca outputs at the same time.
    Rica25 likes this.
  4. Mar 21, 2021 at 12:16 PM
    Danimal86
    Daniel
    Sacramento, CA
    Also, list all the parts in your setup.
    Rica25 likes this.
  5. Mar 21, 2021 at 1:05 PM
    Kenwood 1037S with the Maestro RR. I do have door hertz door speakers all around and a JBL RD900 amp but I have elimanated those by disconnecting the amp. The problem has something to do with the head unit or Maestro (which I programmed again to verify). I double checked the wiring harness and everything is connected properly on the head unit to the Maestro harness. I am still getting static from the dash speakers.
    Rica25 likes this.
  6. Mar 21, 2021 at 1:38 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Why are you using the black ground wire from the RR as a ground for your stereo? Run a separate ground wire. Also make sure you're not running a ground loop.
    Rica25 likes this.
  7. Mar 21, 2021 at 2:07 PM
    That's what the instructions say to do on the Maestro website. The black wire is the ground for the factory head unit so why would it not be sufficient for an aftermarket?
    Rica25 likes this.
  8. Mar 21, 2021 at 2:11 PM
    619Tundra
    Because it might produce distortion or interference to your audio signal.
    Rica25 likes this.
  9. Mar 21, 2021 at 2:49 PM
    619Tundra
    Why not ground it somewhere else? Your whole truck is made out of metal.
    Rica25 likes this.
  10. Mar 21, 2021 at 2:49 PM
    Just tested that theory by running a wire directly to the negative on the battery to the head unit. No change.
    Rica25 likes this.
  11. Mar 21, 2021 at 2:51 PM
    619Tundra
    Dont do that, you're creating a grounding loop.
    Rica25 likes this.
  12. Mar 21, 2021 at 2:58 PM
    Not exactly on the terminal but the side of the truck where the battery is grounded is where I put it.
    Rica25 likes this.
  13. Mar 21, 2021 at 3:04 PM
    Danimal86
    Daniel
    Sacramento, CA
    And this static is the same across all inputs on your head unit.
    Rica25 likes this.
  14. Mar 21, 2021 at 3:05 PM
    619Tundra
    Here's comments made on a Audiofrog post about 4 days ago about this.
    PNWTundra2021 and Rica25 like this.
  15. Mar 21, 2021 at 3:06 PM
    Yes all inputs. Apparently this is a known issue with the 1037S as I asked another person who has it and he said the same thing.
    Rica25 likes this.
  16. Mar 21, 2021 at 3:16 PM
    Danimal86
    Daniel
    Sacramento, CA
    I have a 1037s, no static.
    Have you done a factory reset of the head unit?
    Rica25 likes this.
  17. Mar 21, 2021 at 3:21 PM
    It's very faint. Have you put your ear to one of your tweeters?
    Rica25 likes this.
  18. Mar 21, 2021 at 3:28 PM
    619Tundra
    I never understood why people would buy the 1037 when the 1057XR has the same price and has Audiophile grade components and a 2 year warranty.
    Rica25 likes this.
  19. Mar 21, 2021 at 3:35 PM
    #49
    Danimal86
    Daniel
    Sacramento, CA
    You got a killer deal on that 1057. Msrp to msrp i didn't think it was worth the extra money for an extra volt of preout, and built in navi when i was going to use andriod auto 100% of the time.....ymmv
    Rica25 likes this.
  20. Mar 21, 2021 at 6:07 PM
    #50
    619Tundra
    MSRP on 1037S $1099, MSRP on 1057XR $1099.
  21. Mar 21, 2021 at 6:27 PM
    #51
    I have the JL Audio RD 900/5 amp. I am still learning the logic of ohms and RMS. I am torn between getting two JL Audio TW1-2 10" or TW1-4 10" subs but I am not sure which ones will work best with the amp. Any help?
  22. Mar 21, 2021 at 6:43 PM
    #52
    619Tundra
    How about (2) 10TW3s?
    Rica25 likes this.
  23. Mar 21, 2021 at 6:44 PM
    #53
    I wish. I can't find anyone selling them.
    Rica25 likes this.
  24. Mar 21, 2021 at 6:53 PM
    #54
    619Tundra
    Where do you live ?
    Rica25 likes this.
  25. Mar 21, 2021 at 6:56 PM
    #55
    Does Crutchfield have them maybe?
    Rica25 likes this.
  26. Mar 21, 2021 at 6:57 PM
    #56
    California high desert. All sold out online that's why I'm looking at TW1s.
    Rica25 likes this.
  27. Mar 21, 2021 at 6:58 PM
    #57
    Randoo254
    Randoo254 Addicted to Upgrades
    Randy
    2020 TSS 4x4 SR5
    3 in leveling Kit
    Sounds like several people have the 1037 head unit. Anyone have an iPhone and is able to screen mirror? I ran the hdmi but it still won’t mirror.
  28. Mar 21, 2021 at 7:00 PM
    #58
    Can't help you there. Do you by chance have static noise in your speakers?
    Rica25 likes this.
  29. Mar 21, 2021 at 7:04 PM
    #59
    Danimal86
    Daniel
    Sacramento, CA
    Ohhhhh.....I thought you were talking about the the excelon one with built in navi....
    Yeah, so the 1057 was a screw up on kenwoods part since they were the same price as the 1037. The 1057 is out of stock everywhere and from what I heard they arent going to be making any more.
    Rica25 likes this.
  30. Mar 21, 2021 at 7:04 PM
    #60
    Danimal86
    Daniel
    Sacramento, CA
    Only galaxy phones can mirror
