Jittery fog lamps
Discussion in '2.5 Gen Tundras (2014-2021)' started by rocsteady, Aug 5, 2022.
  1. Aug 5, 2022 at 9:26 AM
    rocsteady
    rocsteady [OP] New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    Any solid solutions to immobilizing that "box" that the fog lamps attach to that then fits into a stock front bumper? After installing the new fog lights and driving with them on last night, I noticed how shaky the beam got over any sort of tiny bump in the road. Can't possibly be good for the lamp's innards.
    When installing, I could see how the new lamp assembly fit nice and tight into this "housing" for lack of a better word, with the two "tines" on the one side and screw on the other but the piece that they attach to is anything but tight in its attachment to the bumper.
    Best to just shim them with something, black foam maybe, just to push the housing tight one way or the other (up or down seems to be the most movement) against the bumper itself?
    I don't have a closeup at the moment but if you push the housing up or down there's a good bit of space that allows the movement of the whole thing.
    This piece, that the fog lamp attaches to, is the thing that's just not snug in its fit to the bumper:
    EHkM56oR_hO8t-pvpylLdaGFEmE1Yi4yIy-_XdpP_f2058d42c489027fb78f4c990aeca6f5c9cbae29.jpg
  2. Aug 5, 2022 at 9:41 AM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
  3. Aug 5, 2022 at 9:44 AM
    Taco-Spike
    Two Trucks
    junior[QUOTED] likes this.
  4. Aug 5, 2022 at 9:51 AM
    rocsteady
    Dave
    New Jersey
    Thank you very much. That is exactly what I needed. Certainly not something one should have to to but I see how it could work really well. Much appreciated.
  5. Aug 5, 2022 at 11:07 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Same, I removed from the truck and put zip ties to snug up all the play. worked great.
    Oey12 and HulkSmurf14 like this.
  6. Aug 5, 2022 at 11:34 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    X2 on the zip ties…
    Simple yet highly effective.
  7. Aug 5, 2022 at 11:45 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    x3!!!
    Oey12[QUOTED] likes this.
  8. Aug 5, 2022 at 2:19 PM
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    Zip ties ftw!
  9. Aug 5, 2022 at 6:40 PM
    rocsteady
    Dave
    New Jersey
    Yep, me too. Did it tonight. 100% better
