Do your fog lights jiggle? Try this.
Discussion in 'Lighting' started by Hoologan, Mar 17, 2018.
  1. Mar 17, 2018 at 8:15 PM
    Hoologan
    Hoologan [OP] New Member
    California
    18 Cement Limited Crewmax TRD
    Ever since swapping over to painted bumper ends my fog lights have jiggled over bumps. I had a look today and simply added a couple zips ties and they’re rigid now.
    One goes through the little loop on the bezel and the other one goes around the fog light screw. Both tie back to the bumper mount.
    It isn’t pretty but can’t be seen so whatever.
    4B7D5815-4453-4164-A0FC-AA3D7BD2C8A1.jpg 69690089-BEA0-4423-B093-95FD78F55CB7.jpg D0EEA4A1-0087-45FF-8643-43198A7468ED.jpg
  2. Mar 17, 2018 at 8:37 PM
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    @Roman sells little blue clips that help with this.they actually slide right into that slot that you zip tied.
    1UPPER, 4x4_Angel, BTBAKER and 3 others like this.
  3. Mar 18, 2018 at 12:51 AM
    Hoologan
    California
    Good to know. Thanks.
  4. Mar 18, 2018 at 12:53 AM
    Appreciate sharing!
  5. Mar 18, 2018 at 5:32 AM
  6. Mar 18, 2018 at 6:06 AM
    borntostun
    borntostun New Member
    Where can I find those clips from Roman for purchase? Thanks.
    Sting Ray likes this.
  7. Mar 18, 2018 at 7:35 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    1UPPER, MotoTundra and Roman like this.
  8. Mar 20, 2018 at 11:42 AM
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    Mine do the exact same, went from metal corners to painted plastic corners.
    How do those clips work @Roman
    I was going to bring that issue up with my Service Advisor next visit to toyota
  9. Mar 20, 2018 at 11:46 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    the clips slide into the little slot and sort of wedge the fog light assembly into place. They don't take all of the jiggle out, but definitely makes it better.
  10. Mar 20, 2018 at 11:54 AM
    TundraCoast
    Ian
    California
    1794 4x4
    I'm running there Morimoto LED fog lights. Ill have to take look, they reuse the stock surrounds. Would these clips still apply to non-oem fogs?
  11. Mar 20, 2018 at 11:57 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    should.. on the drivers side shroud the little slot would be on the right bottom corner where the fog light assembly goes under/in the slot. I believe the passenger side is the same just reversed if i remember. Wish I had a pic to show you.
  12. Mar 20, 2018 at 12:05 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    They clip through the little slot on the back of the bumper end and into the fog light to help hold them still.
    Look almost identical to these:
    NewImprovedRon and geno0506 like this.
  13. Mar 20, 2018 at 12:14 PM
    TundraCoast
    Ian
    California
    1794 4x4
    thx, so you would need qty 2 (one per side on the tab described)?
  14. Mar 20, 2018 at 12:19 PM
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Mine only jiggle very slightly. Just swapped to 18 LED fogs and they seem tighter than the stock halogen ones.
  15. Mar 20, 2018 at 12:19 PM
    Roman
    Roman
    Franklin, TN
    Yep, that is correct.
  16. Mar 20, 2018 at 2:19 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    That slot that the clip slides into is the one above in the pic that the zip tie goes through.
  17. Mar 20, 2018 at 3:56 PM
    Hoologan
    California
    It would appear so
    Sting Ray[QUOTED] likes this.
  18. Mar 20, 2018 at 4:26 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    It is for sure.
  19. Jul 11, 2018 at 4:49 PM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    @Roman is the fog bezel the same between the chrome and painted bumpers ends? i just installed the painted bumper ends and my fogs jump around like crazy! so much so that i just turned them off for now. i ordered the clips, but it sure does seem that the trucks with painted bumpers on the lot at my local dealership are ALOT tighter than my fog bezel?
  20. Jul 11, 2018 at 5:13 PM
    Are the FL beams adjustable? If so, how many of you on here are lifted 4" or higher have adjusted the beams?
  21. Jul 11, 2018 at 5:17 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    From experience I wouldn’t bother with the blue clips. Zip ties are your best friend with this one.
    ForceV4, New_DoorDing and supertran82 like this.
  22. Jul 11, 2018 at 5:23 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    So the color matched bumper ends are plastic?
  23. Jul 11, 2018 at 5:42 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    I used gorilla double sided tape. Works like a charm
    geno0506 and NewImprovedRon like this.
  24. Jul 11, 2018 at 8:58 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Tundra Dude needs to see this.
    New_DoorDing likes this.
  25. Jul 12, 2018 at 6:38 AM
    Roman
    Roman
    Franklin, TN
    Yep, all bezels are the same. The OEM plastic bumpers utilize those little blue clips to keep the fog light housing tight.
  26. Jul 12, 2018 at 8:03 AM
    Nit2wn
    Nit2wn New Member
    James
    Alabama
    2013 Crewmax TRD 4wd
    I took mine apart and put a rubber o-ring on each side of the adjuster to take up the slack.
  27. Jul 15, 2018 at 11:18 PM
    geno0506
    geno0506 New Member
    Michael
    I put in my 2018 LED oem fogs and I thought I was loosing it because my drivers side fog was shaky when driving and bothers me seeing the light spread shake while driving! I may give that a drive!
    Sas likes this.
  28. Jul 15, 2018 at 11:19 PM
    geno0506
    geno0506 New Member
    Michael
    Can I buy those through you! Only my drivers side is shaky! @Roman Thanks
  29. Jul 15, 2018 at 11:21 PM
    geno0506
    geno0506 New Member
    Michael
    for the shaky led fog? if so how'd you do it!
    2013 Tundra TRD 4X4 likes this.
  30. Jul 16, 2018 at 7:37 AM
    Roman
    Roman
    Franklin, TN
    geno0506[QUOTED] likes this.
