JDM ASTAR LED Blinker Bulbs are the biz
Discussion in 'General Tundra Discussion' started by CCLJ03, Mar 25, 2019.
  1. Mar 25, 2019 at 12:15 PM
    CCLJ03
    CCLJ03 [OP] Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Plug and play! For 2018+ all you have to do is just switch the bulbs and you're good. Here's a short video comparison of OEM on the passenger side and JDM bulb on the driver side. It's at least twice as bright. No load resistors needed!
    https://youtu.be/t7fzYSOuQzM
    Here's a screenshot of both bulbs at the peak of brightness:
    I also switched out my main brake light bulbs to LEDs with these -
    https://www.amazon.com/gp/product/B07MYX6Z2N/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    Which I would say are at least 50% brighter than stock bulbs. And they work great! (also plug and play)
    Started a new thread because I didn't want this to get lost in the shuffle seeing as there was a lot of confusion about this.
    I'll be buying some bulbs for the rear blinkers soon (once I find the right ones) and I'll report back on if they are plug and play or not.
  2. Mar 26, 2019 at 7:47 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
  3. Mar 26, 2019 at 7:49 PM
    CCLJ03
    Craig
  4. Mar 26, 2019 at 7:51 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Pre-2018 tundras with the 18+ LED headlight conversion will need resistors. Ask me how I know.
  5. Mar 26, 2019 at 8:03 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    How do you know?:boink:
  6. Mar 26, 2019 at 8:05 PM
    CCLJ03
    Craig
    I really don’t understand why it is that in 2019 this is still an issue. Any do ANY manufacturers still use incandescent bulbs?
    HappyGilmore and Pudge[QUOTED] like this.
  7. Mar 26, 2019 at 8:11 PM
    Pudge
    CT
    Yeah it's pretty nuts they still use the old style bulbs. I pulled my LED blinker bulbs out due to hyperflash but eventually I'll put them back in with resistors, they really are very dim as they are now
    CCLJ03[QUOTED][OP] likes this.
  8. Mar 26, 2019 at 8:13 PM
    Pudge
    CT
    I was so mad that day when I was freezing my ass off in 0 degree weather only to have those LED bulbs hyper flash. Pissed me off.
    Black Wolf, Migraine and CCLJ03[OP] like this.
  9. Mar 27, 2019 at 4:48 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I bought the JDM Astars for my front DRL/Signal (amber) and Stop/Tail/Marker (red), but after looking at the Antline "Extremely Bright" LEDs (amber/red/white), I think I like the Antlines better in all applications where they will fit.
    For my 2017 with 2018 headlights, they will fit the applications above plus Back-up. Bulb life claim is higher, and Amazon reviews on the Antlines show only 2% one star, 96% 4-5 stars, so people really like them. By comparison, JDM Astar in white has like 13% one star rating with lots of short life complaints. The amber and red JDM Astars review better.
    The Antlines are identical in appearance to the JDM Astars, and lumen rating is the same as well. They could have chosen a better company name. :D
    CCLJ03[OP] likes this.
  10. Mar 30, 2019 at 10:03 AM
    owb2gp
    owb2gp New Member
    ID
    I have a 2018, will these both be just plug and play? @CCLJ03
    https://www.amazon.com/gp/product/B07MYX6Z2N/ref=ox_sc_act_title_1?smid=A28CIAO57KNOQR&psc=1
    https://www.amazon.com/gp/product/B00PHVUWR8/ref=ox_sc_act_title_2?smid=A126Q4T86JLNL&psc=1
    Reason I'm asking because Amazon says the yellow doesn't fit my 2018 Tundra.
  11. Mar 30, 2019 at 10:31 AM
    CCLJ03
    Craig
  12. Mar 30, 2019 at 10:45 AM
    JohnLakeman
    Plug and play depends on which bulbs you're replacing. Check the bulbs listed in your owner manual. Unless they've changed the rear bulbs from 2017, the rear Signal (921) takes a different LED than that Antline (3157), but the Antline WILL work in the Stop/Tail light position. Confirm by checking your owner manual.
    owb2gp[QUOTED] likes this.
  13. Mar 30, 2019 at 2:12 PM
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
  14. Apr 1, 2019 at 3:33 PM
    owb2gp
    owb2gp New Member
    ID
    Bought both. Should be here tomorrow.
  15. Apr 1, 2019 at 3:46 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    You had my attention at JDM......
  16. Apr 1, 2019 at 4:36 PM
    CCLJ03
    Craig
    Any particular reason why???
  17. Apr 3, 2019 at 1:06 PM
    owb2gp
    owb2gp New Member
    ID
    Easy install and are way brighter. Did the front turn signals and rear brake lights.
  18. Apr 12, 2019 at 6:03 AM
    Firefed22
    Firefed22 New Member
    2019 Tundra Crewmax TRD Sport
    Nothing yet, but headed that way!!!!
    I have a 2019 TRD Sport. Do you think I will need resisters, I am confused because a bunch of people say yes, and some say no. I just want to plug and be done.
    THanks
    ,Brian
  19. Apr 12, 2019 at 6:39 AM
    I did the fronts also, great improvement.
  20. Apr 12, 2019 at 6:48 AM
    owb2gp
    owb2gp New Member
    ID
    Both front signal and rear brake lights were plug and play for my 2018 Sport.
  21. Apr 13, 2019 at 7:43 AM
    CCLJ03
    Craig
    The JDMs in the front will not need resistors. Brake lights don’t blink so you’ll also be good there without resistors.
    The rear blinkers seem to always need resistors. Haven’t found an affordable option that have real reviews where people didn’t need resistors.
    silverhack likes this.
  22. Apr 13, 2019 at 9:48 AM
    Tzvia
    Tzvia Just an old woman in a pickup truck.
    Los Angeles County
    2019 5.7L Limited TRD Off Road 4x4
    Just a Bed Rug and Snugtop XTRA Vision
    Ordered the rear brake lights and they were plug and play (2019 Limited TRDOR). Brake lights are super bright, a nice cheap upgrade. So I went and ordered the front blinkers just now.
    I was rear ended so many times in my last Tundra that I wanted to put a sign back there "Yes, it's me, please don't hit me again". 3 or 4 new bumpers (lost track) + at least one straighten and re-chrome. Whatever I can do to be more visible (how does one miss a Tundra?) I'll do, within reason, and this is a good idea that doesn't cost your first born. Hopefully they will last a few years at least.
  23. Apr 13, 2019 at 11:37 AM
    JohnLakeman
    In that case, don't forget to also install LED in the high mount brake light. It'll be a different bulb number...see your owner manual.
  24. Apr 13, 2019 at 11:46 AM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    Can you please provide a direct link to the front turn signal LEDs?
  25. Apr 13, 2019 at 12:01 PM
    YotaMan
    Colorado Springs
    2021 Platinum
    Reason I'm asking is because that Amazon link had a bulb type 744X. I thought our was 3157?
  26. Apr 13, 2019 at 12:08 PM
    JohnLakeman
    If you have the stock headlights, look up the bulb number in the owner's manual. Bulb specifications are in the index under "Light Bulbs"...in the 2017 OM this is in the "Specifications" section, page 528.
  27. Apr 13, 2019 at 12:26 PM
    YotaMan
    Colorado Springs
    2021 Platinum
    It's a 2018 with OEM LED lamps, can anyone chime in without me going out and digging that out?
  28. Apr 13, 2019 at 12:57 PM
    Tzvia
    Los Angeles County
    I ordered this one: https://www.amazon.com/gp/product/B07FBYPQ1M/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
    Antline 3157 amber yellow with projector. I hope it's right, guess I will find out. Probably won't get the time to put them in till next weekend.
    EDIT: AARRRRGGGGG doesn't fit. Yea every where I went online looking for 'front signal bulbs' for 2019 said 3157 but nope. I guess that's the one for the headlight assembly that is for Tundras without the LED headlight. Sigh. Should have looked more carefully at the manual. 7444NA single color is what I need as my truck DRL is the leds around the housing edge. So back to Amazon...
  29. Apr 30, 2019 at 6:30 PM
    CCLJ03
    Craig
    Damn! That's a bummer man. been busy but I'm about to start working on the rest of the lights!
  30. Jan 22, 2020 at 4:01 PM
    owb2gp
    owb2gp New Member
    ID
    So I bought and installed these last spring for my rear brake lights.
    Now lately I've had a few issues including brake light not working at all and also strobe affect. So I removed both LED brake lights and went back to stock a month ago. Co-worker told me my brake light was out after work today. I'll change the bulb out again to a non led bulb and see if it works.
    Would using a LED bulb mess anything up without using a resistor?
