jberry's Mall Crawling Tow Pig Version 2.0
Discussion in '2.5 Gen Builds (2014-2021)' started by jberry813, Jun 14, 2015.
  1. Aug 20, 2017 at 5:33 PM
    #181
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    Dammit Jason. Sell me those Methods you took off.
  2. Aug 24, 2017 at 6:08 PM
    #182
    ReCKzX
    ReCKzX New Member
    2023 Tundra TRD Pro Ice Cap
    Saw your new tacoma build, badass. Are you using your tundra's engine for the build or did you find a used one?
    ColoradoTJ likes this.
  3. Aug 24, 2017 at 6:10 PM
    #183
  4. Aug 24, 2017 at 6:24 PM
    #184
    jberry813
    jberry813 [OP] The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Are you crazy? I mean I'm fucking bat shit crazy, but even I won't sacrifice a 2 year old Platinum grocery getter for some turd gen project.
  5. Aug 24, 2017 at 6:30 PM
    #185
    Are you sure? LOL
    Thegr8punkin likes this.
  6. Aug 24, 2017 at 6:38 PM
    #186
    jberry813
    Lake Tahoe
    What the hell am I gonna tow it with when I break it?
  7. Aug 24, 2017 at 6:57 PM
    #187
    It won't break....buahhhhaaaa!!
    Famous last words.
  8. Aug 24, 2017 at 8:35 PM
    #188
    Sefferston
    Seth
    ERMERGERD TOYOTA
    Most expensive grocery getter in existence.
  9. Aug 24, 2017 at 9:22 PM
    #189
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Mr. Jberry
    You are the official king shocks expert, first off bad ass truck mayng!. Ok, I have kings front and rear no clickers with stock uca, been speeding through tank trails here at fort Irwin and I love them, super smooth and controlled, took off my front sway bar too. If I get total chaos uca, is there something to make the kings travel more? I have them on stock settings which level out the truck and I want to leave them at that height, ive heard when you get an aftermarket uniball uca theres a topout spacer or something that can be removed to enable more travel and of course I will revalve and retune. I am in CA where there are a lot of offroad shops that can tune them right, whats your take? I like going fast on and offroad.
  10. Aug 25, 2017 at 10:40 AM
    #190
    jberry813
    Lake Tahoe
    That's why I said "when" it breaks.
    :notsure:
    Inside the coilovers there is a shaft spacer. I don't remember how large the one is in the Tundra coilovers though. Regardless, you can shorten the spacer 1/4" (or if it's only 1/4" just remove it) and gain a little bit more droop travel.
    Honestly I'm really happy with the out of the box valving the front of the kings came with. The only thing I would do is plug one of the free-bleed holes in the piston if you are really getting on it and want it a little bit stiffer (or you are adding weight like armor). Just make sure you red loctite that fucker in there.
  11. Aug 25, 2017 at 10:57 AM
    #191
    Exactly. I say the same thing. I need a reliable tow rig as well.
  12. Aug 28, 2017 at 9:37 AM
    #192
    Samoan Thor
    Thanks Brofessor
    TheBeast, aperezsh and NewImprovedRon like this.
  13. Oct 8, 2017 at 4:02 PM
    #193
    TheBeast The Beach
    @jberry813 do you clear the bottom of the KING coilovers with the sequoia front sway bar ?
    the stock Tundra one is pretty close already. Any pictures ?
    thanks
  14. Oct 8, 2017 at 5:07 PM
    #194
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Externally, they are dimensionally identical.
  15. Oct 8, 2017 at 5:08 PM
    #195
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    So what os the difference between the saq s bar vs the tundras?
  16. Oct 8, 2017 at 5:12 PM
    #196
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Think of them more like a tube than a solid bar. The thickness of the wall of the tube is greater on the Sequoia bar (tubing), which translates to a greater effort is required to flex it.
  17. Oct 8, 2017 at 5:16 PM
    #197
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Huh. Ok makes sense. I was always told they were a bar and that's why a thicker sway bar is so much better.
  18. Oct 8, 2017 at 5:20 PM
    #198
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    What is often referred to as a thicker bar would probably have a greater OD, but the same or similar wall thickness. Or it could even be greater in both of those specifications.
    Thegr8punkin[QUOTED] likes this.
  19. Oct 8, 2017 at 5:22 PM
    #199
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Going from old Toyota 2wd pickups, it's definitely the later. The one tons have a 28mm vs the standard having a toothpick 18mm
    Wynnded[QUOTED] likes this.
  20. Oct 8, 2017 at 5:31 PM
    #200
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I could see that.
  21. Oct 8, 2017 at 5:45 PM
    #201
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    That's where my background is so ya. That and f sway bars on trail rigs
  22. Oct 8, 2017 at 8:21 PM
    #202
  23. Oct 8, 2017 at 8:43 PM
    #203
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Vacuum cleaners suck.
    zcarpenter92 and T-Rex266 like this.
  24. Oct 8, 2017 at 8:44 PM
    #204
    mdavis and Thegr8punkin like this.
  25. Oct 9, 2017 at 2:18 AM
    #205
    Awesome Rig!
    jberry813[OP] likes this.
  26. Oct 9, 2017 at 8:00 AM
    #206
    jberry813
    Lake Tahoe
    My entourage speaks for me when I'm off the grid.
    Sunnier, 757TUNDRA, csuviper and 3 others like this.
  27. Oct 9, 2017 at 11:52 AM
    #207
    Sefferston
    Seth
    ERMERGERD TOYOTA
    So when are we snowboarding. I saw you got snow.
  28. Oct 9, 2017 at 8:05 PM
    #208
    jberry813
    Lake Tahoe
    Any day that ends in y
  29. Oct 9, 2017 at 8:15 PM
    #209
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Can I come?
  30. Oct 9, 2017 at 9:23 PM
    #210
    jberry813
    Lake Tahoe
    Sure...as long you can keep up with an old man.
