jberry's Mall Crawling Tow Pig Version 2.0
Discussion in '2.5 Gen Builds (2014-2021)' started by jberry813, Jun 14, 2015.
  1. Feb 18, 2016 at 9:56 PM
    #121
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    And those people need to die.
    Fireball is the devil.
    Me and a few buddies just got back from this place called Andermatt. It's in Switzerland and a huge freeride mountain. Beautiful powder basically everyday.
    It's only 2 racks if you think about it. 5 gallons doesn't go very far haha. Granted at 10% ABV, 3 will make you feel real good.
    We haven't had snow all season ): making me quite sad.
    zcarpenter92 likes this.
  2. Feb 19, 2016 at 9:15 AM
    #122
    zcarpenter92 and mdavis like this.
  3. Feb 19, 2016 at 12:31 PM
    #123
    Sefferston
    Seth
    ERMERGERD TOYOTA
    Whatta queer.
    zcarpenter92 and Flying Yota like this.
  4. Mar 2, 2016 at 10:34 AM
    #124
    jberry813
    jberry813 [OP] The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Sooo...I hate not having a spare that's even remotely close to the size tires I'm running. But I'm also cheap on some things and didn't want to fork out for another Method wheel and a 35. So I kinda improvised.
    Picked up a 275/70/18 KO2 to mount on the stock steel spare. According to spec sheets, it's 1.3" shorter than my 35/12.50/18 KO2s. I put the tire next to my existing tires and it's a little over an inch smaller with my current tread, which equates to a hair over 1/2" difference in ride height compared to the rest of the tires if I get a flat and actually have to mount the spare. Good enough for me!
    I did have to slightly modify the area where the spare resides. I cut off the two factory retainer looking things that keep the tire from moving aft. However, if you look at the way the crossmember is designed, with a larger tire the crossmember has a built in retainer. tire doesn't move at all when it's loaded up. And it clears the shackles both directions.
    Also, I did a test with the full sized 35/12.50 and it will fit in the stock location as well and will clear the shackles too as long as you are diligent as you install it. Just have to do the same modification on removing the brackets. But the tire sits much lower than this.
    FUNDR., Jsena, Law323 and 5 others like this.
  5. Mar 2, 2016 at 11:24 AM
    #125
    Sefferston
    Seth
    ERMERGERD TOYOTA
    I'd bang it.
    jberry813[OP] and T-Rex266 like this.
  6. Mar 2, 2016 at 12:16 PM
    #126
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I'd like to go bigger on the spare too as well as get rid of the highly damaged spare I have now. Didn't look like much taller of a tire would fit. You proved you can. Will be searching for a cheap tire now.
  7. Mar 2, 2016 at 12:23 PM
    #127
    csuviper
    Broomfield, CO
    Did you figure out a way to prevent this?
  8. Mar 2, 2016 at 1:26 PM
    #128
    jberry813
    Lake Tahoe
    Kinda. I just sandwiched a piece of scrap rubber I had in the garage.
    Law323, dcsleeper408 and tat2ude39 like this.
  9. Mar 2, 2016 at 8:31 PM
    #129
    csuviper
    Broomfield, CO
    That works
  10. Mar 3, 2016 at 6:26 PM
    #130
    jberry813
    Lake Tahoe
    Color matched mirror caps and door handles.
  11. Mar 3, 2016 at 6:30 PM
    #131
    His creed: (I)'m a (P)ansy (A)ss because I can't handle a real IPA.
    jberry813[OP] likes this.
  12. Mar 3, 2016 at 6:32 PM
    #132
    I'm lovin it. Bad Ass.. What's left to do? :thumbsup:
  13. Mar 3, 2016 at 8:54 PM
    #133
    jberry813
    Lake Tahoe
    Convince the wife to bump uglies in the back seat
  14. Mar 4, 2016 at 5:13 AM
    #134
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    :rofl:Been trying that myself!
    jberry813[QUOTED][OP] likes this.
  15. Mar 4, 2016 at 7:00 PM
    #135
    Easier said than done. :ballchain:
  16. Mar 31, 2016 at 6:08 PM
    #136
  17. Mar 31, 2016 at 6:27 PM
    #137
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Plenty of room ;)
  18. Mar 31, 2016 at 6:39 PM
    #138
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Black Wolf likes this.
  19. Apr 6, 2016 at 5:47 PM
    #139
    Sefferston
    Seth
    ERMERGERD TOYOTA
    Surprised you haven't sprung for bypasses yet.
    Take my money and make 2.5 3 tube bypasses fit. kthxluvubye
  20. Apr 17, 2016 at 7:45 PM
    #140
    jberry813
    Lake Tahoe
  21. Apr 17, 2016 at 7:48 PM
    #141
    csuviper
    Broomfield, CO
    Right on. Good idea. At some point I will be adding a larger tire and something like that to protect it.
  22. Apr 26, 2016 at 7:57 AM
    #142
    Sunnier, dcsleeper408, rons23 and 2 others like this.
  23. Apr 26, 2016 at 8:50 AM
    #143
    jberry813
    Lake Tahoe
  24. Apr 26, 2016 at 9:09 AM
    #144
    mdavis
    Michael
    Rock Hill, SC
    Relentless and LOTSOFTOYS like this.
  25. Apr 26, 2016 at 9:13 AM
    #145
    csuviper
    Broomfield, CO
    Relentless likes this.
  26. Apr 26, 2016 at 9:14 AM
    #146
    jberry813
    Lake Tahoe
    Na. Just some asshole with a welder.
    Thanks!
  27. Apr 26, 2016 at 4:50 PM
    #147
    jberry813
    Lake Tahoe
    So TWO of these bad boys showed up at the house today.
    Sefferston and mdavis like this.
  28. Apr 26, 2016 at 6:49 PM
    #148
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
  29. Apr 26, 2016 at 8:44 PM
    #149
    Relentless
    Eric
    Giant Mo'fuckin gas tanks!
    Going to definitely require a couple beers to get those things under our trucks! haha. They're damn heavy too, at least 150-175lbs dry.
    Not stopping every 200 miles when towing will make it all worth it though!
  30. Apr 27, 2016 at 6:48 PM
    #150
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Say what???? U made them eric? Where do they mount?
