JB4
Discussion in '3rd Gen Tundras (2022+)' started by 2020Platinum, Mar 25, 2023.
  1. Jun 29, 2023 at 6:02 PM
    #121
    roboots21
    roboots21 New Member
    2022 MGM Tundra Limited DC
    Checked it after about 500 miles and it had maybe a tablespoon in it. It wasn't a lot but I was glad to see it was catching something.
  2. Sep 11, 2023 at 5:18 PM
    #122
    Taco.ftp
    Taco.ftp New Member
    2022 Tundra PLT
    I've had my JB4 for about a week and gone through 2 tanks of E30 making 6.5 more PSI, All I can say it the truck pick up from 40 MPH is insane for what the truck is. I've gone to 2 car meets and done experiments in MEXICO racing all kinds of of truck in similar class and won. I've raced Chrysler 300's with the V8's and and either won or kept up with them.
    I am waiting for my throttle controller to come in and all hell will be let loose. Sleeper truck for sure the innocent Toyota tundra will take names
    2020Platinum[OP] and 4mm like this.
  3. Sep 12, 2023 at 10:44 AM
    #123
    TerryBMS
    TerryBMS New Member
    Hey, Terry @ BMS here. Working on signing up as a vendor so we can post here. :)
    I've been working on a new JB4 feature, active airdam delete, for customers who want to remove the module for a winch, revised bumper/crash bar, etc, etc. It's basically a cable that plugs in to the factory harness and then plugs in to the JB4 harness in place of the OBDII cable. If anyone is interested in helping test it out just email me!
    SC4333, ryanwgregg and wildmank99 like this.
  4. Sep 12, 2023 at 5:02 PM
    #124
    RPKEAN
    RPKEAN New Member
    Ryan
    Anyone else have any long term updates on their JB4? Any long term issues? I wish there were more YouTube videos showing differences out there.
  5. Sep 20, 2023 at 6:57 AM
    #125
    2020Platinum
    2020Platinum [OP] www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    I haven't done any follow up videos yet other than the 2 I originally released, but all I can say is I freakin love it...I've had it for months now, run it on map 2 with 93 octane, and even that makes it way more fun to drive...I've had several of my viewers ask about follow up videos, so maybe I'll make one, but bottom line is I would absolutely recommend it...no issues to date, hopefully stays that way
    forzamrit and SC4333 like this.
  6. Sep 20, 2023 at 7:10 AM
    #126
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I've had mine for 18 months now..no issues on map 5 running E30 mix
  7. Sep 20, 2023 at 8:16 AM
    #127
    RPKEAN
    RPKEAN New Member
    Ryan
    I would appreciate that greatly. I have a ‘23 so I’m not concerned about the engine blowing. Would the 40hp estimate be on stage 2 or 5?
  8. Sep 20, 2023 at 8:51 AM
    #128
    eddiefromcali
    Eddie
    100% Stock
    I wouldn't expect a similar bump in power like from other trims. JB4 only increases boost and depends on timing/fuel tables already programmed by Toyota. I'd bet that SR tuning is weaker along with lower boost and might not be capable of same delta
    Woocawachie and Justa_SR like this.
  9. Sep 21, 2023 at 7:46 AM
    #129
    2020Platinum
    Patrick
    Northeast PA
    I'm honestly not sure how much of a gain you get on map 2, but you can definitely feel it… I tried to get my truck on a dyno for before and after comparisons but unfortunately the only place within a 100 mile radius of me couldn't accommodate the truck because of the width
  10. Sep 24, 2023 at 9:19 AM
    #130
    chadlogan112
    chadlogan112 New Member
    I have an SR, I logged map 0 and each pre-loaded map 1-5. Was advised by bms that map 3 on 93octane was as safe as they’d suggest until further time could be invested on this platform. Truck feels much stronger with icon coilovers and 35” tires. Will it be worth it to everyone to justify paying for the higher grade fuel, probably not. I will add that I’ve only had the tuner installed for around 300miles however. I’d say it most likely puts an SR at approximately the same power range as the stock SR5. Stock SR seems to put 6-7psi stock, on map 3, I’m around 11-13psi. I believe a stock sr5 I once saw stock map run around 9-10psi for reference.
    Eurodriver[QUOTED] likes this.
  11. Sep 25, 2023 at 6:56 AM
    #131
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    Has anyone experienced strange issues after putting in the jb4? A few things: my navigation thought I was in Asia somewhere and could not calculate my drive home because it exceeded the max trip distance (45 mile drive). This morning my driver side window got halfway down and started jerking itself down with a loud noise.
  12. Sep 25, 2023 at 6:59 AM
    #132
    eddiefromcali
    Eddie
    100% Stock
    The window thing is common. Can't say I've had any GPS issues with or without the JB4. Did you remove it to verify the GPS worked again?
    ziznack[QUOTED] likes this.
  13. Sep 25, 2023 at 7:00 AM
    #133
    ziznack
    ziznack New Member
    Texas Y'all
    Is the window thing a result of the JB4 or just a common issue that the dealership needs to fix?
  14. Sep 25, 2023 at 7:07 AM
    #134
    eddiefromcali
    Eddie
    100% Stock
    It's a dealership issue. Whenever those seals get wet, they cause that bouncing/jerking thing. Goes away after you lower and raise the glass a few times
    22whatwedo and ziznack[QUOTED] like this.
  15. Sep 25, 2023 at 7:10 AM
    #135
    ziznack
    ziznack New Member
    Texas Y'all
    Gotcha, thanks. Makes sense cause I just got my truck washed about 20 minutes before.
  16. Sep 30, 2023 at 9:54 AM
    #136
    RPKEAN
    RPKEAN New Member
    Ryan
    Not to bug ya, but were you ever able to make a video? Curious what the stock vs even map 2 difference would be.
  17. Sep 30, 2023 at 10:47 AM
    #137
    ziznack
    ziznack New Member
    Texas Y'all
    I got some information from BMS about this. I haven't dynoed or anything but you can tell the difference.
    I am running an s&b intake and the JB4. With 93 octane gas, I am told there should be 40-50 more HP with map 1. Map 2 should get me an extra 10 and then another 10 with map 3. This is all 93 octane. Map 3 would be more with E30. There might be a few extra HP with map 4 and 93 octane but not much.
    I have also asked about using E30 as the tundra says not to use more than E10 or E15 (can't remember which). BMS says it is safe to run E30.
    eddiefromcali likes this.
  18. Sep 30, 2023 at 12:57 PM
    #138
    eddiefromcali
    Eddie
    100% Stock
    Been running upto E45 and its fine
  19. Sep 30, 2023 at 1:21 PM
    #139
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Wow sounds fantastic but 40-50 on setting 1? Does it feel like that much of a difference?
  20. Sep 30, 2023 at 1:37 PM
    #140
    ziznack
    ziznack New Member
    Texas Y'all
    Yeah it does
    bigblue14[QUOTED] likes this.
  21. Sep 30, 2023 at 1:37 PM
    #141
    bigblue14
    Craig
    Bitchin \m/
  22. Sep 30, 2023 at 5:19 PM
    #142
    RPKEAN
    RPKEAN New Member
    Ryan
    Is there any risk of pinging or pre-detonation on map 3 without e-85? I think I saw it’s only a 0.5 psi difference.
  23. Oct 1, 2023 at 9:10 PM
    #143
    ziznack
    ziznack New Member
    Texas Y'all
    That being said, is it worth the $600-700 or whatever it costs new with the Bluetooth kit? No, I wouldn't say so. Is it worth $400 for a used one? I think so. I paid $425 for mine locally and then had to spend the $28 on the app to be able to use it. all in for about $450 I think is worth it, but not much more than that.
  24. Jan 7, 2024 at 8:13 AM
    #144
    dutch2112
    dutch2112 New Member
    2023 Limited hybrid Trd
    35” Falken Wildpeak AT3, 17x8.5 method 305 nv, trd lift kit, trd pro grill, trd exhaust
    My question is being mine only has 14k on it, should I just put a pedal commander on it for now to get rid of the lag then wait until even 36k (out of basic warranty) to throw it on?
    I’m a long term guy (the reason I own Toyotas and run domestic service shops as a director lol)
  25. Jan 7, 2024 at 8:20 AM
    #145
    ziznack
    ziznack New Member
    Texas Y'all
    Why wait until out of warranty? Drive in sport S mode to get rid of the lag.
  26. Jan 7, 2024 at 8:23 AM
    #146
    RPKEAN
    RPKEAN New Member
    Ryan
    Just my 0.02….almost every-time I drive I flip to sport and that takes care of 90% of the dead pedal problem.
    I still sense a slight issue when trying to hit the accelerator hard when doing a rolling stop, but sport mode makes a huge difference over normal and reminds me of my ‘19 Tundra in regards to throttle response.
    - 23 Non-Hybrid non AVS.
  27. Jan 7, 2024 at 8:27 AM
    #147
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Or why not Sport+ mode.
    I'm either in Comfort or Sport+ mode,the Sport+ is pretty sweet, I can appreciate how it stiffens up the steering, suspension changes & shifting patterns on the tranny (opps can I use that word) and turbo PSI.
  28. Jan 7, 2024 at 8:51 AM
    #148
    dutch2112
    true, I do tend to switch over to sport quite frequently much like I did on m 14’ as it was no where near the same as my 08’ throttle response.
    So essentially you are saying pedal commander not worth it? Just buy the jb4 and shut my mouth lol
  29. Jan 7, 2024 at 8:51 AM
    #149
    ziznack
    ziznack New Member
    Texas Y'all
    Not everyone has the extra sport s+ mode, that's why I just said sport s.
  30. Jan 7, 2024 at 8:52 AM
    #150
    dutch2112
    100% I have a limited so no fancy pants + lol
    G3ardnut, ziznack[QUOTED] and Blufin like this.
