JB4
Discussion in '3rd Gen Tundras (2022+)' started by 2020Platinum, Mar 25, 2023.
  1. Apr 21, 2023 at 6:07 PM
    #61
    Mpage
    Mpage New Member
    Matthew
    2022 Tundra SR5
    Jb4 tuner Dv8 offroad bumper 12,000lbs winch
    I'm running the tuner on my non hybrid SR5. Lag is still there until the motor is up to temp. Totally worth the money in my opinion.
    I'm going to note though I had my truck detailed. The guy did an amazing job but went under the hood. Tuner got wet. No damage to the tuner but the Bluetooth connector got fried the next day. Truck shut down on me and threw 3 codes. I was able to erase 3 of them. There was a hard code of no power to PCM that only the dealer can delete. U0100 I think it is off memory. I had to uninstall the tuner on the side of the road to get the truck going again.
    I reinstalled when the new Bluetooth connector came in. No issues. But that week without it made me really miss the tune. Just installed the bms blowoff valves with it this time.
    For this saying it's a pain to disconnect. If you approach the motor with your head on the passenger side you can get a clear view of the clip. Take one of those cheap jimmy bars with a 90 on it and stick it in there to apply pressure to the clip tab. Reach in with your left hand and apply the pressure towards the firewall. So much easier then cramming both hands in there trying to release the tab in the blind.
    Taikowaza likes this.
  2. Apr 21, 2023 at 6:29 PM
    #62
    T-MAC
    T-MAC New Member
    Westernesse
    2023 Tundra
    Icon stage 7, Dobisons rear springs and track bar, Icon Rebound Pro wheels, MT Baja Legend 40s, JB4, Pedal Commander, AFE intakes and hot pipes
    Is there a performance element to the blow off valves? Or are they only for sound?
  3. Apr 21, 2023 at 6:39 PM
    #63
    Mpage
    Mpage New Member
    Matthew
    2022 Tundra SR5
    Pretty much just sound. The BMS valves have 4 Allen....keys I'm going to call them. All 4 removed will be the loadest. They suggested starting with 2 out and going from there. That's what I'm running now. I can hear the turbo whistle a little loader now and the Blow off wosssh sound. Not annoyingly load but enough for some pleasure. There was a YouTube guy that said it stalled his truck,. But I'm wondering if he had the wastegate issue. I might remove another key next week and see if I like the sound difference or maintain.
    T-MAC[QUOTED] and Taikowaza like this.
  4. Apr 21, 2023 at 6:52 PM
    #64
    Mpage
    Mpage New Member
    Matthew
    2022 Tundra SR5
    https://www.homedepot.com/p/Dasco-Pro-Pry-Bar-Set-3-Piece-91/202585548
    I used the bigger one in this set that I already had. And when I take it to the dealer I remove the tuner. It's not to bad after the second-3rd time doing it. That back clip is the hardest part. I just tuck my ob2 power plug up in the dash and leave the power cord going through the firewall.
    How did I know it's a hard code? I used a scanner,. Not the jb4 to pull the codes. It wouldn't let me earase it and was marked "permanent" on my scanner. I only take my truck back to the dealer for recalls. The Toyota dealers around me don't do service work that fits my schedule. The cutoff is 430 for appointments, and I never really know where I'm going to be on what day. So I get my oil changes at Valvoline drive through. Only if there was a major mechanical issue would I take it back in for the warranty. But 25k on my truck and nothing major. Just the same issues everyone else has complained about that Toyota doesn't have resolutions for. Wind noise, infotainment disconnecting ect.
    Taikowaza[QUOTED] likes this.
  5. Apr 21, 2023 at 8:00 PM
    #65
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    That was mark brenner....complete tool.
  6. Apr 21, 2023 at 11:57 PM
    #66
    NVRsyDI
    NVRsyDI 22 TRD PRO Prerunner
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    Fox 3.0 Camburg UCA's and Trailing Arms KMC Bead Lock 17" (Unreleased) 37" Nitto Tires Burger 4P Tuner Burger BOV K&N Cold Air Intake and charge pipes Hike It Pedal Controller Black Widow Exhaust (2) JL Audio 13.5 TWv2 subs and Focal Components 10% Tint Windshield 50% 8 gang switch hub 12 smart rgb rock lights
    Why do you say that? My BOV stalled my truck too and put it into safety mode. I like Mark.
  7. Apr 22, 2023 at 4:20 AM
    #67
    T-MAC
    T-MAC New Member
    Westernesse
    2023 Tundra
    Why does it stall the truck?
  8. Apr 22, 2023 at 5:50 AM
    #68
    mattvarnell
    mattvarnell New Member
    Because the air is metered by the MAF sensors pre-turbo, and the OEM setup is to recirc the air back into the closed system. When you add aftermarket BOV, you are releasing metered air that was accounted for by the system into the atmosphere and it can cause a stall. This is why the BOV is adjustable, not only for sound but to find the amount of metered air you can release without causing a stumble.
    T-MAC[QUOTED] likes this.
  9. Apr 22, 2023 at 9:47 AM
    #69
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    Can confirm that the BMS valve spacers stalled out my truck also. Ran them for a week and had several instances where it would limp the engine to shut off
    T-MAC likes this.
  10. Apr 22, 2023 at 10:14 AM
    #70
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I envy the ability to make a bunch more power just by plugging in this module/getting tuned. If I had one I’d struggle to resist!
    Word to the wise though, if the JB4 comes with stickers don’t put them on! Saw a dude on Facebook had 3 bearing failures on his engine at 16k miles. He had the JB4 on previously, but removed 3 months prior to the failure, and it was removed when he brought it in. They refused to cover the engine under warranty due to the JB4 sticker and it cost him 25k to repair out of pocket. Sounds like they didn’t even bother trying to dig deeper and prove it was tuned by other means. I’d be pissed.
    T-MAC likes this.
  11. Apr 22, 2023 at 7:19 PM
    #71
    pursuit2550
    pursuit2550 New Member
    Sticker or not, if they check the data log it will show up like stated by another member.
  12. Apr 22, 2023 at 8:26 PM
    #72
    chill_trd
    chill_trd New Member
    '22 TRD limited
    The dude on FB must be lying. I doubt a dealer could void a warranty because of sticker you put on your truck. Maybe you had a JB4 on your other car who knows. As it has been stated they can pull the logs and see there is something nefarious going on. a sticker aint it.
  13. Apr 23, 2023 at 4:32 AM
    #73
    Silver17
    Eastern PA
    I don’t know, I’m just relaying what he posted in hopes that no one else has the same issue. It’s clear the JB4 is on Toyotas radar if there is an engine failure. You can judge for yourself I guess.
  14. Apr 23, 2023 at 2:53 PM
    #74
    Mpage
    Mpage New Member
    Matthew
    2022 Tundra SR5
    I have eco on map 0, normal on map 2, sport map3, tow map 2. I haven't personally dipped into ethanol. I have 93 octane in abundance around me so I can get away with those map settings. Some areas a hear can only get 91.
    As far as the ethanol and why I haven't dipped into those settings. I don't know if the injectors can handle that much fuel. I do know you don't want to really push them more then 80% efficiency. The other thing that worries me is I don't know what seals Toyota has in its fuel system. Flex fuel vehicles use seals that can withstand the higher ethanol %. If the seals can't handle the ethanol I've been told it will break down the seals and creat leaks/pressure issues. Is this true? I can't 100% confirm. But it made enough sense to me to stay clear of it. I'm happy with the results I'm getting. My truck on map 2 won't pin you in the seat....but it will definitely knock you back in your seat.
    And as far as mark goes ges an enthusiastic motorhead with minimal experience. I'm not going to say I dislike him. But anything he said I would value another opinion. He has money to play with and I can judge certain things off his results.
    The BMS valves for me have been on for 3 days now. I haven't had any issues. But I am running half the set screws on higher boost. I don't believe Brenner had any extra boost. Does this play an effect? To early to tell. Tomorrow I have a 70 mile drive each way to work. I guess that will be the true test.
    T-MAC and Taikowaza[QUOTED] like this.
  15. Apr 23, 2023 at 2:59 PM
    #75
    Mpage
    Mpage New Member
    Matthew
    2022 Tundra SR5
    I want to add ECO mode I think is complete garbage on this truck. I get better fuel economy and performance on normal.
    I'm not sure if anyone else has noticed but this 10 speed transmission isn't really a ten speed. My truck will go to 9th gear no problem. Very rarely does it ever go into tenth.
    With or without a tuner. I'm in Ohio with a lot of hills/ mountains. Next week I'll be driving to Illinois for a relatives wedding. Indian has a lot of flat ground so maybe that's playing a roll. I'll make sure to reply with my results.
    I switch the truck to manual shift to try and find the gear it's in....if I go to 10 the truck doesn't always advance to 10. I've done this at 60,70, and 80. Mph. When I downshift from there it typically goes to 8 which tells me the truck was in 9. A couple times it's shifted to 9 from 10. But the rpm difference from 9 to 10 is so minimal it's not even worth complaining about.
  16. Apr 23, 2023 at 3:04 PM
    #76
    Mpage
    Mpage New Member
    Matthew
    2022 Tundra SR5
    Link to thread? I'm kinda curious to what you found
  17. Apr 23, 2023 at 5:05 PM
    #77
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Just chiming in that my experience with the ECO setting is exactly the same.
    Mpage and ryanwgregg like this.
  18. Apr 25, 2023 at 7:12 AM
    #78
    T-MAC
    T-MAC New Member
    Westernesse
    2023 Tundra
    eddiefromcali likes this.
  19. Apr 25, 2023 at 7:47 AM
    #79
    eddiefromcali
    Eddie
    100% Stock
    because he slapped them on w/o any of the vents plugged...it stalled and he didnt try plugging vents at all. The spacers are adjustable for a reason....some trucks will run fine w/o any vents plugged, some need 2 or 3 vents plugged...depends. The majority (If not all) of people who report problems, didnt try plugging until it wouldnt stall.
    I have a set and it did stall 2 times, once 35 miles after install and then again 1k miles later. This was before the 22TC08 recall which addressed the same conditions where I was stalling...once I got the updated ECU programming (7/22), it never stalled again.
  20. May 1, 2023 at 12:08 AM
    #80
    NVRsyDI
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    Wrong. I have it and friends at a local dealership. Nothing shows.
    forzamrit and BMP like this.
  21. May 1, 2023 at 12:17 AM
    #81
    NVRsyDI
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    When we bought them we were told the screws were for how much sound you wanted. More screws less sound. We were told that our truck wouldn’t without the screws. We were told it that is the loudest configuration.
    Why even have that option if it cripples the truck is the real question.
    Hardly a tool for testing out a part and getting bad information from the manufacturer.
  22. May 1, 2023 at 1:01 AM
    #82
    eddiefromcali
    Eddie
    100% Stock
    By we, you mean beta testers? Because I beta tested and was never told it was for sound.
  23. May 2, 2023 at 5:28 AM
    #83
    pursuit2550
    Wrong. Someone always has a friend of a friend. It’s called data log. The ecm will data log that the truck was boosting 30# vs 20#, timing was advanced and extra fuel was added. Regardless, you want to make your truck .1-.3 secs faster to race your shadow, than have at it. Blowing up a $50-70k truck for a few pony’s isn’t worth it to me anymore. Been there done that and got a cookie.
  24. May 2, 2023 at 7:35 AM
    #84
    mattvarnell
    This is a misleading statement. Nothing may show to the dealer, but the dealer is not who would provide authorization for an engine replacement under warranty. If you blow an engine, the data logs will be sent to Texas to the team of engineers to review before any authorization is given. While they may not see a "blinking neon sign" that a tuner or inline signal modifier was installed, they will look at timing, MAF sensor readings, boost and airflow, fuel consumption, etc. and they will be able to see that something likely was happening because the engine was operating outside the "normal parameters" of the data tables in the computer. logged boost level vs. MAF sensor readings will look funny to them.
    Jarrow, 4mm and eddiefromcali like this.
  25. May 5, 2023 at 5:56 AM
    #85
    Mpage
    Mpage New Member
    Matthew
    2022 Tundra SR5
    Update with my blowoff valve experience. I've had them on now for roughly two weeks. Two set screws in each. No issues. Im not going to remove anymore. I drove from Ohio to Illinois and back.
    Another note though I did put some Lucus synthetic oil stabilizer in with the last oil change.My mpgs were falling off on each tank slowly. My mpgs have jumped from 17mpg to just under 19mpg. I have my truck monitor each tank rather than average. My truck is pushed at 80-85mph a lot of the time. I do speed. Thought I'd share.
    eddiefromcali and iiawah808 like this.
  26. May 5, 2023 at 7:53 AM
    #86
    eddiefromcali
    Eddie
    100% Stock
    How are you liking the sound? Love my bov plates
  27. May 5, 2023 at 7:56 AM
    #87
    Mpage
    Mpage New Member
    Matthew
    2022 Tundra SR5
    I'm liking it.....it's very faint with the windows up but when I'm out playing with the windows down it makes it a lil funner. I think I have it set up now with the perfect balance for my enjoyment.
  28. May 6, 2023 at 5:42 PM
    #88
    RPKEAN
    RPKEAN New Member
    Ryan
    So is everyone’s experience just on Map 5? Or who is conservatively running it daily on just Map 2 for a non-Hybrid?
    wxman91 likes this.
  29. May 8, 2023 at 9:41 AM
    #89
    roboots21
    roboots21 New Member
    2022 MGM Tundra Limited DC
    I run Map 0 on Eco, Map 2 on Normal drive mode, and Map 3 on Sport mode. Without putting mixing to E30, I don't want to go to to any higher boosts. That being said, Map 3 on Sport mode is awesome!
    T-MAC, wxman91 and jeosbor1 like this.
  30. May 9, 2023 at 2:16 AM
    #90
    RPKEAN
    RPKEAN New Member
    Ryan
    Wait I thought Map3 required some mix of e-85?
