Jack for leveled tundra
Discussion in 'General Tundra Discussion' started by Law323, Aug 7, 2016.
  1. Aug 7, 2016 at 5:59 AM
    Law323
    Law323 [OP] it’s only weird if you make it weird
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    What kind of jack do you guys use for your leveled tundras? I tried my stock jack not too long ago and realized it wouldn't do diddly squat if I needed to change out a flat.
    Suggestions?
    ColoradoTJ and Yotalover88 like this.
  2. Aug 7, 2016 at 6:06 AM
    Yotalover88
    Yotalover88 "If it ain't broke don't fix it"
    James
    2013 white tundra
    Rhino liner, bed mounted tool box "no stripper pole" paracord wrapped oh shit handles, Lowes stair tread door seal protectors, handgun holder for my dedicated truck gun. My list of wants is much longer!
    Funny I was looking at mine as well and got a great chuckle out of it, I went ahead and threw a couple of 4x4x12 blocks in my truck box maybe it will help.
  3. Aug 7, 2016 at 6:12 AM
    IndyTundra
    IndyTundra Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    I'll be watching this thread. My floor jack works at home but I've got to get something for use if out n about.
    Yotalover88 and Law323[OP] like this.
  4. Aug 7, 2016 at 6:12 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Thought about that. Be a helluva lot cheaper that's for sure!
    Yotalover88[QUOTED] likes this.
  5. Aug 7, 2016 at 6:20 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You have a leveled tundy? My jack wouldn't hit high enough for me to get my tires off (or on for that matter) even on concrete
  6. Aug 7, 2016 at 6:26 AM
    Yotalover88
    James
    2013 white tundra
  7. Aug 7, 2016 at 6:27 AM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Yes, mine is leveled with a 2" Toytec kit but the stock jack won't work on it. I have to use my 3ton floor jack at home.
    Yotalover88 likes this.
  8. Aug 7, 2016 at 6:30 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Ohh thought you said your stock jack worked on it. Got confused for a sec lol
    IndyTundra[QUOTED] likes this.
  9. Aug 7, 2016 at 8:54 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Too bad a Hi lift doesn't have enough reach or ability to handle the weight of our pickups. I'd think a few blocks with your original jack would be the most expedient plan.
  10. Aug 7, 2016 at 9:51 AM
    trainracer
    trainracer New Member
    tractor supply has them for 33.99
  11. Aug 7, 2016 at 10:20 AM
    Hi-lift jacks are rated at 4600 lbs. Unless one is lifting up the whole tundra, you're good to go lifting one wheel off the ground. Then again, like you said, how is one going to lift the tundra?
  12. Aug 7, 2016 at 10:30 AM
    TheBeast The Beach
    I call AAA..lol
    Law323[OP] and Yotalover88 like this.
  13. Aug 7, 2016 at 10:42 AM
    Yotalover88
    James
    2013 white tundra
    I love tractor supply!
    NewImprovedRon and Law323[OP] like this.
  14. Aug 7, 2016 at 1:01 PM
    Have some treated 2x12x12 with galvanized handles screwed to sides also 3/4 treated plywood cut to that size keep in back of bed use as bases to build up to use stock jack
  15. Aug 7, 2016 at 1:53 PM
    I'm actually glad you brought this up Law. Didn't even dawn on me that maybe I should look into this after my new strut upgrade. Working on a resolution right meow.
    omaguz and Law323[QUOTED][OP] like this.
  16. Aug 7, 2016 at 1:56 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Glad you figured out this was a problem before you got in trouble out in the sticks!
    One of my first purchases after I got this truck was a new lightweight 3T "racing" floor jack made of mostly aluminum.
    I also am carrying a 5T bottle jack and some wood blocks.
    Occasionally I bring along the hi-lift which works fine with a short sling slipped through the spokes in the wheel. Once it is up high enough you can put blocks or stuff under the axle.
    Factory jacks are mostly just good for use as a paper weight.
    Test what you have at home when you are comfortable and not in a rush. It sucks to find out your stuff won't work when it is dark and you are in a ft of mud and snow!
    Law323[OP] likes this.
  17. Aug 7, 2016 at 1:59 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Only reason I even realized that was I installed my own lift. Realized pretty quick I wasn't going to be able to use my stock jack for installation (or after, for that matter) since I'm going back and forth to Memphis from BR this week, and a whole lot of nothing in between makes me want to be safer than stranded. I have 2k miles on my toyo AT's, they should be fine, but can't hurt to have some anti-Murphy!!!
  18. Aug 7, 2016 at 2:02 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Oh I've been stuck in the middle of nowhere before only because one of my lugs were stripped bare (Silverado and rusted to holy hell) not fun.
    I have noticed stock jacks are worth next to nothing even with stock height, but luckily been able to pull off stock jacks thus far in some sketch areas with the help of jack stands of course. Like I said, can't hurt to have some anti-Murphy!!
  19. Aug 8, 2016 at 5:18 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    What jack does the TRD PRO come with?
  20. Aug 8, 2016 at 5:42 AM
    I use a heavy duty floor jack at home. I've got some large wood blocks that I carry with me for the stock jack and that still kind of sucks.
  21. Aug 8, 2016 at 5:59 AM
    Maddog94
    Maddog94 New Member
    Good question! Anyone?
  22. Aug 8, 2016 at 12:48 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I am not sure but will bet double to nothing it is the same factory jack as comes in all like year tundras. POS, was out of my truck the first week.
