It took 8.75 quarts of oil!
Discussion in '2nd Gen Tundras (2007-2013)' started by bradleydavidgood, Jul 28, 2025.
  1. Jul 31, 2025 at 5:55 PM
    bradleydavidgood
    bradleydavidgood [OP] New Member
    2013 Tundra 4.6L Double Cab
    Right, that's what the dots are for, to indicate the acceptable level anywhere between them. Just like the coolant, brake, power steering reservoirs, all the same. Lower line and top line. Anywhere in between is acceptable.
    Rathesun and Leo's first like this.
  2. Jul 31, 2025 at 6:01 PM
    bradleydavidgood
  3. Jul 31, 2025 at 6:02 PM
    bradleydavidgood
    Also, I have not yet changed the PCV. I pick that up tomorrow and will install that tomorrow. So it may have an original PCV in there.
    Leo's first likes this.
  4. Aug 1, 2025 at 4:09 AM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Based on what the manual stated, the 2006 double cab 4.7 L was to be filled to the top hole on the dipstick.
    I can edit later with an exact quote.
    My problem is lack of a flat parking surface to check oil level after waiting 30 minutes. Local church parking lot is likely the best place for this but my schedule is basically "if it's not raining I'm out working." Something like "only 4% of WV is flat" doesn't help.
  5. Aug 1, 2025 at 6:33 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    What about expansion once the oil is at operating temperature?
    You better drain some out, methinks.
  6. Aug 1, 2025 at 7:24 AM
    bradleydavidgood
    Since one has to wait for it to drain down for a proper reading, and at that point it has cooled down, it is only logical that the engineers designed the dots to read while it is cold not hot.
  7. Aug 1, 2025 at 9:31 AM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Check it engine warm, idling while the tranny pump is working...just like when you are roadkill on the shoulder.
  8. Aug 1, 2025 at 4:43 PM
    tmac58star
    Disregard, check engine oil on cold engine...adjust accordingly. Above info applies to tranny fluid.
  9. Aug 3, 2025 at 4:15 PM
    Rathesun
    Rathesun New Member
    Alaska
    2013 Tundra Double-cab 5.7L engine
    My 2013 Tundra 5.7L V8 takes exactly 7.9 quarts of oil with an oil/filter change for the oil level to reach the top mark on the dipstick. So all I do now is to warm the engine for a few minutes after an oil change, turn it off, lift the dipstick, and and take about 15-20 minutes having lunch or a cup of coffee, then check the oil level. If I am on the road on a long trip and want to make sure that the oil level is good, I park off the truck, and take the same steps above.
    But now that I know that I don't have to check the oil level on the road and that my tundra is not burning or losing oil, I just add a maximum amount of 7.9 to 8 quarts of oil with an oil with filter change, start the engine, and look for any oil leaks while it runs for a few minutes.
    AZBoatHauler likes this.
  10. Aug 3, 2025 at 4:30 PM
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    An extra cup of oil will do that if total capacity is over 8 quarts? Seems miniscule compared to total amount of oil in there.
    Normal oil check procedure is engine off after warm up, wait 5 mins and check.
    MadMaxCanon likes this.
  11. Aug 3, 2025 at 5:00 PM
    AZBoatHauler
    So.Arizona
    Who said anything about an extra cup? Did you mean an extra quart?
    grave likes this.
  12. Aug 3, 2025 at 5:21 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Just measure the oil when you change it next.
    While it wont be exact since you cant get all the oil it should give you a good idea whether or not you're burning oil.
  13. Aug 3, 2025 at 8:40 PM
    Rathesun
    Rathesun New Member
    Alaska
  14. Aug 3, 2025 at 9:37 PM
    blenton
    blenton New Member
  15. Aug 4, 2025 at 12:42 PM
    Rathesun
    Rathesun New Member
    Alaska
    I see...I stand corrected.
    How much oil does the second generation 4.6 V8 motor takes with both filter and oil change? My Tundra's 5.7L motor takes less than 8 quarts. If I pour in 8 quarts it rises just a little over the top mark once the oil has warmed, and then a few hundred miles later the level drops to the top mark. Since I drive it under 2,000 miles each year, the level stays by the top mark by the time I change the oil and filter again.
    I replace the oil and filter every six months or so, once as the spring nears (by April), and once again just before winter sets in (October-November). During the winter the truck goes though hours of idling, sometimes around 2 hours per day when the temperature drops around -20 degree and colder, and also when I am taking photos of local sled-dog races or the Auroras. I assume that oil dilution during the winter is quite possible.
    blenton[QUOTED] likes this.
  16. Aug 4, 2025 at 1:21 PM
    4.6 and the 5.7 are the same motor architecture.
  17. Aug 4, 2025 at 1:21 PM
    AZBoatHauler
    So.Arizona
    5.7 is a stroked 4.6.
    KNABORES[QUOTED] likes this.
  18. Aug 4, 2025 at 1:45 PM
    EmergencyMaximum
    Wait, so that means I can get a 5.7 crankshaft and some other miscellaneous gizmos and make it into a 5.7L ?
  19. Aug 4, 2025 at 1:56 PM
    #49
    AZBoatHauler
    So.Arizona
    No - they made them so the parts aren't directly interchangeable despite using the same pistons.
  20. Aug 4, 2025 at 2:34 PM
    #50
    EmergencyMaximum
    That's a bummer.
    If there is longer stroke on 5.7l, but the block is the same, doesn't it have higher compression now, because pistons travel closer to the valves?
  21. Aug 4, 2025 at 3:18 PM
    #51
    AZBoatHauler
    So.Arizona
    If the block was the same you'd be right. But they lengthen the cylinders as well to keep compression at 10.2. Some of the Lexus 4.6 engines have a higher compression - I'm assuming they use a domed piston. Those are the premium fuel only engines.
  22. Aug 5, 2025 at 1:36 PM
    #52
    Rathesun
    Rathesun New Member
    Alaska
    Thank you for the details. I am learning new things :thumbsup:
