It costs what to recharge your A/C!!!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Anohibian, Jun 15, 2021.
  1. Jun 15, 2021 at 9:15 PM
    Anohibian
    Anohibian [OP] New Member
    Anchorage, AK
    2018 Inferno Crewmax
    This is what they are going to do. They didn’t have any refrigerant to charge the system with. I k ow there is a leak somewhere, I’m just worried where it is at and what the cost will be beyond the $1100 recharge.
  2. Jun 16, 2021 at 4:00 AM
    timsp8
    NY
    Do you have an auto parts store where you can buy some refrigerant and try it yourself? Then you can check it for leaks or see if it all disappears again for less than $100.
  3. Jun 16, 2021 at 5:39 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Yes, they are found in pairs throughout the united states. Very prolific little buggers they are.
    Wear long pants when in their area as they bite and dig in like tics.
  4. Jun 17, 2021 at 7:50 AM
    Shamrock92
    Shamrock92 New Member
    I remember when Mercedes (and Dodge) began running out 1234 a few years back - first front end hit I dealt with on a Dart and they told me a recharge was like $1900 I was like WTF?!? I wouldn’t pay that for the car - total it.
    Stuff was stupid pricey due to a lack of supply - but now it’s common on new cars - should be available.
    I know talking to techs they say it last half as long at best - but 2018 is too soon to need a full replacement. Some loss - sure - but total is a leak.
  5. Jun 17, 2021 at 8:45 AM
    Anohibian
    Anchorage, AK
    It is more common and better availability now, but still around $100 a pound. Plus since I live in Alaska, and the stuff is considered flammable, hello Hazmat shipping fees. Did some research and it looks like 18’ is when they made the switch from 134a. Checked all the auto parts stores in my area and no one has any in stock. Makes me wish I would have gone with the CPO 2017 that was on the lot when I bought this one. Oh well hindsight is 20/20 and all.
  6. Jun 17, 2021 at 9:50 AM
    Rocko9999
    Rocko9999 New Member
    Great information. Stupid question-Is it possible to have a system lose freon and not have a leak?
  7. Jun 17, 2021 at 6:58 PM
    CENAIR
    CENAIR New Member
    PAUL
    No and if it loses the charge there is a leak some place and must be found and fixed to repair it correctly. Some leaks though are incredibly small and hard to find but typically at the crimp connector on the hoses, flare connectors and compressor shaft seal, another spot can be the service ports and kind of like car tire air valve to inflate the tire, the ports on the ac have caps and o-ring and can leak too.
  8. Jun 17, 2021 at 7:22 PM
    Anohibian
    Anchorage, AK
    And that is my worry. A small leak that isn’t going to be found until at least one recharge. Or the compressor is having issues. I’m wondering how much I’m going to be in for to get this all fixed.
  9. Jun 17, 2021 at 7:33 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    I'd just refill it with r134 if it was me after I found the leak. Pull a vacuum and put in new oil.
    I'm not sure if there is a difference is between the two refridgerants though. I guess you would have to cross reference some part numbers with an older model truck.
  10. Jun 18, 2021 at 8:29 AM
    Rocko9999
    Why? I competent shop should be able to detect a leak. It may not be as small as you think.
  11. Jun 18, 2021 at 8:34 AM
    Rocko9999
    That is logical. Same issue with a Ford Escape I had that consumed coolant. They couldn't find a leak-it wasn't leaking, yet I needed to add 8oz of coolant every 5-7K miles. Dealer said it's just normal. Engines don't consume coolant normally. Turns out it was hairline cracks in the head. Not enough to blow clouds, set check engine light or even run poorly. Many 1.6 ecoboost owners had this. The good dealers would do overnight leak down test and find cracks, replace engine, but most just topped off and sent them on their way until out of warranty.
  12. Jun 18, 2021 at 8:36 AM
    Anohibian
    Anchorage, AK
    The only shop in my area that will work on it is the Toyota dealer. The next closest one 500 miles away and owned by the same dealership. The other car mechanics in my area don’t do work with the new refrigerant. They spent three hours and said there was no leak. I’m hoping when they pressurize the system the leak shows and it’s an easy fix. I plan on trying to be back in the shop when the run the sniffer over the system. I also want to have them replace the valve core on the fill port and the cap for the port. We will see in a few weeks what happens.
    Rocko9999[QUOTED] likes this.
  13. Jun 18, 2021 at 4:25 PM
    CENAIR
    CENAIR New Member
    PAUL
    Like post# 40 said may not be that small of a leak, and just find a good shop that has. good electronic leak detectors and should be easy to find, and pressurize system with nitrogen to max test pressure if needed to find the leak, evacuate the system to 500 microns after repairing the leak, let it sit for one hour to ensure no rise of more 100 microns, and then recharge it. replacing the cap and seals, as well as the service valve core vales is always a good idea.
    Leaks at the compressor seal shaft is common and usually there will be a small amount of oil you can fell under the shaft if the seal is leaking with your finger, as I said before crimp connections on hoses and shaft seal at compressor are most common.
    R65 and plumber802 like this.
  14. Jun 18, 2021 at 5:02 PM
    Anohibian
    Anchorage, AK
    I hope that the Toyota dealer has good equipment, as I have said they are my only option. I have a hard time believing it is a large leak if drawing a vacuum on it showed it was a solid system. The more I think about it and read about the refrigerant, in cold weather (i.e. winter in Alaska) it is known that the refrigerant can condense enough that standard atmospheric pressure will overcome the pressure inside the system and enter through the low side service port. My truck lives outside and over the past two winters has seen several weeks where the high was -25. I understand that they have also changed the service cap style. I need to check and see if I have a bad cap.
  15. Jun 19, 2021 at 4:36 PM
    Anohibian
    Anchorage, AK
    Well got board today and decided to look over the system and check the cap and valve core. Found out the system had pressure it in when I depressed the valve core. Covered it with some spit and tried with soapy water. No leakage through the valve core. If the system had pressure I think they may have checked it with nitrogen. I’ll have to confirm with the services department. What ever escaped didn’t have a smell so I’m inclined to think it wasn’t refrigerant, that abs the dealer said I had none in the system. Now I’m getting worried about what the issue is.
  16. Jul 1, 2021 at 3:27 PM
    Anohibian
    Anchorage, AK
    Well the dealership said the still couldn’t find a leak after they charged the system. It is at least blowing very cold. After they finished with it, I went to the auto part store and pick up a can of stop leak and put it in. Now just have to sit back and wait to see if it stops working again.
  17. Jul 2, 2021 at 7:33 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I thought 2019 was the first year model for yf-1234 refrigerant in Tundras?
    Out of curiosity, does your truck have an ATF cooler (top half of the AC condenser) and yf1234 refrigerant?
    One of the speculations for removal of the ATF cooler beginning with 2019 models was the larger condenser was required for the yf1234 systems.
  18. Jul 2, 2021 at 8:09 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Your truck will cycle the AC in any position that uses defrost.
    Leo's first and 2mchfun like this.
  19. Jul 2, 2021 at 9:40 AM
    #49
    Anohibian
    Anchorage, AK
    Not sure about the compressor? I honestly wouldn’t even know what to look for to confirm if it has an ATF cooler. Is that the transmission cooler? If so yes I do have one.
  20. Jul 2, 2021 at 9:54 AM
    #50
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Didn't mention a compressor....
    Yes, ATF (automatic transmission fluid) cooler is the transmission cooler. If you peek through the grill, you can see the lines attached on the upper passenger side of the ac condenser. It is a combined unit -- the top third is the transmission cooler, bottom portion is the ac condenser. On my 2019, the window sticker stated that the truck was equipped with a transmission cooler, but that isn't accurate as we have found out.
    Is there a sticker on the underside of your hood or top of your grille that states yf1234 refrigerant?
    If you have both, you may have a late 2018 production truck.
  21. Jul 2, 2021 at 10:00 AM
    #51
    Anohibian
    Anchorage, AK
    I meant condensor. Yes I have a ATF cooler and the sticker does state 1234yf. Also the low pressure port for 1234yf is larger than the 134 port so you can’t hook up the wrong connector.
  22. Jul 2, 2021 at 10:16 AM
    #52
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Well that just thru a monkey wrench in the assumption that yf1234 needed a larger condenser. I guess Toyota removed the transmission cooler on 2019+ trucks for cost savings.
    Good luck with your AC -- maybe the stop leak that you added will prevent it from leaking out again. It's a shame that stuff costs so much. I wonder if you could get Toyota involved to cover it? Depends on the dealer or service advisor. The truck is new enough that they might, even if slightly out of warranty coverage.
  23. Jul 2, 2021 at 10:28 AM
    #53
    Anohibian
    Anchorage, AK
    Well cost ended up being 650. They may give miss quoted me to begin with, or didn’t charge me right. Service manger double checked with parts to make sure the billed it out. They said they did and he rang me up before they could say anything else.
  24. Jul 2, 2021 at 10:41 AM
    #54
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd
    If a feller is gonna have problems getting his AC serviced... Alaska would be the place. Haha.
    Seriously though, are there many experience AC guys in Alaska?
  25. Jul 2, 2021 at 10:49 AM
    #55
    Anohibian
    Anchorage, AK
    Yes, just not a lot dealing with the new refrigerant. That should be changing since all model 21 and newer cars are required to use 1234yf.
