It’s not a build, if it’s just a bunch of “mods”right?!
Discussion in '2.5 Gen Builds (2014-2021)' started by biebs96, Apr 21, 2020.
  1. May 1, 2021 at 11:20 AM
    #61
    biebs96
    biebs96 [OP] my other truck is a big brown truck
    PA
    Added a child mirror in the small sunglasses flip down holder
  2. May 1, 2021 at 11:38 AM
    #62
    biebs96
    PA
    Added a matching 285/75/18 full size spare.
    Tire is used, but the plan is to never have to use it.
    Fits well under the truck after removing the two tabs.
  3. Jun 23, 2021 at 6:50 PM
    #63
    biebs96
    PA
    Stumbled upon a new set of gloss black handles...
    One replaced, one original (obviously too excited to keep the camera straight)...
    Both done...
    RobertD, bulldog93, WVI and 4 others like this.
  4. Jul 17, 2021 at 4:05 PM
    #64
    biebs96
    PA
    FINALLY, the proud owner of a DD exhaust!!
    Can not believe I waited three tundras and almost 10 years to install one.
    RobertD, bulldog93, WVI and 5 others like this.
  5. Jul 25, 2021 at 5:14 PM
    #65
    biebs96
    PA
    Helmholtz resonator installed. Absolutely thrilled with the interior sound, and lack of noise complaints from the family.
    RobertD and J&ATundra like this.
  6. Aug 12, 2021 at 7:00 PM
    #66
    Rippyro
    Rippyro New Member
    2014 Tundra 1794 - Sunset Mica Bronze
    Are there any mods you haven't done to your truck?? Good lord lol
    biebs96[OP] likes this.
  7. Aug 12, 2021 at 7:46 PM
    #67
    biebs96
    PA
    I will take that as a compliment. Thank you!
    Rippyro[QUOTED] likes this.
  8. Aug 22, 2021 at 4:01 PM
    #68
    biebs96
    PA
    Found a tailpipe tip to compliment the BAM system.
    BlueRibbon4x4 and Fotnot like this.
  9. Aug 22, 2021 at 4:02 PM
    #69
    biebs96
    PA
    Essential bottle opener
    RobertD, Fotnot and RRR1C0 like this.
  10. Aug 22, 2021 at 4:37 PM
    #70
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Only thing I think your missing is the Pedal Commander and the Stillen CAI :spending:
  11. Aug 23, 2021 at 3:08 PM
    #71
    KatoK
    KatoK 2021 Super White 4X4 TRD Pro
    Jeff
    N. Texas
    Great job on the mods. Can you provide some more details on the DIY box? I had one on a previous truck and this looks easy to do vs $250
  12. Aug 23, 2021 at 3:32 PM
    #72
    biebs96
    PA
    I used two L brackets that attached to the forward most tie down system bolts in the bedside.
    cut the board to length (had to angle the back corners to avoid pinching the cover’s drain hoses).
    used a third L bracket to attach to the center tie down bolt location.
    the front rubber seal is from an old tonneau cover gasket, but I’d imagine any type of flexible gasket would work. It’s simply attached by heavy duty staples.
    Hope this helps. I agree with you regarding the cost of the bak box. I can store quite a lot in my $12 box.
    KatoK[QUOTED] likes this.
  13. Sep 6, 2021 at 5:58 PM
    #73
    biebs96
    PA
    Installed the @Puppypunter DIR (disable in reverse) harness.
    (stolen photo of his product)
    No photos of the actual install as it was super easy and took longer to unbox it, then it did to install it.
    The rear camera clarity at night is significally improved without the license plate lights shining up into the camera.
    BlueRibbon4x4, bulldog93, WVI and 3 others like this.
  14. Sep 14, 2021 at 7:11 PM
    #74
    biebs96
    PA
    Relocated my rear window switch, thanks to @abomb60 printed panel.
    Lots of sanding required, but the end result is worth it.
    Panel is painted the same satin black as the gear selector and cup holder trims.
    Puts the switches I use most in a very accessible location. Right at my finger tips.
    bulldog93, Pbed85, Cruzer and 4 others like this.
  15. Oct 13, 2021 at 7:48 AM
    #75
    ToyotaG
    ToyotaG New Member
    Going to grab me some 285/75/18's after reading your thread. Just got me some 5100s and glad the tires first no problem with middle settings. Ty for this
  16. Oct 13, 2021 at 10:47 AM
    #76
    biebs96
    PA
    no problem! Thanks for sharing!
  17. Nov 2, 2021 at 7:45 AM
    #77
    biebs96
    PA
    Added color matched vinyl to the grill letters. Very pleased with the subtle pop it gives.
    RobertD, bulldog93, TunsofFon and 2 others like this.
  18. Nov 18, 2021 at 11:38 AM
    #78
    biebs96
    PA
    Removed the mesh guts of the throttle body gasket
    sooo long engine whistle!
  19. Nov 18, 2021 at 7:18 PM
    #79
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    That’s why the engine whistles under load??
  20. Nov 19, 2021 at 3:09 AM
    #80
    biebs96
    PA
    that is correct. It is located behind the throttle body. 4 10mm and one clamp is all it takes to access it.
    bulldog93 likes this.
  21. Dec 4, 2021 at 1:20 PM
    #81
    biebs96
    PA
    Added some patches to the inside of the rear seat armrest area.
    RobertD and Fotnot like this.
  22. Dec 4, 2021 at 1:23 PM
    #82
    biebs96
    PA
    Played with the foam cannon today!
  23. Dec 4, 2021 at 5:18 PM
    #83
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    Great build. Did you use a positap to tap into the footwell light wire? I want to do LEDs for the running boards.
  24. Dec 4, 2021 at 5:25 PM
    #84
    biebs96
    PA
    thank you!
    I could have, but since I added footwell lights as well, I simply cut the light socket off of the pair of wires running to it.
    TunsofFon[QUOTED] likes this.
  25. Dec 15, 2021 at 3:08 PM
    #85
    biebs96
    PA
    Toggle switch added next to console rear power outlet. Power is taken from rear cigarette power.
    Switch is connected to two small dark orange LEDs mounted in the bottom of the console facing outward towards the doors.
    The goal is to add ambient lighting for the rear passengers without it effecting the driver (me).
    This photo is taken facing the floor. The bulb can be seen in the top left. On the right side is the shadow it casts across the floor and onto the door panels.
    Provides just enough light for rear passengers/kiddos when traveling in the dark.
  26. Dec 15, 2021 at 3:28 PM
    #86
    Taco-Spike
    Two Trucks
    This is awesome.
    I have the a plan similar to this. Center front cup holder areas. Never thought of this area but very useful, I might as well since I had to buy LED’s and the 5mm holders by the dozen, might as well use them.
    biebs96[QUOTED][OP] likes this.
  27. Dec 15, 2021 at 3:29 PM
    #87
    biebs96
    PA
    this is the exact reason I did it. I had extra LEDs from another project and the switch was from an old stereo piece. So this was essentially a free mod.
    Taco-Spike[QUOTED] likes this.
  28. Dec 15, 2021 at 3:40 PM
    #88
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Looks great. I debated that Bronze but ended up in the newer Mesquite color.
  29. Dec 15, 2021 at 9:38 PM
    #89
    twintundra31719
    twintundra31719 New Member
    NV
    Great work OP!
  30. Dec 16, 2021 at 4:03 AM
    #90
    biebs96
    PA
    Thanks!
