Issues with 2008 SR5 5.8 4x4?
Discussion in '2nd Gen Tundras (2007-2013)' started by rsttoole, Feb 19, 2020.
  1. Feb 19, 2020 at 8:22 PM
    rsttoole
    rsttoole [OP] New Member
    Randy
    Boise
    2008 Tundra Limited
    Considering buying a 2008 Tundra SR5 4x4 with the 5.8. Has 135K miles. What problems should I look for? What does it cost for a full inspection by a shop before buying?
  2. Feb 20, 2020 at 12:26 PM
    08crewmax
    08crewmax New Member
    CA
    ‘08 Pyrite Mica Crewmax Limited
    Bed rust and cam tower leaks
  3. Feb 20, 2020 at 1:04 PM
    Get the 5.7...
  4. Feb 20, 2020 at 1:30 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    X2 on the bed rust.
  5. Feb 20, 2020 at 3:20 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    PPI are usually around the $100 range
    08 with 135k. Expect to overhaul all the maintenance items, or use it to your bargaining favor. The 2 big items were mentioned above.
    I picked up my 08 with 108k on the clock. Spent the 1st month rehabbing it before tasteful mods. Only problems I had were leaky rear struts, cut reverse bulb, double stacked oil plug gasket, squeaky belt tensioner.
  6. Feb 29, 2020 at 10:21 AM
    Cjcanu01
    Cjcanu01 New Member
    Look for perforations on truck frame and the bed. Especially the cross support members attached to bottom side of the bed. Be aware that the support bed members are very difficult to view, even if the truck is on a lift. If these members are severely corroded you’ll see rust coming up through the bed. Remove plastic bed liner if equipped. If equipped with Line-x or equivalent, inspect thoroughly!9D42B906-C111-4E98-982F-937AC60B2E16.jpg
