Issues getting right fit "short" antenna for 17 Tundra?
Discussion in '2.5 Gen Tundras (2014-2021)' started by mdh1470, Jul 6, 2020.
  1. Jul 6, 2020 at 12:17 PM
    mdh1470
    mdh1470 [OP] New Member
    Tennessee
    2017 Midnight Black Mettalic Tundra Platinum CrewMax 4x4 5.7L V8
    LED interior/ground lights, 3" Leveling Kit, 20" Fuel Rims, 33/12.5/20 Nitto Ridge Grapplers, Hard Tri fold Tonneau Cover, Rhino Linings Spray-in Bed Liner, 8" SS BAMuffler
    I've ordered 2 different "short" antennas. Both of them did not have long enough thread to screw down into the antenna base through the rubber housing. Both claimed they were compatible with 2017 Tundras. The 2nd one was even from Ronin Factory (bullet antenna). The threaded bolt is not long enough. Anyone else have this issue with ordering "short" antennas that claim to be compatible with 2017 Tundras?
  2. Jul 7, 2020 at 6:28 AM
    nodak67
    nodak67 New Member
    JR
    this is what i use, antenna source
    tightywhitey and reneaux like this.
  3. Jul 7, 2020 at 6:38 AM
    nodak67
    nodak67 New Member
    JR
    forgot to add, i went with a 3" or 4" antenna and the reception was dam horrible even in town less than 5 miles from the tower. it looked great but that was about it.
  4. Jul 9, 2020 at 4:01 AM
    nodak67
    nodak67 New Member
    JR
    here is a pic of it installed .....
    mdh1470[OP] likes this.
  5. Jul 14, 2020 at 5:06 AM
    mdh1470
    Tennessee
    I keep hearing reception is horrible with any short antenna. Anyone have experience with a short antenna that does get good reception? I live in the East Tennessee area, lots of hilly/mountainous terrain. I need something that picks up pretty good. Are the copper with rubber coating any better?
  6. Jul 14, 2020 at 5:30 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Antenna reception is not Rocket Surgery.
    The more metal the better the reception.
    Hol Milk and Jaypown like this.
  7. Jul 14, 2020 at 11:12 AM
    nodak67
    nodak67 New Member
    JR
    not always the case. most FM antenna are quarter length of the wave length and they base it on the 100mhz spot on the FM dial since its about mid point in the full FM band.
    which is why most old time antenna are around 31-32 in in length.
  8. Jul 14, 2020 at 12:35 PM
    ezdog
    ezdog New Member
    Gateway To The West
    And all seem to work better than the Shorty for me?
  9. Jul 19, 2020 at 1:02 PM
    KneeYa
    KneeYa New Member
    Give this one a try. Put this on my 18 CM. No issues with reception, live in Houston but have been in secluded areas with no problems.
    https://www.amazon.com/gp/product/B0721Z7YV8/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1
    mdh1470[QUOTED][OP] likes this.
  10. Jul 19, 2020 at 2:36 PM
  11. Jul 20, 2020 at 2:53 PM
    falcon_bartow
    falcon_bartow New Member
    I use the original stubby from Craven Speed. Works great and I've had one on a Wrangler, CR-V, Sienna, Tacoma and the Tundra.
  12. Apr 19, 2023 at 5:49 AM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    I'm looking for an antenna that is right around cab height so about 24 in and can't seem to find one. They're all between six and 17 inches. I just needed a little shorter than the factory one so it clears the garage
  13. Apr 19, 2023 at 6:10 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    It actually is when you get into the weeds of it all.
    Anyways, per google's more simple explanation -
    To calculate the effective length of the antenna , the formula λ= v/ f must be used . The Greek lowercase letter lambda ( λ) is used to denote wavelength . The wavelength is calculated by dividing the phase velocity of the wave (v) - the speed of light 300,000. km/s (299,792,458 meters per second) by the frequency expressed in MHz (f). The result is obtained in meters. For example, for a frequency of 145 MHz, the length of the antenna will be 2.06 m.
    I have a small antenna but it's just for show. I don't use the radio. If I did I would never of replaced my OEM one.
  14. Apr 19, 2023 at 6:18 AM
    SPOirish28
    SPOirish28 New Member
    Ontario, Canada
    2014 SSM SR5 DC
    Satin black roof, 18” KO2’s, satin black powder coated steel rims, tri fold tonneau cover. Led lights interior, exterior. Trd pro grill. 13” ryonnair antenna. OEM LED headlights.
    I got a 13” Rydonair antenna from Amazon. It came with a few thread adapters to make it work with the stock mount. Installed in 60 seconds. Sirius xm is clear as day using it.
  15. Apr 19, 2023 at 6:33 AM
    1UP
    1UP Truck Gang
    Sirius XM uses a different antenna that lives in your shark fin or the black bump towards the front of your roof. It receives its signal from a satellite. Like your GPS.
  16. Apr 19, 2023 at 6:35 AM
    SPOirish28
    Ontario, Canada
    2014 SSM SR5 DC
    That makes sense, I do have that black bump on the roof. I didn’t notice any change with fm radio either, still sounds good
  17. Apr 19, 2023 at 6:35 AM
    FO LO
    FO LO New Member
    Did you do any FM comparison to the factory whip
  18. Apr 19, 2023 at 6:37 AM
    FO LO
    FO LO New Member
    And yes I use FM radio and yes this is the great depression
  19. Apr 19, 2023 at 8:15 AM
    SPOirish28
    Ontario, Canada
    2014 SSM SR5 DC
    Yeah it sounds the same. I do most of my driving on the outskirts of a big city and still get good reception.
    FO LO[QUOTED] likes this.
