Issues Already
Discussion in '1st Gen Tundras (2000-2006)' started by darrylt, May 8, 2017.
  1. May 8, 2017 at 7:53 AM
    darrylt
    darrylt [OP] Making America Great Since 1948
    Chesapeake, Virginia
    2017 TRD 4X4 DC
    TRD CAI, Trifold Tonneau Cover Steelcraft Side Steps
    Recently bought a 2001.. took it for an alignment this morning and turns out that the left side control arm bushings are bad, frame rot starting near rear leaf spring mount points and signs of rack and pinion shifting (whatever that is). It only has 110k on it. I guess age matters more. So much for the new radio, backup camera and tow package. Anyone else had these problems?
  2. May 8, 2017 at 7:56 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO. Sorry that you have issues with your used truck. I'm sure someone with that same year or mileage will have an opinion on this.
  3. May 8, 2017 at 8:19 AM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    Hi darryl, welcome from CO. I I can't speak to the rust. Did the truck come from up north? If the rack and pinion bushings haven't been replaced, do it and use the polyurethane bushings. They are about $30 and will take approx an hour to replace. I have a 2004 and have replaced the rack and pinion bushings 2x since 2004 when I bought it new and it gets used offroad a lot. I have a 190k miles on mine. It will be a night and day difference in handling once you get the UCA bushings replaced as well ;)
    tomsinamerica likes this.
  4. May 8, 2017 at 8:22 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    sorry... by the sound of it though, if the rust is fixable, the rest shouldn't be too bad.
    For the steering rack, if it's anything like my buddy's 4runner, the rubber bushings had just corroded, the replacement pack was only $20 or so and it wasn't that hard to do. It tightened up his steering quite a bit after that - he also replaced with polyurethane bushings instead of rubber.
    For control arm bushings - maybe this is karma's way of telling you that you should upgrade your control arms to allow you to do a bigger lift later on? Do it right, do it once and all that....
    As far as rust - I swear by POR15 - just don't get it on anything you don't want to be black for a very long time, including your hands. If the rust you have isn't structurally damaging, scrub it with a wire brush and then POR15 over the top. If it is structural, frames aren't as bad to repair as you'd think. For me, they're beyond my welding ability as I suuuuck at welding upside down. On my buddy's 4R, he had some severe rot in the back section of the frame - like, you can poke your finger through the bad spots... for $700, he had new metal welded in and strengthened trailing arm mounts.
    Best of luck to you
    TheBeast likes this.
  5. May 8, 2017 at 8:52 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. POR 15 is great for rust.
    Thegr8punkin likes this.
  6. May 8, 2017 at 9:50 AM
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Any chance you could take some pictures of the rust
