Issue Refueling
Discussion in '2.5 Gen Tundras (2014-2021)' started by big_jarv, Nov 26, 2017.
  1. Nov 19, 2019 at 7:24 PM
    15whtrd
    15whtrd Mr. Blonde
    Mine has started to do it. I have to have it on the first click of the nozzle and with the handle angled towards the gas door. I may have to take it in.
  2. Nov 19, 2019 at 7:29 PM
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    My 16 is doing this also. About every other fill up
  3. Mar 16, 2020 at 10:49 PM
    Tundra174x4
    Tundra174x4 New Member
    Cody
    2017 tundra sr5 trd off-road 4x4
    my tank is getting replaced, the tech could not give me a straight answer of what caused it.
  4. Mar 17, 2020 at 12:27 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Notice the incline (if any) at the pumps.
    If pumping on one side of the pumps gives trouble, then try pumping with the vehicle 180 degrees around the other side of pump.
    I've noticed pumping with the inlet on the 'higher' side (of incline) leads to better/faster fueling. Just a though....
  5. May 5, 2020 at 10:26 PM
    typeone
    typeone about time I realized you could change this...
    Zach
    2016 MG Tundra CM
    ICON/Method/BFG
    Hate to revive, but mine just started doing this as well. 2016. Crewmax. 38 gallon.
    couldn’t get half a second at 3 different pumps today. She’s at the dealer now I’ll hear back tomorrow. 54k miles. Def no warranty. I also have a gas tank skid on there from rci and I know they’re gonna say something lol.
  6. May 6, 2020 at 5:35 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Crap. That sucks. When you would refuel prior to this, did you continue to top off after the 1st click when it was full? This seems to be the common theme when this happens.
  7. May 6, 2020 at 9:46 AM
    typeone
    Zach
    2016 MG Tundra CM
    ICON/Method/BFG
    Never topped off once. In any car. Always told not too
  8. May 6, 2020 at 10:06 AM
    typeone
    Zach
    2016 MG Tundra CM
    ICON/Method/BFG
    Spoke with Toyota. They warrantied the whole system. Sweeet
    Cpl_Punishment and WFD473 like this.
  9. Jun 4, 2021 at 3:03 PM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Bump an old thread:
    My truck had the same issue, found this thread and decided to give warranty a try. Fell under the emission warranty and got my tank replaced!
    Never got a straight answer as to what caused it. Caught a glimpse at the retail costs as was just over $2650 if I saw correctly.
    2016 5.7 SR5 with 38 gallon tank.
    15whtrd likes this.
  10. Jan 16, 2024 at 8:37 AM
    Ace1699
    Ace1699 New Member
    Miami, FL
    2020 Crewmax SR5 Tundra
    Hello everyone! I just experienced the same issue with my 2020. Tried multiple gas pumps at different locations… nothing. However, I used a 5 gallon jug to add some fuel manually (just to make it to the dealership), and when the diagnostic technician from Toyota tried fueling he didn’t encounter any problems. My skeptic personality didn’t want to believe them so I went picked up my truck and tried fueling again… and of course no more issue…..
    So just from my personal experience, try manually fueling with a gasoline jug( 5-10 gallons), that may just be what you need to reset or solve whatever is causing the gas pump ordeal! Good luck.
    WFD473 likes this.
  11. Jan 16, 2024 at 9:01 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Roll over valve at the top of the tank/ bottom of the filler neck. This is on a single sided hinge and when the fuel moves in the tank it sometimes causes it to close the door. A new tank doesn't solve the problem since the its the same.
    Ace1699 and WFD473 like this.
