Issue...possible transmission
Discussion in '2nd Gen Tundras (2007-2013)' started by yup79, Jan 9, 2017.
  1. Oct 3, 2017 at 7:02 AM
    sawee
    sawee New Member
    Stan
    2012 Toyota Tundra Grade 4.7L V8 4x4 (Red)
    Westin Bull Bar; Tyger side steps; Atoto Double Din Android Head unit; Rear Back up cam, Wheel Skins
    So what did you find out? I recently purchased a used 2012 Tundra Grade to use as a second 4x4 in winter and it just started the Rumble Strip or Shudder.
  2. Oct 8, 2017 at 10:15 AM
    ADogNamedThunder
    ADogNamedThunder New Member
    2007 Toyota Tundra 4.7L
    I had my transmission rebuilt and it came back with a kick to changing gears but no shuttering. I sent it back to the place that rebuilt it and they rebuilt it 2 more times and then replaced the computer in the truck with a brand new one and that did the trick. No problems since.
  3. Aug 28, 2019 at 9:20 PM
    TalleyHo
    TalleyHo New Member
    2011 Tundra SR5
    How did they figure out it was the computer causing the kick? Could that have been the initial/only problem?
  4. Aug 29, 2019 at 4:47 AM
    Dr_Al
    Dr_Al New Member
    Al
    Toyota has a recall for the torque converter on the '07 and '08s. It has something to do with when it goes in or out of lock up mode (can't remember which). It happens in 4th, 5th, and 6th gears. Usually it's noticed around 30 to 40 mph when light throttle is applied. They redesigned it and replaced it on a number of trucks. I doubt it's still active. You can test it by moving the shift lever to the manual shift mode.
    Rex Kramer likes this.
  5. Sep 5, 2019 at 12:25 PM
    jboyle2001
    jboyle2001 New Member
    My 09 Tundra (base) is doing this. What is the fix; a new torque converter?
  6. Sep 6, 2019 at 1:59 PM
    mike8427
    mike8427 New Member
    Michael
    2010 Tundra
    None
    Think I have the same issue. Mine is not routine, only every once in a while. It happens when down shifting from 5th to 4th, usually when climbing a hill. I haven't been able to find any good repairs, just going to ride it until failure. I have about 117K miles and do light towing occasionally. I did a flush at 90K and no improvements. Looks just like a defect, but not really common enough to make a recall. Toyota are good but aren't perfect I guess.
    I also really want to re-program my tranny. The computer downshifts too easily downhill (to assist in slowing the truck) and I would rather it not downshift except in tow/mode.
  7. Sep 7, 2019 at 12:30 PM
    TalleyHo
    TalleyHo New Member
    2011 Tundra SR5
    In my particular case, changing the fluid only lightened my wallet. The slippage continued. I took it to a local transmission shop, and my wallet got a LOT lighter. But, the transmission was completely rebuilt - new everything.
    From what I was told, the torque converter essentially died, and the shards of metal trashed the valve body. At least I don't have to worry about the transmission for 3/36 now.
    This was at 135k.
  8. Sep 7, 2019 at 2:28 PM
    Dr_Al
    Dr_Al New Member
    Al
    There's a test for the torque converter but I think the easiest test is to just keep your hand on the shift lever. As soon as it starts to vibrate shift to manual sift mode. This will cancel the lock up feature of the TC and should stop the shutter. I think if you let it go on long enough you'll do damage to the transmission. I don't think there's any other option than to replace the TC. If it was me I wouldn't wait too long. There's a filter for the fluid going to the TC but not one after it and before the valve body. So if the trans goes the particles from it are going to the bottom of the oil pan. If the TC goes the particles are going to be under pressure and pushed right to the transmission.
  9. Dec 2, 2019 at 8:02 AM
    GerTundra
    GerTundra New Member
    JB
    Nova Scotia
    2012 DC RWD
    None
    Hi. Do you have any details on the torque converter test, or where I could find information on it?
    Thanks
    jb
  10. Dec 3, 2019 at 9:21 AM
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    Fwiw, I had this same problem with my tranny on the Camry. There was a recall or bulletin a couple years ago due to the TC shuddering. I had no problem but took it in to have the computer flasheD anyway. Thank god I did because the period to get this flash eventually expired and I came down with the shudders around this speed a year later. I took it in and the dealer said it was a good thing I did the flash because of I didn’t, the cost would be on me to replace the TC. They did the whole job for free. It sounds like this issue goes beyond tundras.
    edit: I forgot the reason I brought this up. I noticed I could get the shuddering to go away by giving it more gas and powering through it. It would only happen randomly, but I noticed it would happen when I accelerated gently.
  11. Dec 3, 2019 at 1:11 PM
    Dr_Al
    Dr_Al New Member
    Al
  12. Mar 16, 2020 at 7:42 AM
    PissedTundraOwner
    PissedTundraOwner New Member
    My 2006 Tundra has shudder UNLESS I disable the OD button on stalk. No help from the dealer, freaking dealer no longer employs a transmission specialist..just swaps out transmissions. Calls to Toyota responds like a deers in headlights. My truck runs great with only 78k original miles but thinking of trading in on another truck, but not a toyota, as dealers cannot diagnose transmission issues. My dealers are 90 miles apart and have been nothing but trouble on past issues. After reading through several forums, the OP disappears or the problem are from A to Z..pick one. So, I can have the Converter test made and take my chances with third party transmissions or trade in. Any dealers still employ full service shops?
  13. Mar 16, 2020 at 8:26 AM
    SouthWestGA
    SouthWestGA New Member
    When was the last transmission service done?
    Maybe a complete drain and fill service with lube guard would help?
  14. Mar 16, 2020 at 10:23 AM
    PissedTundraOwner
    Thanks!
    Lol, my 06 Tundra Maintenance guide: Check at specific intervals. I haven't found one yet...
    After the virus passes, and if still alive, I'll get a drain and fill and get check diagnostics to look for codes. For now, OD off until at highway speeds.
    Cheers
  15. Mar 17, 2020 at 2:04 PM
    Dr. Goesinya
    Dr. Goesinya New Member
    2011 Tundra 4x4 Crew Max
    N/A
    How much did it cost to replace the computer?
  16. Mar 18, 2020 at 10:44 AM
    PissedTundraOwner
    Nothing diagnosed or replaced at this time...
  17. Jul 27, 2020 at 3:25 PM
    FLTundra33
    FLTundra33 New Member
    Anyone figure out the torque converter issue? I just purchased an 06 dbl cab. Has the vibration at 35-45 mph. I do the same thing as pissedtundra and drive it around with O/D off (does not give me and issue at all with O/D off but can feel the truck struggles to find a gear). Going to get the trans flushed this Wednesday to see if that helps. I’ve read the flush helps out with some and also read that it does nothing.... only way to find out is get it done
  18. Sep 7, 2020 at 8:55 AM
    PissedTundraOwner
    FLTundra33[QUOTED] likes this.
  19. Sep 7, 2020 at 12:56 PM
    #49
    FLTundra33
    Had the transmission flushed with the Toyota WS fluid and it still has the vibration issue. :notsure:
  20. Sep 8, 2020 at 5:23 PM
    #50
    PissedTundraOwner
    Thanks for the reply, sorry flush did not help you. Ok, yours is the third flush with no results and one guy who had his rebuilt 3 times but fixed with a new computer. I have a little Scangauge but no codes thrown. I'm going to wait a bit more to see what shakes out or luck out to find someone who can properly diagnose it. This site says 2012 the worst model for anyone wanting to trade in: https://www.motorbiscuit.com/the-worst-toyota-tundra-model-year-you-should-never-buy/
  21. Sep 8, 2020 at 6:18 PM
    #51
    FLTundra33
    One guy had his fixed by replacing a computer in his truck? What computer did he have replaced? Do you know how much it was?
    My carrier bearing was bad when I bought it so I replaced it. Had it replaced it two more times after initial replacement(all within 3 months). I don’t know if it has to do with my transmission shuddering and causing it to fail? I know the shudder has to do with the transmission though cus as soon as you hit the o/d off button it goes away. If you find a fix let me know and I’ll do the same
  22. Sep 8, 2020 at 6:35 PM
    #52
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  23. Sep 9, 2020 at 8:45 AM
    #53
    FLTundra33
    What exactly is this this computer upgrade doing? Is it something I can order and install or is it an upgrade that they plug into a system? Doesn’t give a good description or anything on there website
  24. Sep 9, 2020 at 1:47 PM
    #54
    PissedTundraOwner
    No clue and no follow ups...
  25. Sep 9, 2020 at 4:39 PM
    #55
    FLTundra33
    It’s pretty frustrating cus if it wasn’t for the shudder the truck would be perfect
  26. Oct 14, 2020 at 3:59 PM
    #56
    FLTundra33
    Any new leads with the transmission issue?
  27. Jan 1, 2021 at 8:10 AM
    #57
    ErickC
    ErickC New Member
    2010 Black Toyota Tundra
    I have a 2010 Toyota Tundra, felt the shudder about 2 weeks ago. Around 38-45 under light acceleration It kinda feels like when you’re driving off the lane or hitting the small highway bumps in the highway. Only feels like it for a small second or less. Stop hitting the gas and it stops. I had felt this shudder before on my dads 07 tundra, which he has been driving for over 20,000 miles with the shudder and still shifts smoothly and shudders occasionally, although his shudder felt way more aggressive then mine did (probably due to the fact that he has not acknowledge it).
    anyways, in summary told the dealership about the shudder they did a complete inspection. They told me at first because the truck is lifted it might be off center, which I felt was not true because the truck has 115,000 miles and never done it before. Then they said to balance the tires, which I also felt was not true as the tires are new and have just been balanced.
    Then I took it to my transmission shop guy, just by telling him shudder he stopped me. And explained the shudder and the speed it does it at before I did!
    He immediately said torque converter.
    he replaced the torque converter and changed the transmission fluid. Just got the truck back and I have driven it over 70 miles. So far no shudder.
    I was skeptical about how much a job like this would cost, because i don’t have a lot of money, but in all I ended up paying around 1,200 and got the truck back in less then 2 days.
    hope this helps.
  28. Jan 1, 2021 at 8:12 AM
    #58
    ErickC
    ErickC New Member
    also notice my transmission shop said he had already done 6 tundras this past year with the exact same issue.
    regardless, still an amazing truck.
  29. Jan 1, 2021 at 9:33 AM
    #59
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    Nice, $1200 isn’t too bad to fix the issue. Certainly far better than the cost of a rebuilt trans!
  30. Jan 1, 2021 at 10:31 AM
    #60
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    My 2010 (in ~2013 w/~36k on it) had a Shudder around 40-50mph at times. It wasn't felt in the steering or brakes. Once in a while I could jab the brakes and make it stop. It was a Toyota certified used vehicle so I took it to the dealer and they went over it and were clueless.
    I then found a post somewhere about the Ebrake mechanism sticking. The author advised feeling the rear wheels for heat. So I had the shudder on the highway and pulled over and the driver's rear wheel (aluminum alloy) was hot to the touch and none of the others were hot. I then crawled under and found the Ebrake linkage under the truck under drivers side passenger seat was corroded and nearly frozen. It pulls on the cables for the rear Ebrake and even though released at the dash, was not releasing due to the corrosion.
    I went to the dealer (under warranty) and they oiled it which freed it up for a short while and the shudder came back.
    I needed to do it right so cleaned it up thoroughly and lubed it and lubed it once per year and never had the problem again. I was sure this was a transmission or powertrain issue and was my only issue I ever had with the 2010 Tundra which was easily fixed.
    Traded this year for a new 2020. Just something to check and Dealers are not likely to find this issue.
    Rph74 and Dalandshark like this.
