ISSUE: Installed Ditch Lights, now Clock and Radio backlight turns off when headlights are on.
Discussion in 'Lighting' started by SC_TRD, Jun 24, 2020.
  1. Jun 24, 2020 at 1:52 PM
    SC_TRD
    SC_TRD [OP] Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
  2. Jun 24, 2020 at 1:53 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    From what I gather from other reading... The 2020 Head Unit switched out harness connectors. They appear to be completely different from prior years.
    I have the same Anytime Backup Camera setup too. I ordered back in January and I do not recall having to select a model year... However, my unit was different than yours; Especially, with the blue and grey wires NOT being part of a connector harness. Yours appears to tap into the Head Unit Illumination Circuit and May have done something wonky like what has/is been/being described here.
    I used the VSC Switch circuit for illumination to tap my loose blue and grey wires with Posi-taps.
    Maybe, as something to try to diagnose would be to “de-pin” those to wires from the HU connector?. If it restores your back lighting then maybe take those wires to backlight your switch on another “friendly” switch for illumination?.D3926A9C-E491-496E-9886-FEDEFBC1F55D.jpg
    2020Platinum[QUOTED] likes this.
  3. Jun 24, 2020 at 2:09 PM
    SC_TRD
    Colin
    Round Rock, Tx
    Well, I am buttoning my dash back together.. will have to try again perhaps tomorrow =/
  4. Jun 24, 2020 at 2:16 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Hmm. So have you also checked the Parking fuse? I also saw someone else mention the Dome fuse being associated with the illumination circuit.
  5. Jun 24, 2020 at 2:31 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Get a fuse tester and test ALL fuses in both boxes. That should be step #1
    831Tun, GodlessPro and SC_TRD[OP] like this.
  6. Jun 24, 2020 at 2:44 PM
    SC_TRD
    Colin
    Round Rock, Tx
    I pulled and checked fuses visually.. but that sounds like a good tool to invest in. I will try to handle that on all fuses tomorrow before trying anything else.. thanks Joon!
    joonbug[QUOTED] likes this.
  7. Jun 26, 2020 at 1:58 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    @SC_TRD did you have any luck yesterday?
    SC_TRD[OP] likes this.
  8. Jun 26, 2020 at 2:24 PM
    SC_TRD
    Colin
    Round Rock, Tx
    Hey! So didn’t get to tinkering with it yesterday found myself busy all day installing new leaf springs and shocks in the rear of the truck...
    but just finished playing with it with my new tester I bought @joonbug :hattip:and kind of figured it out, or at least made progress..
    In the cab fuse box, there is a 7.5A fuse called “panel” that was not registering any current.. so popped the fuse out and tested the actual fuse slot and there was also no voltage.. funny thing, when the fuse is pulled out clock and radio do not turn off when the headlights are on... but I replaced with a nearby 7.5A fuse that was good and then the problem occurred again :monocle:... so right now I am running with no fuse in this location as it appears to be dead, but I am also fairly certain this did not fix the rest of my interior buttons not lighting up... definitely not sure the best approach to figure this all the way out
    TRDFerguson[QUOTED] likes this.
  9. Jun 26, 2020 at 2:28 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Do the interior fuses get fed by any of the relays and fuses under the hood? I think I had a wiring diagram on my computer at one point but it's been deleted...
    SC_TRD[QUOTED][OP] likes this.
  10. Jun 26, 2020 at 2:31 PM
    SC_TRD
    Colin
    Round Rock, Tx
    good thinking! I am definitely not certain, but I know my new glow handle tester will tell me quickly.. One of the good things about WFH in all this, I can tinker at any point in the day... post back in a few.. and I’ll also do some research on this idea. Thanks @TRDFerguson!
  11. Jun 26, 2020 at 3:02 PM
    SC_TRD
    Colin
    Round Rock, Tx
    Well, checked under the hood and seems like all exterior fuses are good. Let me do some research to see if maybe I missed something that is feeding into the interior fuse box. Maybe I can dig up a wiring diagram like you mentioned. Thanks again!
  12. Aug 21, 2020 at 9:43 AM
    Tundra_Sam
    Tundra_Sam New Member
    Did you figure out your issue? Now I’m afraid to tap into anything for dash light on my switches.
  13. Feb 16, 2021 at 6:27 PM
    AZTundra
    Paul
    Phoenix, AZ
  14. Feb 16, 2021 at 8:17 PM
    SC_TRD
    Colin
    Round Rock, Tx
    I ended up pulling one of the fuses underneath in the cab to solve the problem.. think it was the accessory fuse.. still my backlighting won’t work on any nob though =(
    but the radio screen at least lights up
    I can take a picture to confirm fuse later if you want
