Is Toyota still the best?
Discussion in '2.5 Gen Tundras (2014-2021)' started by DudeWheresMyZ71, Jun 14, 2022.
  1. Jun 14, 2022 at 9:46 PM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited *sold*
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    Rough country n3 struts level the truck , eliminate the spacer stuff and despite what used to be known about rough country they rode awesome the whole time I had them. Pretty inexpensive too. Just saying.
    Troysbama likes this.
  2. Jun 14, 2022 at 9:47 PM
    Wahayes
    Will
    I think the picture I posted was a 3 inch spacer iirc
  3. Jun 14, 2022 at 9:53 PM
    DudeWheresMyZ71
    DudeWheresMyZ71 [OP] Stop the world and let me off
    21 Tundra TSS 4x4
    Yea the dealer is paying for mine. I’m assuming at the moment that it’s a spacer level. Probably something like the rough country 1.75”. I’ll have to ask the shop tomorrow. But, I mean if the thing breaks there’s only one option. Rebuild and keep rolling ‍♂️
  4. Jun 14, 2022 at 9:59 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    And running over Razorbacks...
  5. Jun 14, 2022 at 10:03 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    A dealer is paying for it?
    Guaranteed cheap shit.
    Spend your own money, make your own choices, do it ONCE and do it RIGHT..
    If a spacer lift breaks a shock, it's gonna fuck up more than just the shock.
    As well as downtime to get it fixed..
    Welcome to the forum...
    Wahayes likes this.
  6. Jun 14, 2022 at 10:09 PM
    DudeWheresMyZ71
    21 Tundra TSS 4x4
    Meh, it’ll be fine. Unless these fine pieces of machinery aren’t meant to be used like a truck. Oh, and horns down by the way
  7. Jun 14, 2022 at 10:15 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    So you're calling spacer lifts 'FINE PIECES OF MACHINERY'?
    You should do a search about them this forum.
    A TUNDRA is only as strong as its weakest link.
    That weakest link in your truck will be an aftermarket spacer lift.
    Are you putting a block on the rear axle too?
    That's embarrassing...
    Keep it on the pavement and you'll be OK.
    Good luck Bro.....................
    Again, welcome to the froum..:thumbsup:
    Black Wolf and Cpl_Punishment like this.
  8. Jun 14, 2022 at 10:17 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    :thumbsup:
  9. Jun 14, 2022 at 10:21 PM
    DudeWheresMyZ71
    21 Tundra TSS 4x4
    A Tundra is what I’m calling a fine piece of machinery. But if a small spacer level causes as much damage as what you’re implying it’s the opposite. I’m not worried in the slightest, if it breaks, all you have to do is fix it. Simple stuff. But if that’s all it takes to break one of these things, I damn sure don’t need one :rofl:
  10. Jun 14, 2022 at 10:27 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Worth checking your tires to see if they’re balanced, my first set of OEM tires needed periodic attention to keep them balanced. I’ve had bad luck with Goodyear tires not holding balance well, currently on a set of Falken Wildpeak AT3W’s and they’re great so far. Wheel lug nut torque is easy enough to check yourself, a competent shop will always final torque with a torque wrench but some techs want to just zip stuff on with the air gun and call it hood because they’re using torque impact sockets.
    I wasn’t trying to imply load E tires were inherently an issue, just that a heavy and out of balance tire is an issue.
  11. Jun 14, 2022 at 10:31 PM
    DudeWheresMyZ71
    21 Tundra TSS 4x4
    Oh no I understood what you meant about the E load range tires. Yea I’m sure that’s where they’ll start with it if they have time, if not it’ll have to go for an alignment after it’s leveled anyway so I’ll just have it done then. And you’re not kidding about Goodyears. I’ve had mucho headache from all 3 sets I’ve had.
  12. Jun 15, 2022 at 4:32 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I too don’t care for spacer lifts, but I at least somewhat get installing them on a low mileage truck. For a lot of us who want to lift or level, the truck may already have 50k+ miles when we do it. At that point the shocks are getting more worn out, so it just makes sense to install better riding and more dependable shocks and struts with something like a Bilstein 5100. Many choose to go a step further and go with a whole new coilover, since you’re already working in there why not change the springs too especially if you need heavier springs for your add ons. Between my 2010 and 2017 I have had no issues associated with lifting the front 2.5-3 inches for tens of thousands of miles. I used to be a Chevy guy. I’ve found the GM half tons you’re accustomed to usually eat through front end components faster when you lift the front than Toyota trucks do.
  13. Jun 15, 2022 at 4:35 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    There are enough guys here running 37s that I'm sure the Tundra platform isn't the issue with your setup.
  14. Jun 15, 2022 at 4:35 AM
    DudeWheresMyZ71
    21 Tundra TSS 4x4
    That’s good to hear! My GM trucks never really went through any front end parts except for a wheel bearing on a Sierra that had 150k on it. Yes it was leveled with spacers in the front, 3” in total, but I kind of doubt that was the issue lol. Thanks for the feedback!
  15. Jun 15, 2022 at 4:42 AM
    DudeWheresMyZ71
    21 Tundra TSS 4x4
    I’m pretty sure it’s not either. I just like to hear people gripe honestly. I’ve noticed many Tundra owners wouldn’t be caught with an aftermarket USB cable. And an aftermarket leveling kit!?! :eek2: You’ll die! I love pushing buttons;)
    GODZILLA likes this.
  16. Jun 15, 2022 at 5:01 AM
    pursuit2550
    pursuit2550 New Member
    Me personally, I don’t want cheap parts in an expensive truck. Not to mention you can get a decent coil over set for a decent price. Rear shocks aren’t much either. Just like I don’t do rear lift blocks. I have broken them. Lift shackle or leaf springs. Your killing 2 birds with one stone. Upgrading your shocks and a better ride. Way better ride than a cheap spacer lift. I am seeing people on the wheel and tire thread over on the 2022 forum buying Amazon $40 spacer and $50 wheel spacer for their $60+k trucks. Wow is all I can say.
  17. Jun 15, 2022 at 5:08 AM
    DudeWheresMyZ71
    21 Tundra TSS 4x4
    Man I’ve been reading the same stuff. I’ve used spacer lifts to level, never anything crazy which I think some on here have misread. But, these people throwing wheel spacers on 35s and 37s… maximum cringe. In the GM world that’s the thing everyone bashes on (like the spacer lifts here). Too many wheels shearing studs after wheel spacers for me. Which I’ve never liked the tires outside the fender anyway. Stuffed and tucked
    pursuit2550[QUOTED] likes this.
  18. Jun 15, 2022 at 5:30 AM
    Wahayes
    Will
    I think the 2022 guys are doing at least the spacers anyway because it's a temp fix until suspension kits are released.
  19. Jun 15, 2022 at 5:32 AM
    #49
    pursuit2550
    I am not gonna lie, I did have a wheel spacer kit in my truck recently. I did buy SpiderTrax, one of the best if not the best spacers. Never had an issue and did it because the wheels I wanted, SCS Ray10 weren’t in stock. So I did a spacer kit for the time being. Now I have my wheels and the spacers are out. But I would have never bought $50 spacers from Amazon for my truck. Like I said me personally I just prefer to do it the best way possible and be done. I am not going all out crazy and doing $3k worth of coilovers for a pavement queen but a decent set of coilovers improves your ride and is way better than a spacer. I am on my 4th tundra. 3 of them have had lifts. 2 of them coilovers and 1 had a spindle and coil over lift (6”).
  20. Jun 15, 2022 at 5:34 AM
    #50
    pursuit2550
    If i recall coilovers are already available for the 22. Probably not all manuf though.
  21. Jun 15, 2022 at 5:38 AM
    #51
    Wahayes
    Will
    I know I've seen slot of posts saying I'm waiting for "x" suspension to come out etc
  22. Jun 15, 2022 at 5:39 AM
    #52
    DudeWheresMyZ71
    21 Tundra TSS 4x4
    There’s a couple lifts on the market, wheels to make the offset instead of spacers. BUT I agree, probably waiting on a specific brand to come out with a kit they like.
  23. Jun 15, 2022 at 7:28 AM
    #53
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    To answer your click bait title, unfortunately Toyota is still the best. This gen might be the newest (build date) most reliable truck you can buy. Although not perfect, it is built to last.
    Why do I say unfortunately...? Because competition is always good for the consumer and I feel that to some degree Toyota knows they have the market well cornered in the "trusted" category. If Ford, Chevy, or Dodge could step up their game and earn the same reputation we would all benefit by having more options when it comes to making sure your hard earned money will last when purchasing a vehicle.
    Terndrerrr and panicman like this.
  24. Jun 15, 2022 at 7:38 AM
    #54
    DudeWheresMyZ71
    21 Tundra TSS 4x4
    current Gen? You mean the Gen 3s?? I thought it was one of the worst vehicles I’ve ever driven. Well, the one I test drove was anyway
  25. Jun 15, 2022 at 7:41 AM
    #55
    1UP
    1UP Truck Gang
    I meant it in the context of the current vehicle gen we are talking about (2.5 generation 2014-2021). Buying one would be the newest by build date you could get if searching for "most reliable"
    I edited the post to clarify.
    I share the same opinion about the 2022+
  26. Jun 15, 2022 at 7:46 AM
    #56
    Junior 88
    Junior 88 New Member
    Junior
    18 tundra Sr5
    7inch bds on 35s
    7 inch BDS. I am at 30,000 with no issues.
  27. Jun 15, 2022 at 7:51 AM
    #57
    DudeWheresMyZ71
    21 Tundra TSS 4x4
    I understand what you’re saying now. I know some that have bought the ‘22s think they’re the best thing since sliced bread. But I wouldn’t want to say my $70,000 truck was a turd either
    Leedaar and 1UP[QUOTED] like this.
  28. Jun 15, 2022 at 8:09 AM
    #58
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    hagrid likes this.
  29. Jun 15, 2022 at 8:13 AM
    #59
    Jb357
    Jb357 New Member
    I got my 16 with a dealer installed 3/2 spacer lift on 305/55r20s. It rode like that for 50k miles. Pulled that off and installed 6112's at 1.9 setting because alignment was never right. Blisteins were the same price as new uca's so why not. Went to 34's around the same time.
    I'm now at 74k.
    Probably 40k miles have had a 21' bass boat behind it. 10k with a 28' tt behind it. Up and down 30 year old unmaintained logging roads for 6 deer seasons that jeeps spend all spring rutting out.
    I had to put brakes on it at 65k and the vinyl has come loose on the center console lid because I have a cable ran out of it to plug into my head unit. Totally disappointed, Toyota is the worst.
    Cpl_Punishment and texasrho83 like this.
  30. Jun 15, 2022 at 8:21 AM
    #60
    DudeWheresMyZ71
    21 Tundra TSS 4x4
    Sounds like a nightmare, glad to hear some more positive feedback!
