Is this polisher good enough?
Discussion in 'Detailing' started by WFD473, Sep 11, 2019.
  1. Sep 11, 2019 at 12:28 PM
    WFD473
    WFD473 [OP] Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    So I've been out of the detail game for quite awhile. I've had this polisher for years, but never really used it. I've just been hand waxing over the years. I keep hearing good things about da polishers and was wondering if I need to get one, or if my Milwaukee is good enough. If it is, what pads do you recommend? I have some swirls and light scratches. Thanks.20190911_133218.jpg
    Pudge likes this.
  2. Sep 11, 2019 at 12:53 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    That looks like a very good polisher, but it's not a DA so you need to be very careful you don't burn thru your clearcoat with it. The DAs are pretty much idiot proof as far as being able to damage paint. I would do a lot of practicing with that before I put in to my tundra.
    A good DA is probably the way to go for light scratches. There was just a thread about the new G9 from griots at $149 its an exceptional value. Also maybe pick up a used griots GG6 or porter cable unit from someone selling their old polisher @War Machine ?
    For light scratches and swirls you should be able to get away with a polish and a few pads. I recommend lake country foam HDO pads, maybe get 3 orange and 3 black, the orange will give a little more cut but not too much and the black will finish down nicely. You could also try buff and shine uro fiber microfiber pads, they can cut and finish decently. Just be sure you get enough pads, a clogged up pad is useless and they can get clogged quickly. Get some lake country snappy clean packets for cleaning them. Take care of the pads and they will last a long time.
    For polish I really like carpro essence gloss enhancing polish, meguiars M205, and I hear really really good things about griots BOSS line of polishes and compounds.
    If you get M205 you can get some decent cutting, almost like a compound with a certain technique, then finish it off smooth with another technique.
    You can also get some red pads for applying waxes and sealants, makes it go much faster.
  3. Sep 11, 2019 at 1:02 PM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    ^^^^^^^ WELL SAID
    WFD473[OP] and Voyagermike like this.
  4. Sep 11, 2019 at 1:10 PM
    Pudge
    CT
    Great advice. The high RPMs, free spinning big power motor, and that wool pad could damage his paint in seconds if he isn't used to how it works. I'm not saying it wont work and he can't use it, I'm trying to provide a little education so he or you can take it or leave it. Seems like you'll be a great addition and a sure fit here at tundras.com
  5. Sep 11, 2019 at 1:16 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
  6. Sep 11, 2019 at 1:24 PM
    War Machine
    War Machine SSEM # 5 3MW
    That looks to be a great machine, and I’m partial to Milwaukee, but it’s a rotary. Like @Pudge said, you can do some big damage really fast with it. Someone who knows what they’re doing can do some great work with it, but I wouldn’t attempt it myself.
    A Dual Action polisher doesn’t have that issue. You have to be trying pretty hard to damage your paint with one of those.
    Pudge and WFD473[QUOTED][OP] like this.
  7. Sep 11, 2019 at 1:26 PM
    War Machine
    Well he’s gone now, you happy?
  8. Sep 11, 2019 at 1:29 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Personally I will not use a rotary “buffer” on my truck and I use one weekly here are the shop. If your truck just has minor defects (swirling and light scratches) invest in a quality da (Dual Action) polisher. After I get done with the rotary, a da is what I use to get rid of the swirl marks. Just my .02 but what do I know?
  9. Sep 11, 2019 at 1:35 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Not to derail, but I saw this mobile washer using a dewalt sander outfitted with polishing pads..:notsure:
  10. Sep 11, 2019 at 1:37 PM
    War Machine
    Damn. I’ve heard of people using grinders also.
    saybng[QUOTED] likes this.
  11. Sep 11, 2019 at 1:38 PM
    saybng
    Gary
    Ventura CA
    :rofl::rofl::rofl:
    That's what I was thinking..hahahahaha
  12. Sep 11, 2019 at 1:59 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Thanks Gents! That's just the info I needed. I've heard Toyota's paint is notorious for being soft, so I wanted to make sure not to make a mistake by using the polisher and burning through the paint. I've done it before and when I think about it, I cringe. I saw this new da polisher on harbor freight and was wondering if it would be a good starter unit. Thanks again.
  13. Sep 11, 2019 at 3:08 PM
    War Machine
    That’s the newer version of the one some of us have used. @Pudge probably has more experience than the rest of us do with the Harbor Freight.
    WFD473[QUOTED][OP] likes this.
  14. Sep 11, 2019 at 3:09 PM
    Pudge
    CT
    :p
  15. Sep 11, 2019 at 3:11 PM
    Pudge
    CT
    Grinder? Wait.... Isn't that the dating app you were trying to get me to sign up for?
  16. Sep 11, 2019 at 3:16 PM
    War Machine
    Just trying to help you find a sugar momma.
    WFD473[OP] and Pudge[QUOTED] like this.
  17. Sep 11, 2019 at 3:20 PM
    Pudge
    CT
    Those are very much just okay. I did my whole truck with one and my arms were dead after. I then got a griots gg6 and did another truck that needed more work, but still did it in less time and fewer passes. So obviously I have one and would not recommend it. While they do work, they are loud, vibrate like crazy, and it takes 2-3 times as many passes as it takes with my griots to get a defect out. I would sink a few more bucks into a porter cable or griots, you'll be happy you did. Even a used machine from someone here would be a better investment than the harbor freight in my opinion. I got mine for about $55 at the time and that still wasn't worth It really, if you catch a sale you can get a porter cable or griots for around 125-150, or less used from someone upgrading, they pop up here now and then for sale or trade.
    That said, if you do get the HF model, get a 5" backing plate to put in it. They perform much better with a smaller pad and plate. Lake country backing plates fit them well, you just need to use both crush washers for proper spacing.
  18. Sep 11, 2019 at 4:09 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    I picked up a Griot's 6" Random Orbital
    150 with a 30.00 rebate
    I can not screw my paint up with it but I can make it close to glass.
    Pick up some pads. About 4 of them for polishing.
    One for waxing
    WFD473[OP] and Pudge like this.
  19. Sep 11, 2019 at 4:15 PM
    JMB
    JMB Not new, just a little old
    Chesapeake, VA
    2013 Super White Tundra DC
    A palm sander is da. I'm not saying to use one on your truck, just that most are da.
  20. Sep 11, 2019 at 6:12 PM
    Pawpaw01
    Pawpaw01 New Member
    Bruce
    2016 TRD Off Rd /BadAss Edition
    DOUBLE Roll Bar/w- Off Road LED Lighting . Front matching light Led Setup bar
    I used to detail years ago, used nothing but NuFinish, still do, and I do it all by hand. Shines great, and last for at least 6 months. Great on clear coat, works on glass as well.
    For engines , Dawn Dishwashing liquid, removes all grease and dirt, harms nothing. If don’t hurt ducks covered in oil, it ain’t going to hurt your engine either!
    My truck still looks as good as it did the day I got it.
    Just sayin. Old school I guess.
  21. Sep 11, 2019 at 7:46 PM
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    What he said^^
    In addition to that, nowadays a good DA with the right pad and the proper liquid will net the same results a rotary would, without the risk of damaging your paint.
  22. Jun 22, 2020 at 8:30 AM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Hey fellas. So, I'm finally ready to pull the trigger on a G9 and found this combo. Is it a good starting point or is there something else you'd recommend? Thanks
  23. Jun 22, 2020 at 12:40 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
  24. Jun 22, 2020 at 1:56 PM
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    That is a great starting point. It covers most of your bases when doing paint correction and normal polishing. Make sure you have the appropriate liquids too.
  25. Jun 22, 2020 at 3:39 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Perfect. Thanks!!
