Is this normal ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Angry_Asian, May 14, 2017.
  1. May 14, 2017 at 3:58 PM
    Angry_Asian
    Angry_Asian [OP] New Member
    Brandon
    Temecula CA
    2017 tundra SR
    None
    So I just noticed the texture of the paint along the bottom of the doors and up to the wheel well. the sun hit it just right and it stands out like a sore thumb the drivers side is not as bad but is this normal ?IMG_0316.jpg IMG_0315.jpg
  2. May 14, 2017 at 4:02 PM
    Think somebody else started this thread.. i have it too all along bottom.. believe they said it was normal.. someone else will chime in
    Law323 likes this.
  3. May 14, 2017 at 4:04 PM
    15whtrd
    15whtrd Mr. Blonde
    Yes normal
    040Tundra and Angry_Asian[OP] like this.
  4. May 14, 2017 at 4:06 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    It's helps with rock chips.
  5. May 14, 2017 at 4:06 PM
    Angry_Asian
    Brandon
    Temecula CA
    2017 tundra SR
    None
    Great thanks for the help
  6. May 14, 2017 at 4:09 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yep yep. Normal
  7. May 14, 2017 at 4:20 PM
    Normal.
    Angry_Asian[OP] likes this.
  8. May 14, 2017 at 5:09 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Standard Toyota protection on rocker panels for years
  9. May 14, 2017 at 5:13 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I tire shine mine.
  10. May 14, 2017 at 5:35 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    All is well...press!
  11. May 14, 2017 at 5:43 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  12. May 15, 2017 at 2:45 PM
    Snappymove
    Snappymove New Member
    Joe
    Whittier CA.
    2017 WHT Tundra SR5 TRD PRO 4x4 Off Road extra Cab
    Not Yet
    My has it too but my guess is that if I'm Not wrong that will be something like anti corrosion since most of us will be taking ours truck to the mod or to the snow and specialty the snow has salt that can make a really bad damage to the paint and mostly or usually that section section is the most affected
  13. May 15, 2017 at 5:03 PM
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    At least it isn't discolored like mine 16 that was with about 20,000 miles on it even when it's clean it still sticks out
    15whtrd likes this.
  14. May 15, 2017 at 5:05 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Protective finish
    It's like a durable clear bra
  15. May 15, 2017 at 5:20 PM
    dooododoo
    dooododoo New Member
    MGM '17 CM OR
    Fortin EVO-ONE Remote Start iBoard Running Boards (Black 5") LED interior lights Line-X Bed Plasti-Dip Emblems
    It's supposed to protect the paint from rocks that get kicked up from the tires. I've also seen them on my Tacoma. Typically found on most trucks.
  16. May 15, 2017 at 5:41 PM
    MakMurph
    MakMurph I'm here
    Chip guard , gravel guard just an extra layer of protection seems like mine could of used a couple more coats of paint to cover it better oh well
  17. May 15, 2017 at 6:54 PM
    PMG
    PMG New Member
    The MGM colors have a pinkish hue to them.
  18. May 15, 2017 at 7:19 PM
    TheBeast The Beach
    yep. have it too.
