Is this bolt suppose to be loose?
Discussion in 'General Tundra Discussion' started by Slp82, Aug 17, 2018.
  1. Aug 17, 2018 at 4:31 PM
    Slp82
    Slp82 [OP] New Member
    2005 Tundra RC 4.7 4x4; Toytec Boss 2.0 kit; SPC upper control arms; addicted offroad front bumper & 9k winch, Brute Force sliders & rear bumper, skid row skid plates, 285/75r16 Cooper AT3, Detroit trutrac in rear.
    2014 Tundra 4x4 5.7L DC; Bilstein 6112s @ 1.9"; 35x12.50 Nitto Ridge Grapplers on 20x9 wheels with +25 backspacing; DV8 front & rear bumpers, Engo 12k winch (SOLD) 2005 Tundra RC 4.7 4x4 w/3" spacer, addicted offroad tube winch bumper w/9k Engo, homemade sliders, skid row skid plate, 285/75r16 Cooper AT3, Detroit trutrac in rear.
    So I am hearing a "metal on metal" noise when I hit a nice pot hole, coming from the driver side. We checked all the bolts to ensure they are tight from the recent install of the 6112s. We also used thread locker on all bolts when putting it back together. So when we checked all the bolts just now, we only found one bolt loose, and thats the bolt that retains the top hat when the 6112s were assembled. I didn't assemble this myself. I had it assembled by the dealer and sent to me already ready to install. I have never assembled 6112s before, or any other coilover so I am not sure if those retaining bolts in the center top are suppose to be tightened down tight or just screwed down to a certain point of the threads. We checked the passenger side and it is "not tight" as well... so I am not sure if they are suppose to be like this or not. Here is a picture of the bolt I am speaking of:20180817_183011.jpg
  2. Aug 17, 2018 at 4:33 PM
    Outbound
    Outbound SSEM #2.5, Token AmeriCanadian
    Aaron
    Northern Alberta
    Shouldn't be loose. That's the bolt that's securing your strut to your coil spring.
    Les7311 and driverdog like this.
  3. Aug 17, 2018 at 7:15 PM
    Slp82
    Well it wasn't "tight". It wasn't about to fall off or anything, but it definitely wasnt tight. I was able to turn it with only a short wrench (not much leverage) just using some wrist strength probably about 4 full 360 degree rotations.
  4. Aug 17, 2018 at 7:32 PM
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    Bilstein should have install instructions floating around someplace that'll probably tell you. They typically come with torque specs on all parts you touch during the install
  5. Aug 17, 2018 at 9:19 PM
    TheBeast The Beach
    a loose bolt doesn't serve much purpose :)
    GNTundra and 15whtrd like this.
  6. Aug 18, 2018 at 1:26 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Note the top of the thread has a flat indent.
    Find a, I believe, a 6mm open wrench to lock/hold, then use whatever size wrench to tighten the nut.
    An adjustable pliers can work the same to hold head
    Post op your response.
  7. Aug 18, 2018 at 5:57 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Just another thought...do you have the TRD Pro skid plate?
  8. Aug 18, 2018 at 7:37 AM
    Ericsopa
    Ericsopa Old man and the sea
    Do NOT tighten that nut. It isn't supposed to be "torqued." It compresses a rubber "donut" bushing, squeezing it until it is roughly the same diameter as the large washer right below the nut. The nut is a locknut (see the indent in the picture?) so it will not loosen. That rubber donut below the washer absorbs some of the shock of suspension movement, making everything a little quieter and more importantly, protecting mounts and components from road shock. It's part of the system design.
    (And it's not the source of your noise, anyway)
    Edit.....just re-read some of the thread. You've already tightened it 4 turns roughly. You should loosen it back up four turns, now, before the bushing loses its resilience.
    geno0506 and landphil like this.
  9. Aug 18, 2018 at 8:23 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Measure the other side and compare that to the one you said is loose, but as others have said I doubt that's your problem
  10. Aug 18, 2018 at 9:36 AM
    Crunch527
    Iowa
    I bring up the TRD Pro skid because a bunch of folks have had issues (myself included) getting that thing to not make a bunch of noise. It touches the frame in a few spots and even with proper install it’s not always quiet.
    Ericsopa likes this.
