Is this a transfer case seal leak?
Discussion in '2.5 Gen Tundras (2014-2021)' started by SpeshulED, Dec 3, 2018.
  1. Dec 3, 2018 at 6:01 PM
    SpeshulED
    SpeshulED [OP] New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    Need some advise. I have a leaving that’s coming from the transfer case. I unbolted and cleaned up the transfer case skid plate and saw a marginal amount of oil also on the t case. Cleaned and bolted everything back up and the leak has come back.
    What are your thoughts? If so, how hard is this to do and are there any posted DIY’s?
  2. Dec 4, 2018 at 5:09 AM
    15whtrd
    15whtrd Mr. Blonde
    How many miles do you have? Maybe you’re still under powertrain warranty.
  3. Dec 4, 2018 at 5:11 AM
    15whtrd
    15whtrd Mr. Blonde
    Looks like it’s leaking at the output shaft seal.
  4. Dec 4, 2018 at 5:25 AM
    Same observation here..
    15whtrd[QUOTED] likes this.
  5. Dec 4, 2018 at 5:26 AM
    This ^^
    This is not a horrible job to fix.
    Torque wrench
    Socket set and various hand tools
    Seal install tool
    Lock tight
    Mark driveshaft position to minimize vibrations.
    Make sure seal is installed flush, lube seal up before installing the yoke to the output shaft. You don’t want to damage the new seal.
    Torque output shaft nut and driveshaft bolts to recommended specifications.
    831mic, TTund16, Mr Swervlin and 2 others like this.
  6. Dec 4, 2018 at 5:29 AM
    15whtrd
    15whtrd Mr. Blonde
    So it can be fixed right on the truck? Just remove driveshaft, pull out seal out and tap the new seal in place?
  7. Dec 4, 2018 at 5:31 AM
    Yes sir.
    focal, Tundyfundy and 15whtrd[QUOTED] like this.
  8. Dec 4, 2018 at 5:35 AM
    15whtrd
    15whtrd Mr. Blonde
    I love it when they build stuff like that!
  9. Dec 9, 2018 at 12:02 AM
    SpeshulED
    No write ups on it?
  10. Dec 9, 2018 at 4:33 AM
    YouTube has some on the Tacoma’s, same process.
    Tundyfundy and 15whtrd like this.
  11. Mar 2, 2020 at 11:28 AM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Did you ever get this fixed? Mine developed a leak last year. Unfortunately, mine was leaking from the front output shaft, and the front seal cannot be replaced "on the truck"...at least not for my Gen 3. The T-case has to be removed and opened to replace the $5 seal. At least $1800 according to Toyota. I drained mine and used some AT-205 with new fluid. That seemed to help for several months, but just noticed it was leaking again yesterday.
  12. Mar 2, 2020 at 11:52 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Only suggestion I would add is to cover the shaft splines with electrical tape before installing the seal...might be some sharp edges on the splines.
  13. Mar 12, 2020 at 11:58 PM
    SpeshulED
    I did. It ended up costing me $600
  14. Mar 13, 2020 at 8:33 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    Just loosen the driveshaft at the T/C. Push shaft back just a little and drop the front of the shaft. Push shaft aside. Remove yoke and seal. Check the yoke for a seal groove. Replace it if it’s deep. Make sure to not lose the spring in the seal after it’s put in p,ace. Reinstall shaft. Check fluid level.
  15. Apr 5, 2020 at 4:39 PM
    zpoulsen
    zpoulsen -
    Indiana
    2016 Tundra TRD PRO
    did the transfer case need to be opened up to replace the seal? Did Toyota do the work?
  16. Jun 19, 2020 at 4:30 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    You fix your seal? I have the same broken seal.
  17. Jun 20, 2020 at 12:39 PM
    zpoulsen
    zpoulsen -
    Indiana
    2016 Tundra TRD PRO
    thearborbarber likes this.
  18. Jun 20, 2020 at 2:50 PM
    alpinepro4
    Pat
    Good write up. I called my dealer and it’s still under warranty. Good thing since my warranty runs out July 28th. Now starting to think I might pay to extend it. That whole other topic.
