Is there any way to switch ALL the window switches to AUTO?
Discussion in '3rd Gen Tundras (2014+)' started by 2015Crewmax, Aug 3, 2018.
  1. Jun 5, 2019 at 1:17 PM
    Topherwv
    Topherwv New Member
    Bump... Any way to let the driver have control of the damn windows even though you locked from other passengers? It's driving me crazy having to swiftly push the button to turn off the lock for me to have control. The driver should ALWAYS be able to have control.
    mojojo likes this.
  2. Jun 7, 2019 at 11:07 AM
    1fujifilm
    1fujifilm New Member
    Bear
    19 Tundra Crew
    Not to sound Un-American, but whatever happened to the Japanese being superior to the Americans in technology? These Trucks are lagging tremendously. The 2019 Highlander ain't too fare behind either.
    My speculation; TOYODA IS A GREEDY M F COMPANY!
    My 19 Crew does have LED lights though, that rules.
    Bear
  3. Jun 7, 2019 at 11:33 AM
    ktmhauler
    ktmhauler New Member
    GA
    2019 SR5 Dbl 4wd 5.7
    I just want auto up on the driver side and i'd be happy. My 2013 SR5 4Runner had it and when I saw the "auto" button when checking out my new tundra I kind of just assumed it went both ways. Seriously WTF toyota how much did you save not having auto up when you already had auto down?
  4. Jun 8, 2019 at 6:49 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2019 MGM TRD Sport 4X4
    I'm going to install a module soon. I'll try to take pictures and such. Usually there's is a constant hot feeding the module do it would work with an aftermarket keyless. But I only cared for it to work when the key is on, so I took power from the factory wires that energize with the key for the windows. On my 1st Tundra.
  5. Jun 8, 2019 at 7:30 PM
    SRM18TRD
    SRM18TRD New Member
    18 TundraTRDOR
    Stock
    My 15 4Runner is full auto. I may see if the switches are interchangeable...
  6. Jun 8, 2019 at 7:58 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    I believe the "auto" is built in to each window regulator, not switches. My wife's '14 4Runner is all auto too. Hers is just an SR5.
  7. Aug 9, 2019 at 11:01 AM
    CO_Native
    CO_Native New Member
    Englewood, CO
    2019 MGM CM TRD Sport
    My 14 4Runner SR5P had full auto windows too. Did you ever find out if you can use the switches to accomplish this?
    I can't believe my new 2019 only has auto-down on the drivers window, wtf Toyota?
  8. Aug 9, 2019 at 11:17 AM
    Greybeard
    Greybeard Neither here nor there
    GA
    2014 SR5 Double Cab
    I'd settle for just auto up on the driver's window. I mean come on it has auto down, why not
    CO_Native likes this.
  9. Aug 9, 2019 at 11:28 AM
    phabej
    phabej New Member
    2018 White Tundra SR5 Sport CM 4x4
    Toyota is conservative company that's for sure.. but GREEDY?? I have to disagree. Anyways Tundra head development is lead by some Mike guy, so blame him, not Toyota. He's directly in charge of what "Tundra" should have.
  10. Aug 9, 2019 at 11:47 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Hey @Roman what do you think the odds are of getting this done? Do the window switches go to the same module for the 4Runner and the Tundra?
  11. Aug 9, 2019 at 1:03 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    If you're trying to simply swap switches, it definitely won't work. New regulators/motors would have to be utilized as well, and would definitely be a completely custom install as I'm sure the parts won't just swap over easily.
    Sas and CO_Native like this.
  12. Aug 9, 2019 at 1:12 PM
    Army_of_One
    Army_of_One New Member
    2019 MGM TRD Sport 4X4 CrewMax
    OEM+
    I could be wrong, but aren't the regulators the same between all of the non auto windows(rear left and right and front passenger)? The same goes for the auto down front regulators(on the limited and platinum)?
  13. Aug 9, 2019 at 1:22 PM
    CO_Native
    Englewood, CO
    Dang, I knew it couldn't be just an easy plug-n-play. Oh well, at least I have auto-headlights (4Runner lacked) lol
  14. Aug 9, 2019 at 1:23 PM
    Roman
    Roman
    Franklin, TN
    Yes, but the motors are not the same and would have to come from a different model with auto up/down, which probably wouldn't fit the stock Tundra regulators. Unless there's another work around that I'm unaware of.
    Sas likes this.
  15. Aug 9, 2019 at 5:47 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    The easiest thing would be to put an auto window module on them. I did on the front doors of my '14 Tundra. I'm going to do the same to this '19..... eventually. Now this is only my 2 cents. On the SR5 and lower, the switches are high current or the load goes through the switch. On the higher models, I think they are low current, just sending directional signals to the individual door regulators. If you listen to your driver window switch. When you auto down, you'll hear a click or relay release when the window is at the end of travel. If you have factory all auto, do the same and you'll hear the click in each door. Cheapest, easiest is gonna be auto modules. Like DEI 535T.
  16. Aug 13, 2019 at 5:32 PM
    jclem65
    jclem65 New Member
    james
    19 tundra crewmax sr5 trd off road
    hi all, i tried this last week switch out of a limited/pro was a no go.:annoyed:
    CO_Native and Sas like this.
