Is there a way to reset ecu for a bigger fuel tank
Discussion in '2.5 Gen Tundras (2014-2021)' started by Firered, Jan 1, 2022.
  1. Jan 1, 2022 at 1:16 PM
    Firered
    Firered [OP] New Member
    2015 Radiant red dbl cab
    I replaced my fuel tank with a 46 gallon tank. Is there a way to reset the ECU?
  2. Jan 1, 2022 at 1:53 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  3. Jan 1, 2022 at 2:21 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    What are you referring to when needing to reset ECU? Distance to Empty?
  4. Jan 1, 2022 at 3:21 PM
    timsp8
    NY
    Unhook the battery for 15 min. Give it tank or 2 and see if it figures it out.
    HulkSmurf14 likes this.
  5. Jan 1, 2022 at 3:25 PM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Good question! Maybe ask the tank supplier. I would think that they would know the answer.
  6. Jan 2, 2022 at 9:06 PM
    Firered
    Was hoping to be able to recalibrate it. Tried disconnecting and it just goes back to the 26 gallon setting. The manufacturer say to watch the gauge as you fill to see how much is at each 1/4 mark and figure from there.
  7. Jan 2, 2022 at 9:34 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
  8. Jan 2, 2022 at 9:39 PM
    Firered
    That sounds about right regarding the low fuel light. I love the distance without having to stop when towing a trailer.
