Is there a step available to help getting up into the bed?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by CaptainGrumpus, Mar 23, 2020.
  1. Mar 23, 2020 at 11:43 AM
    CaptainGrumpus
    CaptainGrumpus [OP] The Mailman
    Maine
    2018 Inferno Tundra TRD
    Hey all...was hoping that there is some sort of step I can install that would help me getting up into the bed. Thanks!
  2. Mar 23, 2020 at 11:48 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Welcome to the forum!
  3. Mar 23, 2020 at 11:59 AM
    CaptainGrumpus
    Maine
    Thank you!!
  4. Mar 23, 2020 at 12:17 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
  5. Mar 23, 2020 at 12:20 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Pricing on those steps is unreal.
  6. Mar 23, 2020 at 12:25 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    I've been wanting to get one but they're too expensive for what they are imo. I'd be fine using the bumper corner but there's really nothing on the bedside to grab onto to help pull up. I usually grab the corner above the tail light, but not much to grip to.
  7. Mar 23, 2020 at 12:25 PM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    Those prices are LUDICROUS.
    lu·di·crous
    /ˈlo͞odəkrəs/
    adjective
    adjective: ludicrous
    1. so foolish, unreasonable, or out of place as to be amusing; ridiculous.
  8. Mar 23, 2020 at 12:28 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I put a boot on the top of my tire then pull myself up and over using the bed side
    BENWALES and GeezePlease like this.
  9. Mar 23, 2020 at 12:32 PM
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    Does the OEM step bolt to the frame or OEM bumper assembly? Curious if it will work with the Smittybilt M1 bumper.
  10. Mar 24, 2020 at 5:08 AM
    CaptainGrumpus
    Maine
    I can’t believe there aren’t any cheaper aftermarket options. $230 is pretty absurd for what it is.
    GODZILLA and texasrho83 like this.
  11. Mar 24, 2020 at 5:10 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    It bolts to the frame. But it uses the bumper bracket bolts, so as long as your aftermarket bumper did not change this setup you might be okay there. However, it sits close to the OEM bumper when folded up, and when down the bracket gets close to the bumper also, so depending on your bumper size it might still not work right.
  12. Mar 24, 2020 at 6:54 AM
    CaptainGrumpus
    Maine
    Thanks for the pic. Looks like an easy enough install. Gonna see what my local dealer sells it for. Not a glamorous mod, but would definitely be useful.
  13. Mar 24, 2020 at 8:17 AM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    I use a small step stool that folds up and fits under the toneau behind the fender and I bungie it to the side. There are plenty of options under 20 bucks.
    Something like this: [​IMG]
  14. Mar 24, 2020 at 8:27 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    I paid $200 cad for my OEM, installed, when purchased truck. It's backed by 3y because of it
  15. Mar 25, 2020 at 10:08 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I carry this on trips and when wheeling. I strap it with bungee cord against the tailgate.
    14burrito and texasrho83 like this.
  16. Mar 25, 2020 at 10:22 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Or you could just wait around and see if a used one pops up for sale.
  17. Mar 25, 2020 at 1:04 PM
    Kn4x2
    Kn4x2 Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    I couldn’t afford one those either, so I went for this one ($55.00)
    C92598FB-0CAE-453B-B4BF-273B93B92D7E.jpg 217D0535-8AFE-4EEC-9EB7-A610DB971040.jpg
  18. Mar 25, 2020 at 1:40 PM
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    Is there a matching step for the passenger side, I weird about balance and I think the single step looks stupid :)
    GODZILLA likes this.
  19. Apr 20, 2020 at 10:43 AM
    jahshuah
    jahshuah New Member
    Joshua
    Council Bluffs, IA
    2017 Tundra TRD Pro
    295/70/18 Toyo RCI rock sliders Diode Dynamic amber fogs/bumper bar Diode Dynamics grill light bars Alpine 445u ATL black interior 12Volt Solutions Remote Start Gecko LEDs bed and hood
    check out Rago Fabrication
  20. Apr 20, 2020 at 11:12 AM
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    I broke my ankle a few months ago and would just hobble over on my crutches, sit on the tail gate, turn around, and get up. It was free and easy on the joints.
    FrenchToasty likes this.
  21. Apr 20, 2020 at 4:53 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Thanks for the tip, it looks like their antenna mount would work good as a hand-hold. Will have to go measure my gate gap tomorrow when it's not raining and see if it'd work. Only thing I'd be somewhat worried about is if you get any bed flex that it'd rub the paint off the gate. Also I'm not sure if those are existing holes or not.
  22. Apr 20, 2020 at 6:26 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    I have an 8" lift on 37's, this didn't work for me. So I bought the step. I agree they are steep for what they are, but they are sturdy and well made. You can get the bestop version and save a few bucks.
  23. Apr 20, 2020 at 7:00 PM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    Famous last words. You're either stripping the top of the bumper and replacing a support bracket, or taking a cutoff wheel to the factory one. I would take the cutoff wheel route if I were to do it again.
    Only for the driver's side.
  24. Apr 20, 2020 at 7:08 PM
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    That’s hard to do with a tonneau cover lol , I’ve learned that with our new truck !
