Is the fluid on the actuator transmission fluid ?
Discussion in '1st Gen Tundras (2000-2006)' started by Dolfimus_prime, May 14, 2024.
  1. May 14, 2024 at 10:50 AM
    Dolfimus_prime
    Dolfimus_prime [OP] New Member
    2006 Black DC
    GX460 brake caliper & rotor upgrade.
    Had this replaced back in August. Saw a wet spot on my drive way and that’s when I saw this. IMG_5914.jpg
  2. May 14, 2024 at 10:53 AM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I would agree, she is seeping
  3. May 14, 2024 at 11:12 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    That's your transfer case 4WD actuator. So no. Not transmission fluid.
  4. May 14, 2024 at 12:56 PM
    Dolfimus_prime
    2006 Black DC
    If it isn’t, What fluid could it be?
  5. May 14, 2024 at 1:10 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
  6. May 14, 2024 at 5:41 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The t case fluid flows into the actuator to help keep it lubed, the screws holding the triangle plate might be loose, give em a snugging up with a PH4(?) and plastic cover
    FrenchToasty likes this.
  7. May 14, 2024 at 5:52 PM
    shifty` Waving My Dick In The Wind
    Check the vent tube while you're there.
    FrenchToasty and Tundra2[QUOTED] like this.
  8. May 14, 2024 at 5:54 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @empty_lord had said it in crackies thread around chrimmas of 21(?)
    FrenchToasty and shifty` like this.
  9. May 14, 2024 at 8:45 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Looks like maybe the o ring was compromised when they swapped In the new unit
    KNABORES likes this.
