Is the 4.7L an iron block? Coolant dirty.
Discussion in '1st Gen Tundras (2000-2006)' started by atikovi, Sep 2, 2021.
  1. Sep 4, 2021 at 9:58 AM
    atikovi
    atikovi [OP] New Member
    Suburban Washington DC
    And what happens when it goes down to -50F and your block cracks?
  2. Sep 4, 2021 at 10:29 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Canada has a 55/45% coolant to water mix good to -50 something degrees. The US gets 50/50.
    At least according to the owners manual.
  3. Sep 4, 2021 at 10:34 AM
    atikovi
    Do any national chain stores carry this brand?
  4. Sep 4, 2021 at 10:42 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    You buy a block heater if you're going to stay in that cold a climate.
  5. Sep 4, 2021 at 10:44 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Paging @Outbound
    Do you mix with Canadian whiskey to prevent freezing?
    Sunnier, Darkness and Jack McCarthy like this.
  6. Sep 4, 2021 at 10:46 AM
    Outbound
    Aaron
    Northern Alberta
    Can confirm.
  7. Sep 4, 2021 at 11:00 AM
    atikovi
    That's primarily for easier starting. What it the power goes out? Don't most people up there run 70% antifreeze?
  8. Sep 4, 2021 at 11:39 AM
    Enema style.
    AZBoatHauler likes this.
  9. Sep 4, 2021 at 11:53 AM
    Jack McCarthy
    Bill
    North of Boston
    Pray your freeze plugs on the block work otherwise get a backup generator system that automatically kicks on when needed. I can't comment on the 70% antifreeze mixture.
  10. Sep 4, 2021 at 11:57 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    How cold does it get where you are? How much water do you think is still in the block? How can you make a perfect ratio mixture without knowing precisely? Why does it matter so much if you're selling it?
    Desert Dog, Sunnier, BubbaW and 3 others like this.
  11. Sep 4, 2021 at 12:13 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    w666 and FirstGenVol like this.
  12. Sep 4, 2021 at 12:17 PM
    Jack McCarthy
    Bill
    North of Boston
    All hypotheticals because the last owner might've driven it to the arctic circle where the block cracked. :D
    Seriously, OP I wouldn't be too concerned unless you plan to keep the vehicle.
  13. Sep 4, 2021 at 12:21 PM
    FrenchToasty
    Mo
    Bone stock
    Like a lot
    Sunnier likes this.
  14. Sep 4, 2021 at 12:39 PM
    Cody06tundra
    Cody06tundra New Member
    Cody
    2006 Tundra Crew Cab SR5 4.7L
    You can buy heaters that warm up the coolant.
  15. Sep 4, 2021 at 1:04 PM
    atikovi
    Can't find that OEM brand around here so will go with Peak.
    Schcoman likes this.
  16. Sep 4, 2021 at 3:55 PM
    Jack McCarthy
    Bill
    North of Boston
  17. Sep 5, 2021 at 2:23 AM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Yep, slap something in it and let it be the next guys problem.
  18. Apr 24, 2023 at 6:56 AM
    bron-yr-aur
    bron-yr-aur New Member
    Ché Calvo
    Windber, PA
    2004 DC 4x4/Tow pckg
    Mods: zip-tied PS line and tire shine
    Just wanted to add this for anyone doing research here. The previous pics of the rusty looking orange coolant are perfectly normal. The coolant is translucent and the black container is giving that appearance. Mine looked exactly the same when doing my timing belt and I drained it into the same container, which gave me some concern. Then I poured it into an old windshield washer fluid bottle (translucent but clear with no color) for disposal. The bottle is completely pink.
    Redoak, jimf909, bmf4069 and 3 others like this.
