Is My Truck Lifted?
Discussion in '1st Gen Tundras (2000-2006)' started by DanielDD, Dec 15, 2020.
  1. Dec 15, 2020 at 9:02 AM
    DanielDD
    DanielDD [OP] Too Old to Rock and Roll and Too Young to Die
    2001 TRD Tundra
    I know its a silly question, but I seriously don't know. I'm looking to replace the tires because when I bought it, someone put oversize tires on it and they rub on the front suspension. The current tire size is LT285/75/R16. I plan on going back with the standard 265/70R16
    While I was looking underneath, I noticed the rear springs have a 4/1 setup rather than the 3/1 that I thought was stock. This is a 4x4 TRD, so I don't know if that makes any difference or not. I have a couple of pictures to see if you can help me decide whether this is a stock configuration or someone has lifted it.
    tunyota likes this.
  2. Dec 15, 2020 at 9:29 AM
    Front definitely has some interesting lift spacers in there. TRD coils. Upper ball joint looks a little suspect. Rear suspension appears factory ( edit - does appear to have an extra leaf installed).
    FYI, someone stole your spare tire.
    BTBAKER, FlyingWolfe, abcinv and 3 others like this.
  3. Dec 15, 2020 at 9:43 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm pretty certain the trucks with the TRD package had 1 more leaf than the others. So I don't think someone added a single leaf.
  4. Dec 15, 2020 at 10:13 AM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    Interesting is a nice way to put it.
    270Fan likes this.
  5. Dec 15, 2020 at 10:24 AM
    DanielDD
    2001 TRD Tundra
    So, I take it that those spacers on the front coil are not stock?
    And yes, the spare is gone. I bought it like that. Haven't had a chance to raid the junk yards for a replacement yet..
    tunyota likes this.
  6. Dec 15, 2020 at 10:37 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Where you located? I have a never used 2016 spare tire sitting in the backyard that I keep forgetting to throw away.
    Toyotoholic and GIN•OKUMA like this.
  7. Dec 15, 2020 at 10:39 AM
    DanielDD
    2001 TRD Tundra
    Southern Tennessee... Not in your neck of the woods...
    Appreciate the offer, though.
  8. Dec 15, 2020 at 10:41 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    This is the 1st gen section. We have 6 lugs, not 5. So that 2016 won't work.
    Hbjeff and Darkness like this.
  9. Dec 15, 2020 at 10:52 AM
    GIN•OKUMA
    Fish
    26.57°
    Still a kind gesture. :hattip:
  10. Dec 15, 2020 at 10:54 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yes it was. @Cruzer sorry if that came across as rude
  11. Dec 15, 2020 at 11:38 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    No worries! I was eager to get rid of the spare didn't see which section of the forum I was in. :D
    GIN•OKUMA likes this.
  12. Dec 15, 2020 at 11:58 AM
    Is this true? My 2000 TRD has 3 leafs + an overload for a total of 4.
  13. Dec 15, 2020 at 1:10 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Do you have a closer picture of the rear leafs? Try to get one right by where it sits on the axle. You could have 4 leafs or an add a leaf.
    Also, what are your measurements from hub to fender on each wheel?
  14. Dec 15, 2020 at 1:13 PM
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    measure from center of hub/center cap to bottom of fender. for ex gen2 stock size is 22" front and 24" rear. So if I measured and get 25" front and back then lifted at 3/1.
  15. Dec 15, 2020 at 1:23 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I thought it was. It's been discussed here in the past that the TRD offroad package got you Bilstein shocks and one more leaf.
    @speedtre am I imagining this?
  16. Dec 15, 2020 at 1:53 PM
    Arringtonpalmer
    Arringtonpalmer New Member
    Sam
    New Hampshire
    2004 Limited Double Cab
    ARB Bumper, Warn Evo, UTE H66 tray, OME 2884 and Nitrochargers.
    My 2003 TRD has 3/1 as well.
  17. Dec 15, 2020 at 2:01 PM
    DanielDD
    2001 TRD Tundra
    As requested. I think someone added some stuff.....
  18. Dec 15, 2020 at 2:16 PM
    one of these is not like the others
  19. Dec 15, 2020 at 2:37 PM
    DanielDD
    2001 TRD Tundra
    Quick measurement from center hub to inner fender: Front 22.25inches, Rear 23.50inches
    All numbers are approximate...
  20. Dec 15, 2020 at 2:44 PM
    Professional Hand Model
    Hand Protectors
  21. Dec 15, 2020 at 2:49 PM
    Hand Protectors
  22. Dec 15, 2020 at 2:50 PM
    Hand Protectors
    TuRD Package Leafs on mine is 3 plus 1.
    Looks like some weird Bobo Type Bushings on the Front Coils.
  23. Dec 15, 2020 at 2:54 PM
    DanielDD
    2001 TRD Tundra
    Yeah, not good then. That means the entire suspension will have to be reworked. My lift won't be here until mid/late January and I don't have any heat in my shop yet. Will have to get a quote from the local auto repair shop to fix these blunders before I put new shoes on her. OR, I wait till Spring and deal with it then....
    Merry Christmas to me!
  24. Dec 16, 2020 at 8:48 AM
    rock climber
    Is it giving you issues right now? If not, go ahead on the new tires and get new suspension when you're ready.
  25. Dec 16, 2020 at 9:40 AM
    DanielDD
    2001 TRD Tundra
    No immediate issues at the moment. But as you know when you get new tires, it is always good to get an alignment. I am sure that when they do an alignment, since the truck has 240K miles on it, there will be some front suspension needs before they can put it within spec. I already know the 2 front differential half shafts will need to be replaced as the boots are torn. This whole thing could literally snowball with repair/replacement parts/costs.
    Got to weigh the cost vs benefit issue....
  26. Dec 16, 2020 at 10:18 AM
    rock climber
    Makes sense. You can always take it in to wherever you are going to get the alignment and ask them to do a little precheck and see if they think they'll be able to get it aligned as is.
  27. Dec 16, 2020 at 6:34 PM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    Looks like some kinda tripple isolator on the front spring, super wacky, but not cracked or crooked. looks like about 3/4 inch front lift just from the extra cushions.
  28. Dec 16, 2020 at 6:48 PM
    DanielDD
    2001 TRD Tundra
    I don't know what it is. Never seen it before. Personally, and this is just me, but I wish I would have bought this truck without someone making these types of modifications. Now, I have to undo these things in order to bring it back into a correct suspension setup.
  29. Dec 17, 2020 at 1:02 AM
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    Save yourself $800+ if you were considering buying new OEM front driveshaft assemblies and instead just buy new OEM boot kits. It seems pretty simple to remove the front driveshafts if you have the tools and time.
    https://www.toyotapartsdeal.com/page_product/pl?vin=5TBKT42136S476027&filter=()&subCategoryUrl=power_train_chassis/front_drive_shaft&diagram=&partNumbers=&pnc=04438
    https://www.youtube.com/watch?v=AEcQLCTA4jA
    https://www.youtube.com/watch?v=gt4JIp16DVI
  30. Dec 17, 2020 at 4:50 AM
    Hand Protectors
    You make a great point. I see many a mangle job on our trucks passing through the pages here mostly associated with poor suspension work. They are either in the process of mangling their pristine GranPa Truck or unmangling it like you are going through.
