Is it necessary to have your cat back exhaust system welded or is it just a waste of dollars?
Discussion in '2nd Gen Tundras (2007-2013)' started by pacman_gptx, Apr 30, 2015.
  1. Apr 30, 2015 at 8:54 AM
    pacman_gptx
    pacman_gptx [OP] New Member
    Paco
    2012 5.7L Magnetic Grey Metallic Crewmax SR5 Texas Edition
    Interior LEDs, Cargo/Reverse LEDs, Foot Well LEDs, McGard Tailgate Anti-Theft, Pilot Stubby Antenna
    I've seen exhaust systems clamped together and I've seen them welded, which is better in the long run? Does it make a difference? What do the manufacturers say?
    Your thoughts, opinions, and comments are appreciated.
  2. Apr 30, 2015 at 11:13 AM
    Welded...more durability ...I think. Idk much on exhausts. Currently saving for a TRD exhaust.
  3. Apr 30, 2015 at 11:15 AM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Clamping is all you need.
  4. Apr 30, 2015 at 11:48 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    As long as it's a well made kit then the clamps are sufficient, but if the kit is loose fitting or doesnt have enough overlap to clamp securely it should get welded. I've had kits in the past that only slid together maybe a 1/2 " and would vibrate apart, I decided to weld that one up after the muffler fell out when I was offroad. On my Tundra my MBRP fit together very well and has been on there for several thousand miles clamped together with no problem at all.
  5. Apr 30, 2015 at 1:42 PM
    Mike Tread lightly.
    south carolina
    I have a borla exhaust on mine, and mine is clamped. NO issues and no leaks for what its worth been on the truck i think 3 years now. Just make sure you clean off the clamp an the connect surface if you have rust and your gold.
  6. Apr 30, 2015 at 2:53 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Factory is clamped. :p
  7. Apr 30, 2015 at 2:57 PM
    dandailey
    Dan D
    Newport News Va.
    So are the aftermarket TRD duals.
  8. Apr 30, 2015 at 4:08 PM
    chphilo
    chphilo Tundra addict
    Western PA
    Most top of the line cat-back kits clamp on, if that tells you anything.
  9. Apr 30, 2015 at 11:19 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Clamp it
  10. May 1, 2015 at 5:55 AM
    That's exactly what I told my wife to do.
    ....and then I woke up.
    Mike and UPSed like this.
