Is an AUTO LSD button a common option?
Discussion in '1st Gen Tundras (2000-2006)' started by Grumpy74, Feb 3, 2022.
  1. Feb 4, 2022 at 8:48 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I'd love to have that but I need a limited slip first. Almost had one but the sales guy wanted me to pay $400 over invoice for it.
    Looking back on that decision it would have been worth it.
    Grumpy74[QUOTED][OP] likes this.
  2. Feb 4, 2022 at 8:49 PM
    Jack McCarthy
    Bill
    North of Boston
    I'm surprised we don't have a auto-4wd for our trucks even today or did they change that with the 2022?
    Grumpy74[OP] likes this.
  3. Feb 5, 2022 at 3:45 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
  4. Feb 5, 2022 at 5:14 AM
    Retired...finally
    To protect that expensive master cylinder consider changing your brake fluid. If unable to do a complete flush at least get a turkey baster and suck out as much of the old and replace it with fresh fluid every few months. Doing this a few times will at least help prevent rusting of the internal components.
    speedtre likes this.
  5. Feb 5, 2022 at 6:46 AM
    Jack McCarthy
    Bill
    North of Boston
    Grumpy74[OP], shifty` and N84434 like this.
  6. Feb 5, 2022 at 8:15 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    You’re gonna have to run that truck through the website window sticker thing. Im curious what option group had hydroboost.
  7. Feb 5, 2022 at 8:48 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I wonder if this master cylinder setup gives 4-point ABS with independent brake lines to the wheel cylinders in the rear.
    DaWhiteTundra likes this.
  8. Feb 5, 2022 at 8:58 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    maybe its a white truck thing.
  9. Feb 6, 2022 at 3:29 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Some 4Runners and Tacomas) as far back as '98, had electric locking/unlocking center diffs in the transfer case. I had one in my '02 SR5. It was great for winter driving when you have a mix of snow/ice and dry pavement -- which we get frequently here in New England. You get open diff AWD for mixed conditions, and when you encounter low traction conditions, you lock the center diff and you have regular 4WD.
    I'd love to swap one in to my Tundra, but I don't know if it would be possible to make it work with the ECU.
  10. Feb 6, 2022 at 5:22 AM
    Jack McCarthy
    Bill
    North of Boston
    Someone actually did that on TS years back with the same year Sequoia. I think he went by the username Crazy Ivan or something. I can't recall if he divulged all the details of what he did or not.
    A tacoma with a center diff? That would imply AWD capability. This is the first I've heard of that.
  11. Feb 6, 2022 at 5:35 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I dug around looking at LC tcases, but jumped to the conclusion thats not what i wanna do.
    i think i might like to hotwire the front diff actuator with a switch and momentary button. So i can have it on like normal, or off for 2 low, but the momentary button if i just need some help from the front axle for a couple seconds.
    but i wont need any of that until i have a bit of lift and some tires that wont get stuck in wet grass.
    Jack McCarthy likes this.
  12. Feb 6, 2022 at 6:40 AM
    tvpierce
    Maine
    I could be wrong about the Tacoma having the locking/unlocking center diff -- I've never had a 4WD Tacoma. They definitely had the push-button 4WD actuation on the transfer case lever -- I assumed the two features were bundled. Quite possibly not.
  13. Feb 6, 2022 at 6:44 AM
    tvpierce
    Maine
    The thing I don't like about the LC or Sequoia transfer case is that they are full time AWD, with no option to be in 2WD.
    des2mtn likes this.
  14. Feb 7, 2022 at 7:01 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Yea, I was only looking for DCs, so my estimate was on 2004-2006 double cabs only. For all Tundra's 2004-2006 it's probably in single digits percentage wise...
  15. Feb 7, 2022 at 10:29 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Yes...that's exactly what it's for. I almost bought a 2005 with this but ended up with a 2006 without it. If I could choose, I'd get one with out it....it's one of the simpler less complicated things I liked about the FGTs (brake upgrades are MUCH simpler without it for example). Having said that, I think the Auto-LSD/VSC is a very nice feature for a truck that will spend 95% of it's life on pavement and is probably preferable to a mechanical lsd in nearly all pavement situations and if everything else about the truck was right it would not stop me from buying one...the issue as we all know is the cost if it breaks. I'm not sure if there is any preventative maintenance that can be done to help extend it's life (maybe more frequent brake fluid flushes...?) but if I had this setup, I'd research that possibility and do it religiously... :D
  16. Feb 7, 2022 at 11:20 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    At least the early Sequoias can be 2wd, AWD and 4wd. When I turn off the 4wd button it's just rwd, then when I turn on 4wd, it's really AWD, and then when I put it in 4lo and the gear selector in 1st gear, then it's true 4wd with the transfer case locked.
  17. Feb 7, 2022 at 12:26 PM
    tvpierce
    Maine
    Interesting... so you can't lock the center diff without being in 4lo?
  18. Feb 7, 2022 at 1:21 PM
    rock climber
    Yeah 4 lo and 1st gear. It's kind of annoying. I think the later ones were easier. There's a few different transfer case options for the 1st gen sequoias :der:
  19. Feb 7, 2022 at 1:51 PM
    #49
    Jack McCarthy
    Bill
    North of Boston
    Interesting. If I read that thread correctly, the Sequoia in 2008 has a new transfer case that integrates the center differential? Nice. Only downside was having to shorten one of the driveshafts by 1/2" to make it work.
  20. Feb 7, 2022 at 5:20 PM
    #50
    Mertokirk
    Mertokirk New Member
    Eastern Pennsylvania
    2001 Tundra Extended Cab SR5
    17" Level 8 MK6 wheels Falken Wildpeak AT3W tires, leveled with Bilstein 5100 shocks all around.
    I had some Auto LSD at a Dead show once. The fractals where…automatic.
    tvpierce and bmf4069 like this.
  21. Apr 28, 2022 at 11:59 AM
    #51
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    IMHM, some dude was asking about my truck a while back and told me his Gen 2 was working fine in 4WD but then got all "jumpy". I asked him if he had just got onto the pavement...
  22. Apr 28, 2022 at 12:27 PM
    #52
    Jack McCarthy
    Bill
    North of Boston
    He probably thought it was okay since the toyota salespeople have no issue with you popping it into 4wd going 40 mph on the parkway while out on your test drive. :rofl:
  23. Apr 28, 2022 at 12:30 PM
    #53
    alb1k
    Left Coast
    It's good
    :yes:
  24. Apr 28, 2022 at 3:39 PM
    #54
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    My Sr5 06’ has the button and the fancy master cylinder.
    The Auto LSD button lets me do burn outs and spin both tires. With the button off, traction control kicks in as soon as a tire slips and cuts power.
  25. Apr 28, 2022 at 3:49 PM
    #55
    Grumpy74
    Grumpy74 [OP] New Member
    2005 White Tundra SR5
    That's the only annoying thing about this truck. When the traction control kicks in, it cuts power way too much.
  26. Apr 29, 2022 at 5:05 PM
    #56
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Yeah, I’d be really curious for you to jump on the My Toyota website and get your build sheet.
    I do a nationwide AutoTrader search for these trucks every month or so and I can say, with confidence, that I’ve seen less than 10 of these buttons.
    Honestly, I think every single one that I’ve seen, was on a limited. If I’m seeing your picture correct, you may have an extremely rare SR5.
  27. Apr 29, 2022 at 5:18 PM
    #57
    Grumpy74
    I'll look into it. It sounds like a unicorn for sure.
  28. Apr 29, 2022 at 5:51 PM
    #58
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I've got an SR5 with it. As far as I'm concerned, it's not something to be proud of. It's a curse, not a blessing.
    FirstGenVol likes this.
  29. Apr 29, 2022 at 7:27 PM
    #59
    Definitely not a desirable option. I suspect it's why you don't see a ton of trucks with it.
  30. Apr 30, 2022 at 3:16 PM
    #60
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    If it’s predominantly Limited rigs that have it, that would indicate it actually was desirable. At least that’s what people would have thought at the time, having no experience driving it.
