Is 2nd Gen Worth It?
Discussion in '1st Gen Tundras (2000-2006)' started by TMO82, Feb 10, 2025.
  1. Feb 10, 2025 at 7:17 PM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    That looks like them, though no idea on the ARP part number, I used OEM. Also, now I think about it, it was 2004 that was the crossover year, but still bookmark that site! It's great for looking up part numbers.
  2. Feb 11, 2025 at 10:28 AM
    TMO82
    TMO82 [OP] New Member
    Tj
    Lehigh Valley, Pennsylvania
    03 Tundra TRD Limited
    Many on the list
    Thanks Shifty. The ones I have posted above were a little cheaper. These already shipped so hopefully they will be here soon.
  3. Feb 14, 2025 at 11:14 AM
    TMO82
    Tj
    Many on the list
    Ok. I now have the LBJ that come from Toyota. In the next couple days I will have the new bolts, the Aisin timing belt kit, Denso Iridium plugs, and my new head unit (with rear camera). Now that I have the truck I have had time to look over the entire vehicle. It will need a heavy, heavy detail but overall is in pretty good condition. The frame was coated by Toyota at some point and after looking it over it is in really good shape. Just basic surface rust. The very next thing on the operating table will be the upper control arms. They are pretty rusted out. At the same time as doing that I am going to put in the Bilstein 4600s and the 2" leveler. Beyond that I will have to play it by ear as to what else I need to do. Thank all of you for the help and knowledge, it is very much appreciated. I'll upload some pictures once I get a chance to caught up on things.
    G_unit3000 likes this.
  4. Feb 14, 2025 at 6:52 PM
    If the frame was coated by Toyota, it means it was in bad enough shape at one point and the owner gave Toyota two choices: Replace the frame, or put lipstick on a pig. Based on what you've said, they chose lipstick on a pig. The coating Toyota used didn't actually fix or even stop the rust, it just covered the damage for a few years while the frame continued to rot inside.
    I hope I'm wrong, but what I just described is typically what we see here. Over. And over. And over again.
    I would not use strut spacing "levelers" to level your truck. It sounds like that's what you're describing. Cue @FishNinja.
  5. Feb 15, 2025 at 2:31 PM
    TMO82
    Tj
    Many on the list
    Could be. The reports from the dealer say no major rust found. I don't trust dealers for much of anything. I've seen rusted out frames before though and this one doesn't look like those. Ultimately though, I didn't pay anything for it, and yes I'll lose the investment of parts I'm putting into it if something should happen, but that's the gamble. Time will tell.
