Irrigation question
Discussion in 'Off-Topic Discussion' started by T-Rex266, May 12, 2019.
  1. May 12, 2019 at 4:54 PM
    T-Rex266 [OP] Moderator Staff Member
    When turning your sprinklers back on for the season, is this valve correct or do I need to open it (clockwise)?
  2. May 12, 2019 at 5:06 PM
    Twinky
    07 double cab work horse
    Custom speed dent. Saving up for matching driver side speed dent.
    Is that cut off valve conected to something else? Or is that a submerged system?
  3. May 12, 2019 at 5:28 PM
    :notsure: Should be all sprinklers
  4. May 12, 2019 at 6:10 PM
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    That valve looks like where they hook up to blowout the system for winter. I think. And should be off like it is. I could be wrong. Assume the blue valve is what you talking about.
    PotentPotables, 15whtrd and landphil like this.
  5. May 12, 2019 at 6:15 PM
    Patch999
    Patch999 You are what you do when it counts
    Kyle
    TX
    2015 Bad@$$ Tundra
    Wish I could help. I was flipping them off and on until I got it to work. Never bothered with winterizing the system until last year. This year I’ll pay closer attention.
  6. May 12, 2019 at 6:16 PM
    War Machine
    War Machine Premium Elite Member
    Houston, Texas
    2017 Black Crewmax SR5 Blaaaack
    That’s my technique also.
    COMiamiFan and Patch999 like this.
  7. May 12, 2019 at 6:22 PM
    Leo's first
    Leo's first Hey Adam! I’m not new anymore
    Groton ma
    That is a blowout port or drain leave it closed turn main water on run system through controller to check zones program controller to your needs
    Do you have back flow preventer?usually a brass bell looking thing on house where main water comes out
  8. May 12, 2019 at 6:29 PM
    JC303
    JC303 Same same but different
    Justin
    2012 Tundra 5.7
    I would leave that as is. Make sure your water is off before the valve and then turn in the water to your sprinklers on from the basement? Make sure all the vents are closed and no leaks then turn on the water slowly before the valve. Check for leaks. Valve might leak for a second from pressure.
    T-Rex266 [OP] likes this.
  9. May 12, 2019 at 6:29 PM
    Black@Blue19
    Black@Blue19 New Member
    Ken
    45 Gulf Freeway South
    19Tundra TRD Sport 4X4 CrewMAX
    TRD upgrades, everything except leather, sunroof, and electric passenger seat
    Don’t turn that one!! You’ll have water where you don’t want it!!:(. Look for the main going into all of those off your main and then follow directions above. But I’m thinking if nothing was touched then turn on the main to the sprinkler system and power (breaker) to the system and timers and all should work?? Good luck?
  10. May 12, 2019 at 6:53 PM
    I turned on the sprinklers from the basement for the irrigation line and opened the valves on the backflow. Seems to have worked
    15whtrd, Stroke250, Bob and 4 others like this.
  11. May 12, 2019 at 8:33 PM
    BTBAKER
    BTBAKER THE AVS GOT SCREWED.
    Brad
    Castle Rock
    2017 Tundra TRD limited
    That stays off. I have on occasion cracked that open after blow out to allow any remaining water in the lines a way to escape before freezing. If you do that make sure to close it before starting your system again.
  12. May 13, 2019 at 8:53 AM
    Lee's rig
    Lee's rig Party naked
    Lee
    North nj
    2014 DC and 2014 single cab both 8' bed with 5.7
    To many
    you are in luck! i own an irrigation company.
    that definalety should be off other wise it will continuously leak from there . looks like a blow out connection to me.
    the solenoids on the valves need to be hand tight . if they are not one valve or all valves may run and not shut down. also if the black bleeder screws should be hand tight
    15whtrd and T-Rex266 [OP] like this.
  13. May 13, 2019 at 8:56 AM
    Lee's rig
    Lee
    North nj
    To many
    i do not know why they would put a blow out in that location. i put my blow out at the exit of the house and before the p.v.b. so i can blow everything out from the source.
    also have no idea why they made a u shaped manifold other than being cheap and trying to fit more valve in a box than is supposed to be in there
  14. May 13, 2019 at 10:20 AM
    I vaguely remember blowing it out from there for shut off in the winter. I did tighten (hand) the valves to off.
    So is the valve in the right position or do I need to turn it? :help:
    BTBAKER likes this.
  15. May 13, 2019 at 10:32 AM
    Lee's rig
    Lee
    North nj
    To many
    it is correct.
  16. May 13, 2019 at 6:42 PM
    BTBAKER
    Brad
    Castle Rock
    It’s fine. Leave it like that. That is IMO not an ideal blow out spot. I run a quick connect just before my back flow preventer. You air up the system and turn each zone on until no more water. I’ll send a pic if it helps.
  17. May 13, 2019 at 6:43 PM
    BTBAKER
    Brad
    Castle Rock
  18. May 13, 2019 at 6:45 PM
    BTBAKER
    Brad
    Castle Rock
    That pic is when I had it blown out. Buy a quick connect and you can leave it there permanently.
  19. May 13, 2019 at 7:02 PM
    Thanks gents!
    BTBAKER likes this.
  20. May 13, 2019 at 8:00 PM
    15whtrd
    15whtrd Mr. Blonde
    TRD Pro suspension, +2 Coachbuilder shackles, 2015 TRD Pro headlights, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats front and rear, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, aluminum oil filter canister, Real truck tailgate seal, Pop-n-lock tailgate lock actuator, rear diff breather relocate.
    Test “COCK” #1
  21. May 13, 2019 at 8:15 PM
    BTBAKER
    Brad
    Castle Rock
    Just tested it. It’s not what it used to be.:eek:
    15whtrd likes this.
  22. May 13, 2019 at 8:27 PM
    15whtrd
    15whtrd Mr. Blonde
    BTBAKER likes this.
  23. May 14, 2019 at 7:12 PM
    BTBAKER
    Brad
    Castle Rock
    For reference, this is how I leave mine all the time. I have a medium size compressor and I bought one of those cheaper pig tail yellow hoses that are mobile. Roll it over there and pressurize the system. Turn on each zone, done.
    JC303 likes this.
