Ironman Raid front bumper
Discussion in '2.5 Gen Tundras (2014-2021)' started by mundra, Nov 20, 2024.
  1. Jan 8, 2025 at 6:45 AM
    #61
    mundra
    mundra [OP] New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    here is mine with the TRD skid plate. This is the side view if it helps
    bulldog93 and batman900 like this.
  2. Jan 8, 2025 at 6:49 AM
    #62
    mundra
    2019 platinum 4x4
    I can get a pic with the new red tow hooks if you need them. The bolts were long enough to go through the skid plate and new tow hooks. Looking at the Talons skid plate it looks like it mounts the same as the TRD skid. Possibly compare this side view to your current Talons skid but from online viewing "I don't have a Talons skid" they look the same. If you need more pics of the bumper with the TRD skid let me know I would be happy to help you.
    23Tundy likes this.
  3. Jan 8, 2025 at 9:08 AM
    #63
    mundra
    2019 platinum 4x4
    The skid plate just needs to be tight against the frame rails.. I suggest use a floor jack to press the skid plate against the frame by placing it in the middle of the skid to apply pressure. But, no it was fairly easy to do. A second set of hands is needed on the bumper to make it easier though.
    batman900[QUOTED] likes this.
  4. Jan 8, 2025 at 2:14 PM
    #64
    23Tundy
    23Tundy New Member
    SE Pa
    19 SR5 Cement crewmax
    5100s,Diode Dyn fogs, ARE topper, AJT interior chrome delete, meso lights/vleds, RC neoprene seat covers.
    Awesome! Thank you for the pics, ill go back and review the Talon install and compare. Thank you for the visual aid.
  5. Mar 25, 2025 at 5:12 PM
    #65
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    I am currently in the process of designing a laser cut/steel bent lighting cross bar that will bolt to the top of the bumper (only about 1" tall) to mount 4 larger lights to the front Baja style. It would push the lights out front a little bit farther so brackets would clear the grill. Would any body be interested in buying something like that for their bumper if I had a few made? Still working on cost, just judging interest.
  6. Mar 25, 2025 at 5:13 PM
    #66
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    Curious to what it would be attached to? One of the removable top plates?
  7. Mar 25, 2025 at 5:14 PM
    #67
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Thats the current working theory. A half inch bolt through the first set of top wings.
  8. Mar 25, 2025 at 5:20 PM
    #68
    littlebus01
    littlebus01 New Member
    Tobias
    21 trd off-road
    Iron Man lift, still-cai, list goes on
    Sounds great can’t wait to see your results
  9. Mar 30, 2025 at 11:54 AM
    #69
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Light bar update. Having it made out of 11ga (1/8") Cold Rolled Steel.
    Should be here in 2 weeks. Will powder coat locally to match the bumper if it all works out.
    These are from the bottom side.
    Tboh1870 likes this.
  10. Apr 13, 2025 at 12:09 PM
    #70
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Ok lighting cross bar update. The first one didn't turn out exactly how I wanted it too. I need a slight redesign of moving the mounting tabs 1.5-2 inches backwards to clear to tubing of the bumper. Also need to raise it about 1/8inch for some extra bolt clearance. Also not sure if i should make the whole thing shorter in length so that there isnt any overhang on the first angle backwards?
  11. Apr 14, 2025 at 7:03 AM
    #71
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    Before doing any other design iterations try putting a light on there as well. The mounting slots near the center look like they may place a light too close to the lower painted part of the grill.
  12. Apr 14, 2025 at 8:15 AM
    #72
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Yes it does. i need the bar to run over the tubing. So i have to push the mounting tabs back a few inches so i can push the bar farther forward. But when i do that i dont like the overhang of the bumper.
  13. Apr 14, 2025 at 11:18 AM
    #73
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    Why not do something like this? (sorry for the crude, quick model)
  14. Apr 14, 2025 at 1:37 PM
    #74
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    First of all sick model. Thats actually what Im working towards now with the design. Slightly different but close. There is not enough room to mount lights on the bend backwards. But going to try to make it follow the bumper lines better.
    IMXPLRN[QUOTED] likes this.
  15. Apr 14, 2025 at 1:56 PM
    #75
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    Thanks. I do this sort of stuff for a living so if you have any questions or want to bounce an idea around feel free to reach out. I do all the design work and prototyping at the company I work for, which includes programming our CNC press brake, machining, etc.
    Yota303 and jmevis[QUOTED] like this.
  16. Apr 14, 2025 at 4:53 PM
    #76
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Dang wish I knew that before I hired someone from Fiverr for the STEP file
  17. Apr 14, 2025 at 5:15 PM
    #77
    Cthulhu
    I have been looking for a way to mount baja lights as well, especially a way to remove the lights first, then remove the grille. What about drilling rivet nuts into the top plates, removing the need for a bar altogether?
  18. Apr 14, 2025 at 5:29 PM
    #78
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Doing it that way puts them too close to the grill that it makes contact. If you'd like after I finish this design and have a good working model, Ill sell you one.
  19. Apr 14, 2025 at 5:49 PM
    #79
    Cthulhu
    Gotcha. When you settle on the final design, let me know. :thumbsup:
    jmevis[QUOTED] likes this.
  20. Apr 17, 2025 at 8:01 AM
    #80
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Here is the updated design that I sent to manufacturing. Screenshot 2025-04-17 at 9.57.24 AM.jpg
    I might have the tabs welded together and smooth them out unless it looks fine in person.
    Cthulhu[QUOTED] and TRDFerguson like this.
  21. Apr 17, 2025 at 8:06 AM
    #81
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I don’t hate this. My wife might though. Which makes it even more enticing.
    BillyB, Mater and RobertD like this.
  22. Apr 17, 2025 at 8:42 AM
    #82
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    :rofl:Let me know if you want one, after I confirm its good to go.
    TRDFerguson[QUOTED] likes this.
  23. Apr 28, 2025 at 7:40 AM
    #83
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Revision 2 showed up today! i just need to get it powder coated and i might take it in to a welder to get the gaps filled in.
    MadMaxCanon, TRDFerguson and RobertD like this.
  24. May 6, 2025 at 10:01 AM
    #84
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Lighting Cross bar update! I got the gaps welded/filled and powder coated to match it looks great I should be able to wrap this project up this week. IMG_6382.jpg
    TRDFerguson and bulldog93 like this.
  25. May 6, 2025 at 12:15 PM
    #85
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Looks like it should work great.
    Lights clear the grill just fine.
    Explorer and Cthulhu like this.
  26. May 6, 2025 at 12:24 PM
    #86
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    My guy is mounting the sun on his bumper! You love to see it, looks sick dude. Love the bumper and mod you have done to it. A true pioneer.
  27. May 6, 2025 at 12:58 PM
    #87
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    All the lights are from IRON MAN they seemed to have a great middle of the road light between AUX BEAM and Baja Designs its
    2x 9 inch "driving" lights and 2x 9 inch spots. If I feel like its tooooo much I can remove the middle 2 lights. Excited to get it all wired up and mounted. Ill post when its completed.
  28. May 6, 2025 at 4:27 PM
    #88
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    @TRDFerguson @Travo60 @Cthulhu @IMXPLRN @littlebus01
    Final Results! I might space them out just a little. But luckily, you can remove the whole cross bar if you need to remove the grill. Lights have no contact with the grill.
    DRL
    Headlights & Fogs on
    All Lights on
    No contact with paint.
  29. May 6, 2025 at 4:41 PM
    #89
    Cthulhu
    Great job! Looks awesome!! So what holds the bar onto the bumper? Assuming two hex head bolts like the one in the last pic? And what do the bolts screw into? That one hex bolt head looks almost like it’s under the lower lip of the grill, so curious as to how you remove the entire bar to then remove the grille?
  30. May 6, 2025 at 5:29 PM
    #90
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That turned out great. Does it have any wiggle or pretty solid with the lights? I’d be worried about some bouncing with a load of lights up there and no front mounting point, but it may be solid enough
    RobertD likes this.
