Ironman 4x4 Suspension
Discussion in 'Suspension' started by linwozzle, Apr 1, 2020.
  1. Jan 31, 2021 at 2:19 PM
    #181
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Yea lower internal pressure, no leaks from dings on the shaft, no worries about rust.
    All sounds good but my hunch is they ride harsh offroad in higher speeds (in comparison to something like dobinsons ims).
    Still probably night and day over stock, and since I don't fly don't trails at 50-60mph I doubt I need a 'race' shock.
    HulkSmurf14 and Hbjeff like this.
  2. Feb 1, 2021 at 11:43 AM
    #182
    coexplorer
    coexplorer New Member
    Graham
    Does anyone know definitively if the Ironman UCAs are extended travel? I cannot find any info on that and thought someone here might know.
  3. Feb 2, 2021 at 3:20 PM
    #183
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    If I read all this correctly, the front coilovers can only be set at 3.5inches?
  4. Feb 2, 2021 at 5:19 PM
    #184
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    No they are adjustable. I intend on setting mine at 2” and installing them when it warms up a bit. They are pre-set from Ironman at 3.5”.
  5. Feb 5, 2021 at 9:30 AM
    #185
    TundraLaw
    Northern Nevada
    how do you like the Ironman UCAs?
    I have dobinson's shocks on the way, and deciding between SPC and Ironman.
  6. Feb 5, 2021 at 9:31 AM
    #186
    TundraLaw
    Northern Nevada
    It's an OEM balljoint, so I dont know if it has a ton of mobility, but maybe someone else knows.
  7. Feb 5, 2021 at 10:36 AM
    #187
    TundraLaw
    Northern Nevada
    I contacted Ironman about the rear spring height, and they noted that was incorrect on the website, and actually 3.5 inches of lift. How did it turn out for you?
  8. Feb 5, 2021 at 1:08 PM
    #188
    coexplorer
    Graham
    I have heard that the ball joint is not usually the limiting factor in Dow travel but rather impact between the upper control arm and the coil spring. Apparently if the control arm is shaped differently than stock, it allows for further Tavel. Again, this is second hand information, so I am not sure.
  9. Feb 5, 2021 at 1:13 PM
    #189
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    This is true but the ball joint can be a limiting factor as well.
    there is a little section in this video explaining the balljoint difference
    https://youtu.be/ohUdflLnxYw
    coexplorer[QUOTED] likes this.
  10. Feb 5, 2021 at 1:59 PM
    #190
    coexplorer
    Graham
    That is helpful, thank you.
  11. Feb 6, 2021 at 12:50 PM
    #191
    TundraLaw
    Northern Nevada
    so the Ironman leaf pack with shackles nets you 2 inches of rear lift? On the website it says 4 inches.
  12. Feb 6, 2021 at 2:11 PM
    #192
    TundraLaw
    Northern Nevada
    Did you get the leafs?
  13. Feb 7, 2021 at 10:27 PM
    #193
    TundraLaw
    Northern Nevada
    looks awesome. How much weight do you have in the bed to make that 3.5in rear leaf spring lift only 2 inches?
  14. Feb 8, 2021 at 10:40 AM
    #194
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    I'm not 100% sure, I don't have these yet. But my understanding is the performance leaf pack yields closer to 2" of lift in real life. And their shackle provides no lift. I think their salesman don't actually know how much about the real world applications to be honest. There is so much conflicting information.
    I will likely purchase the performance leaf pack, and swap out the shackle for a 1 or 1.5" lift shackle. From what I hear the constant load leaf pack will ride a little extra rough when unloaded, and I don't need my truck to feel like a 1999 F-250. I do want more than 2" of lift, so this seems like an option that will work for me.
  15. Feb 12, 2021 at 5:55 PM
    #195
    Legend33
    Legend33 New Member
    Middlesex Massachusetts
    Yes, I bought the stage 2 constant load kit which comes with everything. Planning on added more weights to the ride, buy once cry once?
    The reason why I went with this kit is the price point and my main purpose for my rig is Overlanding.
    I've been driving around with the Ironman Suspension for about 2 weeks now, the rides quality is great, better than stock. Rides smooth but firm, not harsh. Once I add more weight to it. Will ride even better.
    So, if you planning on running bigger tires like I am down the road to 37s, I would get the Ironman Stage 1 kit and get a more adjustable UCA like SPC, Heims ICON UCA etc. And don't forget to buy the adjustment tool cause the kit does not come with it. As of right now the adjustment tool is backordered.
    I will run this UCA for now and try 37s down the road with it, if problem arise with Ironman UCA then I will get a new UCA.
    I hope this answers some people questions.
    Skew12 and Wallygator like this.
  16. Feb 13, 2021 at 8:59 AM
    #196
    Wallygator
    How much weight do you currently carry?
  17. Feb 13, 2021 at 9:02 AM
    #197
    Legend33
    Legend33 New Member
    Not carrying a lot of weight at the moment, it have Rock Sliders from C4. Everything all around is stock.
    Wallygator[QUOTED] likes this.
  18. Feb 13, 2021 at 1:26 PM
    #198
    TundraLaw
    Northern Nevada
    I don’t think so. You mean for like 6 inch long travel lifts?
    Does anyone on the forum run the pro forge yet?
  19. Feb 13, 2021 at 2:12 PM
    #199
    coexplorer
    Graham
    No, just for medium travel. Many aftermarket UCAs allow a bit more down travel. This is often referred to as a Mid-travel setup.
  20. Feb 17, 2021 at 10:05 PM
    #200
    Destro748
    Destro748 New Member
    H
    2018 Cement
    It's more than 2". I spoke w a rep because the info on their website originally had 2", now I see 2.5" and 4". Rep said it should be 3.5" all around. Here's how mine looks. 20210217_171932.jpg
    AggiePhil, Skew12 and Wallygator like this.
  21. Feb 17, 2021 at 10:07 PM
    #201
    TundraLaw
    Northern Nevada
    Nice! Thank you. Looks great. How is the steering and driving with the UCAs?
  22. Feb 17, 2021 at 10:29 PM
    #202
    Destro748
    H
    2018 Cement
    So far it's good. Not twitchy and very stable. The UCA made it fairly easy to align. I've got 295/70/18 and there's really just a slight rub at full crank when reversing. Very seldom though. No BMC or fender adjustment yet.
  23. Feb 18, 2021 at 7:38 PM
    #203
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    Anyone know if you can get 4” lift with these coilovers and are they extended travel?
  24. Feb 19, 2021 at 4:22 AM
    #204
    Ry24000
    Ry24000 New Member
    Ryan
    Carson, WA
    2019 Tundra SR5 TRD offroad Quicksand
    Debadge, ARE z series top, Ironman Foam cell pro 3" lift, SPC UCA's, ICON vector 5 & Toyo ATIII 285 75R 17, Warn 9.5XP mounted in a Victory Blitz bumper. GTR 1000LM+XTR LP Reverse Light System
    Yep they will. Read post #29
  25. Feb 19, 2021 at 4:58 AM
    #205
    Ry24000
    Ry24000 New Member
    Ryan
    Carson, WA
    I got 2 out of mine with the softer springs
  26. Feb 19, 2021 at 8:20 AM
    #206
    TundraLaw
    Northern Nevada
    I swear they don’t know what anything actually does, but they sell it well. Their packaging is really nice too. And their product is top notch.
    Wallygator likes this.
  27. Feb 19, 2021 at 12:53 PM
    #207
    Hugemoose
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Yeah I've noticed this with them. Honestly, even though I like this product, I'll probably end up going with Dobinsons. It just seems more proven and the people I talk to seem to actually understand the product.
    RJVA and TundraLaw[QUOTED] like this.
  28. Feb 19, 2021 at 1:45 PM
    #208
    rodl12
    rodl12 New Member
    Rod
    South Jersey
    2017 Tundra SR5 Double Cab
    That's probably because they're not familiar with Ironman. I just had the Stage 2 Suspension kit put on my truck and honestly I don't know how it could be any better.
    huntsonora, Enzof104, Elduder and 3 others like this.
  29. Feb 19, 2021 at 1:48 PM
    #209
    Hugemoose
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Oh don't get me wrong, I think it's a great kit!! I actually wish I had jumped on it before the price increase. I'll probably just end up with Dobinson's because I can also pick it up locally which will also help with any potential issues down the line or replacement parts.
    I've been back and forth on these for months lol
  30. Feb 19, 2021 at 1:56 PM
    #210
    rodl12
    rodl12 New Member
    Rod
    South Jersey
    The one thing that is unique with the Ironman struts is their technology using a foam cell and a huge strut that holds more oil than any other strut with a reservoir. Their struts have been used for the Aussie military for years. Check out their technology on YouTube. You're only going to do this once so for the extra money I think hands down it's a better choice.
    HulkSmurf14 and Wallygator like this.
