Ironman 4x4 Suspension
Discussion in 'Suspension' started by linwozzle, Apr 1, 2020.
  1. Jan 27, 2021 at 4:12 PM
    #151
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    On my Nissan frontier I had, it was a "1.75 inch estimated lift". It was morel like 3.
  2. Jan 27, 2021 at 4:15 PM
    #152
    PhilActual
    PhilActual New Member
    Phil
    2018 Doublecab SR5 5.7 4x4
    SDHQ ABS guards, Hondo Garage/Ram phone/GPS mounts, 275/65r18 duratracs
    My rear leafs where almost flat so 3" may be closer for me.
  3. Jan 27, 2021 at 4:16 PM
    #153
    PhilActual
    Phil
    If I was worried about hauling extra I'd go performance load and install airbags.
    Wallygator likes this.
  4. Jan 27, 2021 at 6:45 PM
    #154
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Interesting find, thank you. Yeah I never looked at the individual listing for the leaves. I have a feeling the salesman on the live chats maybe aren't 100% versed is how everything actually works.
    I would definitely rather have plenty of rake and load capacity. I'm sure the performance load are sufficient, but it's the same price for the constant load so.....I can always just remove a leaf lol
    Bravohook and Skew12 like this.
  5. Jan 28, 2021 at 8:01 AM
    #155
    cch2a
    cch2a New Member
    So for those that have adjusted them how did you get the bottom lock ring to loosen? I have spanner wrenches but can't get any movement at all. Feel like the bottom ring should be fairly easy. The set screws are loose.
  6. Jan 28, 2021 at 8:05 AM
    #156
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I think they suggest releasing some load on them...jack it up and it might be more doable
  7. Jan 28, 2021 at 8:10 AM
    #157
    cch2a
    cch2a New Member
    Thanks, I'll try that. Not really wanting to get a spring compressor.
    HulkSmurf14[QUOTED] likes this.
  8. Jan 30, 2021 at 3:02 PM
    #158
    cch2a
    cch2a New Member
    I installed my Ironman front coilovers and rear shocks split between yesterday and today. No leafpack just shocks and coilovers. I also have Coachbuilder +2 shackles and bushings in the rear. Currently measure .25" nose high. I kind of expected that but plan to add some weight to the front at some point. So hoping after it settles and I add a bumper it will drop about .25 inch.
    I have no mechanical experience and really just learned how to change my oil and diff fluid about a month ago. It was pretty intimidating to attempt this but glad I did it myself. I learned a lot. Truck will probably fall apart driving to get the alignment lol. Pics tomorrow when there is more light.
    EvoTundra, equin, Skew12 and 4 others like this.
  9. Jan 30, 2021 at 4:34 PM
    #159
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Did you get their UCA also? I’m looking at doing a kit and leaning towards dobinsons right now but the iron mans are their competition. It’s that or just refinance the house and go full bypass etc
  10. Jan 30, 2021 at 6:03 PM
    #160
    cch2a
    cch2a New Member
    I did not get their UCA yet. If they can't get it aligned then I will order them. It drives and tracks great now on a short drive around the block not that it means much. Eventually I'll get them regardless.
    HulkSmurf14 likes this.
  11. Jan 31, 2021 at 8:01 AM
    #161
    cch2a
    cch2a New Member
    Waiting on alignment to be completed. Driving to the shop my initial impression is it's a huge upgrade over my 5100s I had. Weird side effect is I use to have a small shimmy on initial acceleration that is now gone. Takes larger bumps at speed great and the aftershock vibration in the rear from big bumps is gone. Really drove great and no pull or vibrations prior to alignment. If I hadn't read you need one after lift I probably would have not gotten one as the truck showed no symptoms. I only got up to 50mph though.
    I will update y'all with what the shop says and pics in a couple hours.
    HulkSmurf14 and Skew12 like this.
  12. Jan 31, 2021 at 8:17 AM
    #162
    HulkSmurf14
    2014 Tundra Limited
    Awesome to hear! Man oh man I'm itching to echo what you've done! Snap some pics for us to drool in unison with ya!
  13. Jan 31, 2021 at 9:46 AM
    #163
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Looks great!
  14. Jan 31, 2021 at 10:09 AM
    #164
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Any Tundra lean? I know the DS and PS spring rates are different I was just wondering if that was enough. My Coilovers are still sitting in the garage waiting for better weather.
  15. Jan 31, 2021 at 10:09 AM
    #165
    cch2a
    cch2a New Member
    Got the alignment done. Shop said no issues even on stock UCAs. Rides great. Just need bigger tires and front bumper now. Here are the pics. 20210131_120006.jpg 20210131_115953.jpg
  16. Jan 31, 2021 at 10:18 AM
    #166
    Anohibian
    Anohibian New Member
    Anchorage, AK
    2018 Inferno Crewmax
    Looks awesome. That is exactly the look I want on mine and you answered my questions about running these shocks with stock springs. What size tires are you currently running?
  17. Jan 31, 2021 at 10:56 AM
    #167
    eick
    eick New Member
    Which front coils are those? The performance or the constant load?
  18. Jan 31, 2021 at 12:35 PM
    #168
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Are you sure the spring rates are different? I know the drivers side spring is a little taller but are the spring rates actually different?
  19. Jan 31, 2021 at 12:37 PM
    #169
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    Do you still have rake with that setup?
  20. Jan 31, 2021 at 12:47 PM
    #170
    TundraLaw
    Northern Nevada
    Why did some of you guys, im guessing here, choose Ironman over Dobinson IMS?
  21. Jan 31, 2021 at 12:50 PM
    #171
    cch2a
    cch2a New Member
    Hopefully this will answer questions about my setup:
    Prebuilt Front Coilovers Foam Cell Pro - Performance Load (0-110LBS)
    Foam Cell Pro Rear Shocks only (no leaf pack)
    Factory UCAs
    Coachbuilder +2 Shackles with poly bushings and carrier bearing drop
    18x9+25 SCS SR8 in solid gunmetal
    275/70r18 BFG KO2s with about 30k miles on them
    Dirty Deeds 10" Exhaust
    Color matched Pro grille and endcaps
    Pro LED Headlight Conversion and OEM LED black fogs
    Leather steering wheel swap and all black leather shift knob
    All work was done by me outside of alignment.
    Current measurements from ground to center of fender after alignment and driving it about 20 miles:
    Driver Front- 40.25"
    Passenger Front- 40.26"
    Driver Rear- 40.75"
    Passenger Rear- 40.70
  22. Jan 31, 2021 at 1:05 PM
    #172
    eick
    eick New Member
    I haven't decided yet, but when I look at these, the Ironman shocks 'appear' to be lower maintenance and heavier duty than the Dobinson IMS. The dobinsons may ride nicer. Unfortunately no one has two tundras with each set up to compare.
    Just buying front coils and struts and rear struts, when looking at these two, I also consider getting fox 2.5 fronts with 2.0 rear resi shocks. It's only a couple hundred more for a known setup. My concern is just overall maintenance, corrosion, rebuilding intervals, etc.
    That's why I continue to consider the Ironman setup
  23. Jan 31, 2021 at 1:13 PM
    #173
    Anohibian
    Anchorage, AK
    I’m looking at the Ironman since the coil overs are threaded to really dial in my front height. If the Dobinson’s had that instead of the clips it would be a toss up for me.
  24. Jan 31, 2021 at 1:14 PM
    #174
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Sorry you are correct. I think spring rates are the same but the drivers side spring is taller per Ironman’s confirmation.
  25. Jan 31, 2021 at 1:16 PM
    #175
    Black
    What makes you feel they will need less maintenance than the Dobinsons?
    TundraLaw likes this.
  26. Jan 31, 2021 at 1:36 PM
    #176
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Are Dobinsins rebuidable?
    Reasoning for the 4Runner:
    -decent warranty.
    -good reviews from lots of 4Runner/Tacoma users.
    -They are local. Coilovers are 100% rebuildable(if anything happens).
    -Just about every local dealership sells/installs both pre sale and after.
    -UCA’s included as well as sway bar extended end links.
    -Price point. Wife doesn’t need a 10k king,icon, etc. kit. Not that you asked compared to those.
    I have no clue what I’m doing with my truck though. Prior to new job I have considered duplicate setup for the tundra, BP-51’s, or maybe even lowering it. I change my mind every other day.
    AggiePhil likes this.
  27. Jan 31, 2021 at 1:39 PM
    #177
    eick
    eick New Member
    Every other day? I change mine multiple times a day!
  28. Jan 31, 2021 at 1:44 PM
    #178
    Black
    Yes.
    Juanjoolio007[QUOTED] likes this.
  29. Jan 31, 2021 at 1:58 PM
    #179
    Juanjoolio007
    Oregon
    Oh. Cool.When I did her 4Runner last summer I didn’t consider them. Again with that build it was down to Bp-51’s, Ironman and Icon stage 3-5. Icon got booted for 2 reasons 1 was price and 2 was availability. I fully intended on taking advantage of their Black Friday sale. But thanks to corona that screwed that up. I ended up starting her build early due to everything listed for Ironman.
    Out of curiosity why would you choose dobinsons over Ironman?
  30. Jan 31, 2021 at 2:00 PM
    #180
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The foam cell pro has me interested. Perhaps they run a lower internal pressure so then maybe less wear on the seals?
