Ironman 4x4 Suspension
Discussion in 'Suspension' started by linwozzle, Apr 1, 2020.
  1. Jan 17, 2021 at 11:02 PM
    #121
    tundranoob702
    tundranoob702 New Member
    2021 Tundra Trail Edition
    How's the suspension holding up?
    I am thinking of getting this set for my tundra. Whats your tire amd wheel specs?
  2. Jan 18, 2021 at 3:51 AM
    #122
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    So far very good.
    I do have SCS wheels with +25mm offset and 295/70 R18 Toyo at3
  3. Jan 18, 2021 at 6:27 AM
    #123
    Enzof104
    Enzof104 Have Trailer will Travel
    Paul
    Danbury CT
    2015 SR5 TRD OR DC, because bed size matters...
    Ironman Foam Cell Pro Lift. 2018 retro fit LED headlights, TRD grill, TRD rear sway bar.
    Well just pulled the trigger on a set or Foam Pros. Only did stage 1 since I plan to limit the lift to 3 inch or under. Can always add the UCA later. Now the wait for delivery. hoping to use my stock TRD OR wheels and get some 285/70 tires to complete the set up. Will post in a few weeks when everything is installed.
    Wallygator and LarryDangerfield like this.
  4. Jan 18, 2021 at 7:26 AM
    #124
    cch2a
    cch2a New Member
    Did you set them at 3" in the front or did you request them set at 3"?
  5. Jan 18, 2021 at 4:29 PM
    #125
    Piki
    Piki New Member
    I didn’t request anything. Just ordered stage 2 set.
    That kit came set as 10” , that is around 3.5” lift in theory.
    I have rci metal skid plates and some other equipment so I end up around 3.25” lift
    I’m still about to install SSO slim bumper and winch so I will be around 3” after all.
    Will see.
    Wallygator and Sunnier like this.
  6. Jan 19, 2021 at 4:17 AM
    #126
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Did you do the full leaf pack in the rear? I was hoping that would yield more than 2" of lift.
  7. Jan 19, 2021 at 8:52 AM
    #127
    Piki
    Piki New Member
    Yes I did. 2” lift. I have 400 pounds in the bed full time so it sits in 1”
    Wallygator and Hugemoose[QUOTED] like this.
  8. Jan 19, 2021 at 8:55 AM
    #128
    Hugemoose
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Okay thanks. So empty it should lift it around 3", but you keep 400lbs in the bed so you're only seeing a 2" lift. That's what I was hoping for, I just wasn't sure how truthful their 3.5" lift claim is. I don't want to have to go back in there and add shackles or a block unless I need to. And I imagine the constant load springs will be way too much with a typically unloaded bed.
  9. Jan 19, 2021 at 1:23 PM
    #129
    Piki
    Piki New Member
    You still can put different shackles, If you wanna go more.
    I just tell you, its very well build kit and everything working together so nice.
    I wouldn't mess with it.
    From my experience, if you trying put different parts working well together you have to know what you doing and what you like to accomplish on the end.
    Just my .2
  10. Jan 19, 2021 at 1:52 PM
    #130
    Hugemoose
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Oh don't worry I understand that. And yes I would prefer to just use the full kit, shackles and greasable bushings included. I didn't want to have to get a lift shackle if I didn't need to, so I'm glad it hear it does yield at least around 3".
    My old first gen Tundra I built my own leaf pack, and while it did work extremely well, it also kind of rode like a dump truck lol. I'm trying to avoid that this time yet still maintain the rake I desire.
    Piki[QUOTED] likes this.
  11. Jan 21, 2021 at 12:38 PM
    #131
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    I was looking at the Ironman Pro or the Eibach coil overs and building my kit to save money, but I really like the ironman kit. Is anyone running the constant rear springs unloaded? I plan to add a bumper later down the road and would rather be prepared. I don't mind a little stiffer suspension as my other truck was a 3/4 ton cummins.
  12. Jan 22, 2021 at 6:13 AM
    #132
    Hugemoose
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    I asked this question to the a little while ago, and they said unloaded it may yield around 5.5" of lift, and will probably be quite stiff. I was tempted to do the same, but I don't want excessive lift since I'll mostly be unloaded. That's why I have the Timbrens for when I put a real heavy load in.
  13. Jan 22, 2021 at 7:15 AM
    #133
    mundra
    mundra New Member
    2019 platinum 4x4
    That seems excessive lift at 5 1/2" for the rear. I would have thought maybe another 1". LOL
  14. Jan 22, 2021 at 8:40 AM
    #134
    Hugemoose
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    I agree it seemed like a lot to me too. I'm not sure if it just includes and extra leaf, or if the pack is simply built with thick/stronger leaves. I figure I'll just get the performance pack, and worse case, I'll add an AAL of some sort if I really needed to down the line.
    Wallygator likes this.
  15. Jan 22, 2021 at 9:56 AM
    #135
    Wallygator
    Yeah if that number is true this also has me second guessing the constant weight pack.
  16. Jan 22, 2021 at 10:07 AM
    #136
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    I don't know if it works the same with the tundra leaf packs, but the guys on Tacoma world were removing a leaf or two and then if they changed their setup and added more weight they were going to put a leaf or two back in.
  17. Jan 22, 2021 at 10:12 AM
    #137
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Most manufacturers recommend waiting until you are putting on the minimum weight before adding their spring package. I know a guy who looped his truck on a washboard road twice because he didn't keep the minimum weight on the truck. He learned after the second time as he made contact with another vehicle.
  18. Jan 22, 2021 at 11:13 AM
    #138
    Hugemoose
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    They have a pretty great live chat on their website, so you could always ask more specific questions there about the leaf pack.
    I'm tempted to reach out to them again because there doesn't see to be a price difference between the two packs. If it really is just an additional leaf, I'll gladly take a leaf out myself and just save it for later if I need to lol
    Sunnier and Wallygator[QUOTED] like this.
  19. Jan 22, 2021 at 11:15 AM
    #139
    Hugemoose
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    I believe it. I made my own leaf pack on my old 2001 Tundra out of Deaver offroad springs, and junkyard Chevy 1500 springs. They.....did not get along. It was definitely a little bit of a rough ride at times, but when weighted down they were fantastic.
  20. Jan 22, 2021 at 2:50 PM
    #140
    mundra
    mundra New Member
    2019 platinum 4x4
    Ok another option. I’m looking at a local spring shop that can add leaves to my current stock rear set to match my front lift plus a little rake. This would not only allow me a little more payload but also allow me to not sag when towing. My question is will this still articulate well off road for that weekend warrior once in a while? I think it would be fine overlanding since I’d be adding payload assistance.
  21. Jan 24, 2021 at 6:22 AM
    #141
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Just get the kit you want and put some sand bags in the bed til you get your gear on the truck. #400 of sand is like $50 at home depot.
    HulkSmurf14 likes this.
  22. Jan 24, 2021 at 9:21 AM
    #142
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    ^^$4.95/60lbs of tube sand from HD or Lowes...easy peezy
  23. Jan 27, 2021 at 9:55 AM
    #143
    Legend33
    Legend33 New Member
    Middlesex Massachusetts
    IMG_20210127_095528_01.jpg Here's my Ironman Setup
  24. Jan 27, 2021 at 10:04 AM
    #144
    Hugemoose
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Ugh, that's perfect. Regular load springs front and rear?
  25. Jan 27, 2021 at 10:08 AM
    #145
    Legend33
    Legend33 New Member
    Front and rear are constant load. METHOD 702s and wrapping on 35s Ridge Grappler
    Wallygator and Skew12 like this.
  26. Jan 27, 2021 at 10:14 AM
    #146
    Hugemoose
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Nice, thank you. I inquired about the constant load rear springs and using them while unladen. They urged against it saying they would yield around 5.5" of lift and be very stiff. But I also have little faith that the performance load will actually yield 3.5" of lift as advertised.
    I assume the front still gives you 3.5" of lift with the constant load spring? Probably just a slight stiffer ride since you don't seem to have a bumper or winch.
  27. Jan 27, 2021 at 10:56 AM
    #147
    Legend33
    Legend33 New Member
    The Truck is still at the shop. My mechanic snap me a photo of right before taking it to get an alignment. He told me the front is about 3.5 in of lift. He didn't mention about the rear.
    This what my mechanic said to me via texted "First impression is I am very impressed with ride quality. Its firm but not to ridged. Smooth driving and does not dive like stock. I know you will be very happy with it. "
    Hopefully that answer some of your question.
    Wallygator, Sunnier and Hugemoose like this.
  28. Jan 27, 2021 at 11:23 AM
    #148
    Hugemoose
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Thank you, appreciate the update. Definitely keep us up to date once you get the truck back! It looks fantastic.
  29. Jan 27, 2021 at 3:35 PM
    #149
    PhilActual
    PhilActual New Member
    Phil
    2018 Doublecab SR5 5.7 4x4
    SDHQ ABS guards, Hondo Garage/Ram phone/GPS mounts, 275/65r18 duratracs
    The front is 3.5" of lift and the rears are 2" of lift or thats what they told me. I have the softer springs all around.
    MTRock, Chucho, Wallygator and 2 others like this.
  30. Jan 27, 2021 at 3:46 PM
    #150
    PhilActual
    Phil
    Performance load...
