Ironman 4x4 Suspension
Discussion in 'Suspension' started by linwozzle, Apr 1, 2020.
  1. May 18, 2023 at 8:22 AM
    #1021
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Yeah, I was just hoping to get to maybe an even 3” or so by bottoming out the threads, and the equivalent amount on the other side. I have an extra 100 lbs under the hood which may help also. If it just hits the bellows that’s fine, but would suck to install them and get it aligned to find out it’s making metal on metal contact. If it’s minimal maybe a little grinder action would be necessary, although it would suck to have to do.
    Wallygator likes this.
  2. May 18, 2023 at 8:41 AM
    #1022
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    I wouldn't worry too much just yet. I wish jhines621 or someone else with the new springs would follow up on exactly what is touching.
  3. May 18, 2023 at 9:36 AM
    #1023
    jhines621
    jhines621 New Member
    Jonathan
    2020 Voodoo Blue SR5
    The tie rod is contacting the lower collar at full lock. The pics I posted were not held at full lock but you can tell there is contact on the aluminum… I asked IM about the changes if I were to tighten the lower collar for clearance and they replied that they have never thought of that but “might be worth a try on my end” I had to order spanner wrenches as the kit came with nothing.
  4. May 18, 2023 at 10:44 AM
    #1024
    rruff
    rruff New Member
    Your pics show that the shock collar is touching the rubber bellows on the tie rod, not anything metal. Are you metal on metal anywhere?
    If you raise the lower spring perch so it clears, it will increase the lift. 3.5" is already at the limit of what anyone should do, and way past best practice IMO. Plus you'll need to remove the shock to access with the wrench... it is not an easy thing to check.
  5. May 18, 2023 at 11:08 AM
    #1025
    jhines621
    Jonathan
    I have been very cautious as soon as I noticed this happening and yes, it is making contact with the collar… I really don’t want to increase height. I need function over anything…
  6. May 18, 2023 at 11:18 AM
    #1026
    jhines621
    Jonathan
    Now I am noticing the passenger shock rubbing…. This is ridiculous
    rruff likes this.
  7. May 18, 2023 at 11:23 AM
    #1027
    Silver17
    Eastern PA
    Did you change out the upper control arms for the 3.5” lift or are they the stock ones? I’m wondering what effect that may have on the clearances?
    Wallygator and Piki like this.
  8. May 18, 2023 at 11:30 AM
    #1028
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    That is what mine look like, plenty of room.
  9. May 18, 2023 at 11:38 AM
    #1029
    jhines621
    Jonathan
    they are stock UCAs... At this point, its not going to be worth keeping this kit with the amount of issues and potential damage to my truck...
  10. May 18, 2023 at 12:12 PM
    #1030
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    how come the rubbing pics vs. the non rubbing pics have the tie rod ends curving opposite directions? there are a left and a right tie rod end.
  11. May 18, 2023 at 12:18 PM
    #1031
    jhines621
    Jonathan
    Driver and passenger pics
  12. May 18, 2023 at 12:22 PM
    #1032
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    Show us
    You need aftermarket UCA if you like it or not. You have probably 1.6 caster. It’s a lot of knowledge over here on this forum, just do your research and try to understand how suspension components works together.
    Wallygator and Rodtheviking like this.
  13. May 18, 2023 at 12:36 PM
    #1033
    jhines621
    Jonathan
    I didn’t respond to your identical comment on the page that you admin including when you made additional comments regarding me personally. Your input is irrelevant as UCAs will NOT correct the issue I’m having. They will adjust caster yes, but there are more underlying issues with the kit that I received.
  14. May 18, 2023 at 12:44 PM
    #1034
    Piki
    Piki New Member
    I just copy from Ironman page.
    They designed the kit. Not me.
    I didn’t do any comments anywhere else.
    Show us full picture of your suspension and your alignment print please.
  15. May 18, 2023 at 12:57 PM
    #1035
    jhines621
    Jonathan
    My apologies… there were posts in a FB group where the admin was running their mouth about me because I argue that UCAs are not required. They state that it can cause rubbing at the top of the spring and that is not where my issues lie with this. This was the last printout before they turned me away due to the parts being incorrect. The caster was within specs and truck does not pull in either direction. If I hit full lock, the wheel moves off center.
  16. May 18, 2023 at 12:58 PM
    #1036
    jhines621
    Jonathan
    Pics that I have right now
  17. May 18, 2023 at 1:06 PM
    #1037
    rruff
    rruff New Member
    You are getting rubbing on the lower part of the shock, but that is an easy fix with an angle grinder.
    I'm still not sure it's metal rubbing on the collar, and that is the important point here. The bellows can cause a rub mark. I do agree with you that a UCA will not help, as that doesn't effect your shock mount... on 2nd thought though it will change the way your LCA alignment pivots are adjusted, and that will effect your lower shock mount and may effect the tie rod clearance.
    I bet that's it. If the LCA was pivoted rearward, wouldn't that help?
  18. May 18, 2023 at 2:24 PM
    #1038
    Silver17
    Eastern PA
    Is it possible that aside from designated drivers and passengers sides, there is. Front/back direction they should be facing. I noticed non symmetrical holes in the top plates on both which I was wondering if they could indicate the front or back?
  19. May 18, 2023 at 2:34 PM
    #1039
    Piki
    Piki New Member
  20. May 18, 2023 at 3:22 PM
    #1040
    rruff
    rruff New Member
    That guy is great... wish he owned a Tundra.
    That's what I'm saying regarding the UCA. 3.5" lift with the stock UCA means means he has to adjust the LCA as far forward as possible to get decent caster. That pushes the lower shock mount forward. With an aftermarket UCA he can move that back.
    Wallygator, Silver17 and Piki[QUOTED] like this.
  21. May 18, 2023 at 3:36 PM
    #1041
    Piki
    Piki New Member
    You’re absolutely right. That’s how it works
  22. May 19, 2023 at 6:15 AM
    #1042
    blackoutt
    Indy
    OEM+
    Yep I'm now convinced it's in alignment. There's lots of components in close proximity swinging through arcs of motion and alignment adds up to HUGE variation between trucks. Also the note from Ironman confirms they recommend shifting upper ball joint back to gain more caster vs. adjusting lower ball joint forward. Guys had this same issue on the big 3.0 shocks from other brands when they came out.
    Wallygator and Piki[QUOTED] like this.
  23. May 22, 2023 at 4:11 PM
    #1043
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Are your guys foam cell pros super squeaky?
  24. May 22, 2023 at 4:21 PM
    #1044
    Rodtheviking
    Vancouver, WA
    Sequoia
    Negative, nice and quiet.
  25. May 22, 2023 at 7:41 PM
    #1045
    rruff
    rruff New Member
    Should be silent; find out where it's rubbing.
  26. May 22, 2023 at 7:43 PM
    #1046
    Js18tundra
    I’ve re torqued everything, it sounds like it’s coming from the coilover, you can feel the vibrations in the coils
  27. May 22, 2023 at 8:03 PM
    #1047
    rruff
    rruff New Member
    Same answer as before. Metal on metal. Find it. If you haven't checked to see if the coil is rubbing on the shock body, that would be the first place.
  28. May 23, 2023 at 10:33 AM
    #1048
    Js18tundra
    Ive checked everything, no dice, sent a video along with a video with my tie rods hitting the coilover.. there response for the noise is “definitely upper control arm noise” and referred me to a new moon part number… and they said not to worry about the rack bellow hitting the coilover…. I’m going to see if I can return the whole thing…
  29. May 23, 2023 at 10:50 AM
    #1049
    Rodtheviking
    Vancouver, WA
    Sequoia
    Upper arm can squeak pretty bad if its been torqued down while in the air, especially the OE arm. I would loosen the nut and retorque with it on the ground if you haven't done so. But the tie rod hitting the coil, that's a problem.
    I have the new coil design waiting to be installed and now I'm a little concerned.
  30. May 23, 2023 at 11:49 AM
    #1050
    rruff
    rruff New Member
    You need UCAs anyway... and that would fix your tie rod issue. Sounds perfect... so why do you want to get rid of them?
