Ironman 4x4 Suspension
Discussion in 'Suspension' started by linwozzle, Apr 1, 2020.
  1. Sep 30, 2021 at 8:20 AM
    #541
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Their shop, it's in the process of getting started.
    Explorer likes this.
  2. Sep 30, 2021 at 8:21 AM
    #542
    Explorer
    Explorer New Member
    Battle Ground WA
    2019 Silver Tundra SR5 TRD Offroad
    Thanks. Let me know when they are up. Would be good to know another shop this side of the river.
  3. Oct 1, 2021 at 11:55 AM
    #543
    Rodtheviking
    Vancouver, WA
    Sequoia
    Got the shock back today, they look much better, a tiny bow in one but nothing I am going to worry about. I'll get them installed this weekend, see how they look.
    They are having a sort of open house this Saturday if anyone is local.
  4. Oct 2, 2021 at 5:07 PM
    #544
    Rodtheviking
    Vancouver, WA
    Sequoia
  5. Oct 7, 2021 at 6:43 PM
    #545
    TRDblvd
    TRDblvd New Member
    2019 Toyota Tundra TRD 4X4 Sport
    Very cool, glad you got it worked out.
    Can anyone tell me if the adjustment tool comes w the coilovers, or do I have to buy it separately?
  6. Oct 7, 2021 at 6:51 PM
    #546
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    You have to buy it separately. I paid like $70 or $80 for mine.
  7. Oct 14, 2021 at 7:46 AM
    #547
    Cavalry5.7
    Cavalry5.7 New Member
    21 cavalry crewmax
    Stock
    What height did you end up with in the front ?
    Even with the issues you had, would you still recommend them ???
  8. Oct 14, 2021 at 8:17 AM
    #548
    Rodtheviking
    Vancouver, WA
    Sequoia
    I had them set at 3inch, about 260mm seat height. My only gripe is they are a little bouncy on the small stuff. I don't have a bunch of weight on the truck yet, I will be getting a Smartcap canopy next spring and that (I hope) will help a lot. It's not bad, feels like my old 4runner with 5100's
    So, for a daily that won't have some weight to it, I wouldn't recommend them.
  9. Oct 14, 2021 at 10:57 AM
    #549
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Mine were like that when first installed. But after a few thousand miles they are definitely improving. I imagine at 10k miles and up they will feel pretty plush.
  10. Oct 19, 2021 at 8:52 AM
    #550
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    This is interesting because I also want a 2" lift (maybe a bit less). I'll eventually have a camper on and set up for fulltime living so the front will definitely be loaded!
    Since it's fine on high speed bumps you are surely not bottoming out the shock or springs... that was my initial worry. Sounds like it's just reluctant to compress at all unless the force reaches a certain level. Seal stiction? Maybe high compression damping?
    I was about to get the shock set and front springs, but the warped springs were giving me pause. Looks like the 25% off sale has ended... still 20% if you buy a full kit.
  11. Oct 19, 2021 at 9:10 AM
    #551
    Rodtheviking
    Vancouver, WA
    Sequoia
    They got my springs all figured out, I really should of just had them do the mounting. As far as the jarring ride I would say its the spring weight rating and the preload that causes a lot of it. They are quiet robust as my alignment shop said. If you are going to be loaded up most the time they are great. I just need to get my canopy installed this spring and see how they feel. If they continue to be jarring I will reduce the preload and put a couple of coachbuilder shims (shouldn't have sold them) on top to gain the lift back.
    rruff likes this.
  12. Oct 19, 2021 at 10:32 AM
    #552
    ToyotaG
    ToyotaG New Member
    25% SALE is something they do alot. So it will probably happen again. Black friday is coming up too so i wonder what more sales they will offer
    rruff[QUOTED] likes this.
  13. Oct 22, 2021 at 3:00 PM
    #553
    ab1653
    ab1653 Ew member
    TX
    2014 Tundra
    25% is active along with free treads with the purchase of a suspension kit. Ordered mine a while back and they just got shipped. I asked Ironman if they can add on those free treads and they did! Let’s see how this suspension works out
    rruff and Piki like this.
  14. Oct 23, 2021 at 8:10 AM
    #554
    rruff
    rruff New Member
    Based on dpast88's experience with them set to 2" I doubt reducing preload will help much. Think it's probably seal friction or high compression damping that you are feeling.
    Does anyone know how long the front strut is compared to stock? Most aftermarket lifting struts are a little longer, so you get part of your lift from that and part from the springs.
  15. Nov 8, 2021 at 2:48 PM
    #555
    rruff
    rruff New Member
  16. Nov 15, 2021 at 2:33 AM
    #556
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    Anyone able to adjust the height while on the truck?
  17. Nov 15, 2021 at 4:50 AM
    #557
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    Super hard on these, with all the preload on the coil seat, it's near impossible. You have to pull the strut, take the coil off or compress it to take the pressure off the coil seat, change the height, then reassemble
  18. Nov 15, 2021 at 5:46 AM
    #558
    rruff
    rruff New Member
    I've heard you can. Just jack up the truck to take some pressure off the coil... and you'll need the special wrench to turn the lockrings.
  19. Nov 15, 2021 at 8:37 AM
    #559
    Rodtheviking
    Vancouver, WA
    Sequoia
    I need to do my drivers side, it's got the "lean" but don't have the special wrench to do it. I am hoping it can be done on the truck with it unloaded.
  20. Nov 15, 2021 at 4:03 PM
    #560
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    This also might be applicable to Ironman coilovers, but instead of using a special tool to adjust preload on my Fox coilovers, I used a punch set that fit perfectly in the adjustment holes paired with a cheater bar after jacking up the front. Gives you a lot more leverage even though Ironman adjustment is on the bottom.
    rruff likes this.
  21. Nov 15, 2021 at 4:18 PM
    #561
    rruff
    rruff New Member
    Doesn't Fox say that they must be removed? The Fox threaded bodies are aluminum... are the rings as well? Ironman's are steel.
  22. Nov 15, 2021 at 5:44 PM
    #562
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Hell no. Need to be in a wall mounted spring compressor and my Coilovers damn near kicked the wall mounted spring compressors ass at the mechanic.
    crikeymike likes this.
  23. Nov 15, 2021 at 5:47 PM
    #563
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    My coilovers set at 2” are starting to feel much better after 5000 miles or so. I think they just need to be broken in.
  24. Nov 16, 2021 at 10:00 AM
    #564
    rruff
    rruff New Member
  25. Nov 16, 2021 at 11:58 AM
    #565
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Yes I only get out on dirt roads when I go upstate for fishing a handful of times a year. I have the pros, don’t know much about the coilovers in your link
  26. Dec 4, 2021 at 5:23 PM
    #566
    sea_weathered
    sea_weathered New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    I ordered a set of the 3.5” 0-110lbs, pre-assembled FCP’s and their forged UCA’s. Can anyone comment on their personal experience with this setup? How were your alignment numbers? How’s the ride quality?
    SimpleMan likes this.
  27. Dec 4, 2021 at 5:43 PM
    #567
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    I have the coilovers set at 2”. They were rough and jarring after initial install but I am pretty happy with them after 5k miles and know they will keep getting better. No issues with alignment either.
  28. Dec 5, 2021 at 3:49 AM
    #568
    sea_weathered
    Pacific Ocean
    Thank you. Do you also have their UCA’s?
  29. Dec 5, 2021 at 4:59 AM
    #569
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    I do not because I was only going with 2” of lift.
  30. Dec 5, 2021 at 5:06 AM
    #570
    sea_weathered
    Pacific Ocean
    Gotcha. Thanks for the info, but I'm really looking to hear from someone who has the complete front Iron Man FCP setup. 3.5" and UCA's
