Ironman 4x4 Suspension
Discussion in 'Suspension' started by linwozzle, Apr 1, 2020.
  1. Feb 26, 2021 at 8:49 PM
    #271
    NWPirate
    Zach
    WA
    @Juanjoolio007 Yo man, considering this for my wife's Sequoia. Thought it might be a close comparison to your wife's 4R? I could be way off, I'm not too schooled on Ironman. $1,236
    Wallygator and Juanjoolio007 like this.
  2. Feb 26, 2021 at 9:02 PM
    #272
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    2.75” looks good in front. I say do it :thumbsup:
  3. Feb 27, 2021 at 6:07 AM
    #273
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    I like Ironman myself. Wife keeps telling me to just buy them and be done with it.
    Wallygator likes this.
  4. Feb 27, 2021 at 6:29 AM
    #274
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Does she have the Limited? If I’m not mistaken the limited or one of the trims has the rear air suspension height control or something. If she doesn’t have that then she should be fine.
    The wife’s 4Runner is at 2.5”(I think) with the UCA, rear coils, and adjustable pan hard bar.
    But yes both hers and yours have foam cell pros. One of these weekends we will get it out to the dunes/beach. But she likes how it drives/handles.
    NWPirate[QUOTED] likes this.
  5. Feb 27, 2021 at 7:20 AM
    #275
    NWPirate
    Zach
    WA
    It's the limited, no rear air suspension though. I'll be getting UCAs too, what did you go with?
    It says approximately 2" lift stock load suited, I'm guessing that's referring to the spring rate and I wouldn't want a ton of extra payload on the rig?
    It'll be mostly a kid hauler and see the mountains occasionally, not too stiff on road?
    Good to hear she likes it, I think I'll pull the trigger on them.
    Thanks for letting me bug you with all the questions! :D
    Juanjoolio007[QUOTED] likes this.
  6. Feb 27, 2021 at 9:06 AM
    #276
    Juanjoolio007
    Oregon
    No worries.
    I went into the shop to look at all their stuff. I can’t for the life of me right now remember which height she has. So I went and looked at it again(website) and I can only recall she has performance spring with the lowest weight rating. I’ll have to check paperwork when I get home.
    That’s what she uses hers for primarily also. I’m sure your correct on the load/spring rate.
    The UCA isn’t that bad. We did passenger first on hers. It was more of a pita. If you have someone to help guide that long bolt back in you will be much happier. The ball joint that goes into the spindle was the hardest part. The passenger side took maybe 30 minutes total being extremely careful as it was the first one I ever did. The drivers side was maybe 10 minutes tops.
  7. Feb 27, 2021 at 9:24 AM
    #277
    NWPirate
    Zach
    WA
    I've changed out her coilovers once already with some cheap quickstruts but haven't done UCAs before.
    Looking forward to this!
    Thanks dude :hattip:
  8. Feb 27, 2021 at 10:43 AM
    #278
    Juanjoolio007
    Oregon
    No worries. I was worried about the cv slipping out so bungeed up the spindle. Turns out I never got it stretched far enough to cause a problem. May have been over thinking it. Just leave that UCA bolt loose until you get everything back in. Then tighten it all back down.
  9. Feb 27, 2021 at 12:40 PM
    #279
    NWPirate
    Zach
    WA
    Right on :thumbsup:
  10. Feb 28, 2021 at 12:02 PM
    #280
    Elduder
    Elduder New Member
    Anyone running a front bumper with the performance load?
    Just read through the specs on their site and they have the performance spring rate at 580lb/in, which is roughly what stock is. Not really ideal for a bumper up front.
  11. Mar 1, 2021 at 5:35 AM
    #281
    mundra
    mundra New Member
    2019 platinum 4x4
    I was looking for this spec. Where’d you find it?
  12. Mar 1, 2021 at 7:26 AM
    #282
    Elduder
    Elduder New Member
    dpast88 likes this.
  13. Mar 1, 2021 at 8:02 AM
    #283
    mundra
    mundra New Member
    2019 platinum 4x4
  14. Mar 3, 2021 at 2:06 AM
    #284
    paulbk
    paulbk New Member
    What are peoples thoughts of using coachbuilder shackles in place of the shackles that come with the foam cell pro kit?
    I’m just asking as I own a new set of CB +3 shackles and shims that i had intended on using with a 6112/5160.
  15. Mar 3, 2021 at 7:06 AM
    #285
    cch2a
    cch2a New Member
    I'm using Coachbuilder +2s on mine but didn't get the leaf pack/kit. I'm just running Foam Cell Pro Coilovers in front and Foam Cell Pro shocks in the rear. Works great for me but if I had wanted the leaf pack I probably would have run Ironman shackles.
  16. Mar 3, 2021 at 2:24 PM
    #286
    paulbk
    paulbk New Member
    True. But given the fact that the cell pros reportedly provided 3.5 inches in the rear and CB +3 shackles give 1.75 inches, doesn't that mean that the CB +3 shakles won't provide any additional lift provided by the rear shocks?
    Again, I'm just wondering as these CB +3 shackles are very overbuilt and I would like to utilize them (since I already have them) so long as there aren't any unwanted results. Simply put, if the CB +3 shackles will serve the same purpose as the kit I'd prefer to use them. But there's also the idea to recoup some of the funds from the kit by selling the CB shackles too :monocle:
    I think I am leaning towards just using the kits as a whole.
  17. Mar 3, 2021 at 2:31 PM
    #287
    Elduder
    Elduder New Member
    The shackles would add an additional 1.75" over the IM leafs. The IM shackles appear to be stock length, they just have zerk fittings as an added feature.
  18. Mar 3, 2021 at 2:33 PM
    #288
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    The rear shocks provide no lift. The lift comes from the leaf pack if you buy the full kit. Their greasable shackle also provides no lift. I believe people are seeing closer to 2-2.5" of lift from the leaf pack. You could easily forgo the leaf pack and use your CB bushings to obtain 1.75" from them using your stock leaf pack and their shocks.
  19. Mar 3, 2021 at 4:53 PM
    #289
    paulbk
    paulbk New Member
    Ahhhh ok my mistake. So the shackles would provide additional lift over the leafs. I see. In that case I’ll just install the kit as is and sell my cb shackles and shims.
    thanks for the help!
    Hugemoose[QUOTED] likes this.
  20. Mar 3, 2021 at 5:05 PM
    #290
    Hugemoose
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Or, you could keep your CB shackle for 1.75" of lift if feel like you don't need new heavier duty leaf springs. You can just buy the front struts, and the rear shocks all separately. No leaf springs, no shackle, and save some money if that works better for you.
    paulbk[QUOTED] likes this.
  21. Mar 3, 2021 at 6:02 PM
    #291
    paulbk
    paulbk New Member
    i hopped on that flash sale! the whole kit is supposed to be here soon!
  22. Mar 3, 2021 at 8:45 PM
    #292
    Destro748
    Destro748 New Member
    H
    2018 Cement
    I got the performance spring and leafs. The lift is about a 3.5” all around.
  23. Mar 4, 2021 at 6:35 PM
    #293
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    how is the ride quality with the whole set up?
  24. Mar 8, 2021 at 9:09 AM
    #294
    Destro748
    H
    2018 Cement
    Great! I would say it's better than stock. Firm and controlled. Any bumps in the road is absorbed and rebounds fast. It's definitely more firm but not harsh. Also I feel there is less body roll. Going into turns hard just to test out, it feels controlled and intentional. I had the Off Road package and doing the same procedure would feel mushy. There isn't any squeaks or rattles or bodymount chop I had to do. I've got a slight rub but just haven't had a chance to push in the front plastic yet. All in all, for the price (I paid $2K for the stage 2) I do not feel that there is a more complete package. What I might have done differently would have opted for the SPC UCA but that would have been an additional $500. One can piece together other components from different companies, but as a package, this works very well together.
    Wallygator and Skew12 like this.
  25. Mar 8, 2021 at 9:50 AM
    #295
    paulbk
    paulbk New Member
    Any reason you think the Ironman UCAs aren’t up to par? Any issues? I ask only because I’m installing the kit this weekend.
  26. Mar 8, 2021 at 11:09 AM
    #296
    Destro748
    H
    2018 Cement
    No issues and I've got no comparison other than from what I've read. The only difference I see is the +/- 2 degrees camber. More adjustment capability... Ironman's UCA is pretty beefy and I've got no complaints.
  27. Mar 12, 2021 at 9:43 AM
    #297
    Enzof104
    Enzof104 Have Trailer will Travel
    Paul
    Danbury CT
    2015 SR5 TRD OR DC, because bed size matters...
    Ironman Foam Cell Pro Lift. 2018 retro fit LED headlights, TRD grill, TRD rear sway bar.
    im installing my setup over the next week or two and am now trying to figure out tires. Are those 295s. Looks great. Just don’t want to go too big.
  28. Mar 12, 2021 at 11:28 AM
    #298
    Destro748
    H
    2018 Cement
    Yes 295/70/18 and wheels are +25offset. Slight rub at full turn when reversing but I haven't messed with pushing the inner plastic out yet. Tires are Falken Wildpeaks AT3 and i got them on Amazon $249ea delivered. It was the cheapest I could find and had very good reviews.
  29. Mar 15, 2021 at 6:13 PM
    #299
    Elduder
    Elduder New Member
    FYI, Ironman is having another sale, 25% off. Code is GREEN25
    Fronts are currently $854.25, for anyone cross shopping the 6112s that probably wont be in stock till the 2nd half of this year.
    Wallygator, HulkSmurf14 and Destro748 like this.
  30. Mar 16, 2021 at 11:26 AM
    #300
    Garvin74
    Garvin74 New Member
    2017 Tundra CM SR5
    Got the ironman stage 2 lift on yesterday. Tires and rims today. Super straight forward lift. Rides great. Super happy with it
    TOYOTARIG, Wallygator, Skew12 and 6 others like this.
