Ironman 4x4 Suspension Kit
Discussion in 'Suspension' started by rodl12, Feb 14, 2021.
  1. Feb 14, 2021 at 5:10 AM
    rodl12
    rodl12 [OP] New Member
    Rod
    South Jersey
    2017 Tundra SR5 Double Cab
    After much research and limited choices due to COVID availability, I've decided to go with the Ironman 4x4 Foam Cell Pro 3.5" Suspension Kit. My install date is this coming Wednesday. My original choice was to go with the Bilstein 6112 coil overs and 5100's in the rear but due to availability now being moved up to mid May I've changed mind and decided to go with the Ironman suspension kit. It's more money than I initially was going to spend but again my choices are limited and not only with Bilstein. Any reviews I've been able to find have all been positive. Is there anyone else on this form that has this suspension on their truck?
    Teddybear18 and Wallygator like this.
  2. Feb 14, 2021 at 5:16 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    https://www.tundras.com/threads/ironman-4x4-suspension.64691/
    Wallygator and HulkSmurf14 like this.
  3. Feb 14, 2021 at 7:01 AM
    rodl12
    Rod
    South Jersey
  4. Feb 14, 2021 at 7:04 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Several guys in there have the 3.5" as well. Edit: As a matter of fact, Ironman doesn't even advertise 2.5" on their website currently.
  5. Feb 14, 2021 at 7:13 AM
    rodl12
    Rod
    South Jersey
    Those are the one's I'm looking for feedback from. Having been a previous LC owner and running an OME suspension I appreciate the thread but the LC is not the same as the Tundra. My 94 LC was amazing and the OME suspension had a great ride but that suspension is coils on all 4 wheels which is no way similar to the Tundra.
  6. Feb 14, 2021 at 7:18 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    The first page and a half are other vehicles, but starting on post 47 is it tundras https://www.tundras.com/threads/ironman-4x4-suspension.64691/page-2#post-1998212
  7. Feb 14, 2021 at 8:50 AM
    rodl12
    Rod
    South Jersey
  8. Feb 14, 2021 at 2:14 PM
    paulbk
    paulbk New Member
    Hi, is this confirmed that 6112 are being pushed back? Not surprising this is the case, this is just the first time I've heard it being pushed this far out.
    You mind providing your source of this info :) thanks!
  9. Feb 14, 2021 at 3:18 PM
    rodl12
    Rod
    South Jersey
    That came directly from Bilstein. I talked to them early Jan. and they said mid February, talk to them a couple weeks ago and they said mid May. I had my heart set on doing this after the 1st of the year with the Bilstein's so I waited till February. Now I'm going with Ironman. Tuff decision for the extra money but I think I will be glad when it's done and it's much better than the Bilstein suspension from all the reviews I've read.
  10. Feb 14, 2021 at 3:24 PM
    rodl12
    Rod
    South Jersey
    There is an added small bonus to the Ironman suspension and that's that I don't need to add a rear sway bar which I was planning to do. That'll save me $200+. Body roll elimination is one of the improvements with this suspension kit.
  11. Feb 14, 2021 at 4:22 PM
    paulbk
    paulbk New Member
    Hmmmm, I already own a rear trd sway bar - not installed yet as I wanted to do it with my lift all at once....Is the sway bar not compatible OR will need longer end links?
  12. Feb 15, 2021 at 3:21 AM
    rodl12
    Rod
    South Jersey
    Bubba at Ironman told me it isn't needed with this suspension kit. He has this kit on his Tundra also. Get your money back.
  13. Feb 16, 2021 at 11:57 AM
    Destro748
    Destro748 New Member
    H
    2018 Cement
    I've had this installed for about 2 weeks now. Got the 3.5" Stage 2. Initially, I wanted the 2.5" but after talking to John and Bubba, they said there was never really a 2.5". The 2.5" when measured was 3.5" so they changed it to reflect the lift height. I do not have anything to compare this to but so far it rides well. My truck is a 2018 CM with the Off Road package. Comparing stock to this, well the Ironman feels good. Firm but not harsh. It absorbs bumps really well and moves on. Currently have on 18x9 with a +25 offset and Wildpeaks 295x70. The preset coilovers is really high though. It looks like a true 3.5" up front. The rear leafs says it's a 2". Adjustment appears to not be as flexible because you need to remove the entire coilovers to compress and then adjust the coilovers. Overall, I think you'll like the ride. Not as smooth as a factory but still very close.
  14. Feb 16, 2021 at 12:33 PM
    rodl12
    Rod
    South Jersey
    Thanks for the post. My truck goes into the shop tomorrow. When I get it back I'll post a pic and an opinion. There doesn't look like there is much of a rake or is that the ground you're on?
  15. Feb 16, 2021 at 1:05 PM
    Destro748
    H
    2018 Cement
    I don't think there's much rake. Ironman said stock settings maintain the factory rake but I think the fronts need to drop about 1/2". Ironman has a informational data sheet that gives the measurement of where the collar is and how it correlates with the height. All the reviews I've read, the factory setting looks to be 3.5".
    rodl12[OP] likes this.
  16. Feb 16, 2021 at 1:15 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 GMC Sierra At4x AEV
    How does it drive with those UCA's? They look great under there.
  17. Feb 16, 2021 at 1:23 PM
    rodl12
    Rod
    South Jersey
    Looks nice. I'm hoping for more of a level look on mine.
  18. Feb 16, 2021 at 1:26 PM
    mac10tuna
    mac10tuna New Member
    Marc
    19 cement limited CM
    We’ve installed a bunch recently and have been super impressed.
    you won’t be disappointed with your choice.
    Get the performance load springs if you aren’t lugging around a ton of weight.
    The ride quality will soften up over a couple months time.
    tonynw318, Wallygator and Skew12 like this.
  19. Feb 16, 2021 at 1:32 PM
    rodl12
    Rod
    South Jersey
    That's the kit I did get.
  20. Feb 16, 2021 at 3:20 PM
    paulbk
    paulbk New Member
    Any additional photos to share?
    Truck looks great!!
  21. Feb 16, 2021 at 5:11 PM
    Destro748
    H
    2018 Cement
  22. Feb 16, 2021 at 5:15 PM
    Destro748
    H
    2018 Cement
  23. Feb 16, 2021 at 5:17 PM
    Destro748
    H
    2018 Cement
  24. Feb 16, 2021 at 5:17 PM
    Destro748
    H
    2018 Cement
  25. Feb 16, 2021 at 5:18 PM
    Destro748
    H
    2018 Cement
  26. Feb 16, 2021 at 6:35 PM
    paulbk
    paulbk New Member
    man that looks so good. Did U get the bmc done?
    Rica25 likes this.
  27. Feb 16, 2021 at 6:53 PM
    Destro748
    H
    2018 Cement
    Thanks man. The quality is exceptional. I think it's the best bang for the buck. I got the entire package delivered for $2K. This includes the UCA. No BMC. I've got a slight rub once and a while and full lock but I can probably fix that w a heat gun once the weather gets better.
    paulbk[QUOTED] and Wallygator like this.
  28. Feb 16, 2021 at 7:33 PM
    paulbk
    paulbk New Member
    Wow!! How’s you get that great of a deal? I’m seeing at $2500 delivered.
  29. Feb 16, 2021 at 7:47 PM
    Destro748
    H
    2018 Cement
    They are usually running specials. The complete kit was $2200 and I used GOODBUDDY10 to get an additional 10% off. The code should still work. If you're going to get it preassembled, you can save some money there too. I should have done the preassembled and had the coils powdercoated and then adjust the lift to about 2.75".
  30. Feb 16, 2021 at 7:54 PM
    Destro748
    H
    2018 Cement
