intermittent starting issue
Discussion in '2nd Gen Tundras (2007-2013)' started by chewluwatoo, Apr 22, 2016.
  1. Nov 4, 2019 at 4:33 AM
    Tazzer
    Tazzer New Member
    Clay
    2008 Toyota tundra
    hate to beat a dead horse but did anyone ever get this resolved ?
    got up this morning and mine did the same thing. truck started fir like 2-3 seconds then died
    turn the key again and truck will turn over but not start release key and truck is still turning over until you turn the key to the off position.
    I had it happen like this about 2 years ago and just unconnected the battery and all has been good till now.
  2. Nov 22, 2019 at 5:04 PM
    Cajunman007
    Cajunman007 New Member
    Shane
    Lafayette, LA
    02 Tundra Access Cab 4x4 4.7
    Mine is doing it also. I am going to try and check the vacuum. It has been doing it over the last few days more frequently.
  3. Nov 22, 2019 at 5:07 PM
    Cajunman007
    Shane
    Lafayette, LA
    Mine is doing as well, with more and more frequency the last 2 days. Going to check the vacuum this weekend.
  4. Dec 6, 2019 at 1:15 AM
    b99g51
    b99g51 New Member
    Alex
    2016 Tundra
    here you can find the main reason for that: https://tundraheadquarters.com/tundra-sequoia-air-injection-induction-pump/
  5. Apr 12, 2021 at 10:25 AM
    MikeB Fla
    MikeB Fla New Member
    Same problem....., 2008 Tundra w 165,000 miles, this has happened 5 times in 2 years, always after it sat for 15-30 minutes, if I wait for an hour it starts fine. Did anyone figure this out yet.
  6. Apr 12, 2021 at 10:38 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    May want to start a new thread... eitherway I would suggest getting your battery tested. Something else you can try is wiggling the ground terminal... there is probably a reason Toyota slams the terminals to the bottom as they tend to loosen their connection with vibration.... stalling is sometimes related to the battery, believe it or not
  7. Apr 12, 2021 at 11:06 AM
    blackdemon_tt
    Flex fuel?? You swapped in a flex fuel?? You may be in a world of shit if you did, since you may require an ECU flash due to a TSB on the ffv.. highly doubt Toyota will want to do it for free, you may need to pay for the flash, but again, they may not want to if it's a Frankenstein due to liability.
  8. Apr 12, 2021 at 12:17 PM
    Cajunman007
    Shane
    Lafayette, LA
    Mine was 2 issues. First, one of the starter bolts backed out and the other was loose. It was on a bind because trying to start it at an angle. I changed it out and it was still having some trouble starting and idling high. Changed out the coolant temperature sender, the 2 wire one, and cleaned the MAF. Has been working great ever since. You have a different engine though, but still the same working theory I believe.
  9. Apr 12, 2021 at 2:28 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    Because of this behavior, I have a blank non-programmed key cut for all my cars as my hidden “locked myself out” key.
    All the times I needed it was when I left my keys in the ignition (newer cars won’t let you do this) or on the seat or floor.
    Worst nightmare is to drop my key ring down a sewer drain, like the guy in the TV commercial sneezing and dropping his phone down the sidewalk grate. My sphincter tightens a little every time I see that commercial.
    Greg
  10. Aug 28, 2021 at 3:57 AM
    Spreadphred
    Spreadphred New Member
    2011 Tundra 5.7 4WD
    This is an old, old post, but having just experienced this in 2021, I thought I’d share a success story.
    Skipping the play by play, I removed the mass air flow sensor located downstream from the top of the air filter housing top. Using CRC ‘maf’ sensor spray (yes, there is a product suited just for this part), I liberally sprayed it down. Once reassembled, the result was night and day.
    Like a halogen bulb, avoid greasy hands on the sensor parts; just hold the base.
    Just for shits & giggles, I did clean up the throttle body, essentially the butterfly valve and valve seat. I used the same CRC spray, but evaporating so quickly, a different cleaner would have been better. The only grime was on the periphery of the round valve flap (the butterfly as I call it) and the seating area of the housing. Did this help? Probably not, but it felt good to take things apart.
  11. Apr 6, 2022 at 12:29 PM
    Bber08527116
    Bber08527116 New Member
    08 tundra
    I have this same issues starts when it wants changed fuel pump checked relays everytime I fill the truck up and go home next morning will not start .
