Interior trim (level) swap.
Discussion in '2.5 Gen Tundras (2014-2021)' started by FortyNorth, Jan 14, 2023.
  1. Jan 14, 2023 at 7:56 PM
    FortyNorth
    FortyNorth [OP] New Member
    Northern ON
    2014 Tundra Super White SR5
    Just wondering on the feasibility of buying 1794 interior trim parts to install on a lower trim. Just surfaces (not seats) as would get Katzkin of a complimentary colour.
  2. Jan 15, 2023 at 7:39 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    It will be most affordable using a pick and pull , CL, or marketplace for those pieces but it will 100% snap into place...
    FortyNorth[OP] likes this.
  3. Jan 15, 2023 at 8:21 AM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    Not too hard. Just source the part numbers and hit up sparksparts.com or something. I did this to my Limited to a TRD PRO. The doors are another story though, as the whole panel must be replaced but the wood trim and passenger side piece below the airbag are just snap in to replace. Center console is easy too
  4. Jan 15, 2023 at 2:51 PM
    Trentimus
    Trentimus New Member
    Trent
    2019 Tundra Off Road
    Nfab bars, undercover armor cover, hottails
    This is way more expensive then you might think.
    best bet is to find a parts truck that has been wrecked
  5. Jan 16, 2023 at 10:10 AM
    GR8WHITE1
    GR8WHITE1 New Member
    Justin
    2017 Tundra SR5
    Parts on order
    I concur.
  6. Jan 16, 2023 at 10:12 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Or sell and upgrade to a 1794. By the time you find parts and the work into swapping, you might be better off just buying something different. Gotta consider the value of your time too.
    Trentimus likes this.
  7. Jan 16, 2023 at 11:06 AM
    Trentimus
    Trent
    This and your VIN will never consider the value of these changes. Essentially you do all this work, and it may make it appealing, but it won’t increase the value of your truck.
    a 1794 will be complete with what you’re looking to do and be more valuable because of the value baked into the VIN
