Interior Lights Blowing Fuse
Discussion in 'Lighting' started by Tiger Tundra, Sep 11, 2015.
  1. Apr 17, 2017 at 2:25 AM
    PermaFrostTRD
    Northern NY
    Thanks man. Yah. I may just grab a couple from Amazon. How difficult/ tricky is removing that overhead console?
    @csuviper
  2. Apr 17, 2017 at 9:09 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Not very. 4 or 6 screws and it comes down easy.
    PermaFrostTRD[QUOTED] likes this.
  3. Apr 17, 2017 at 5:47 PM
    PermaFrostTRD
    Northern NY
    Sorry to keep harassing you on the issue. The light works when I turn off the ignition. But when I open the door it's the only light that cuts off. The driver map, and 2 domes stay illuminated but the passenger cuts off. Does that sound like a switch issue? Also. I don't see any torx screws. Do I have to pop the plastic cover off first?
    @csuviper
  4. Apr 17, 2017 at 5:58 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    PermafrostTrd, you have 3rd gen Tundra? The 6 torx screws on the 2nd gens are front, middle, and back. Do you have short overhd console or the long version
  5. Apr 17, 2017 at 6:33 PM
    PermaFrostTRD
    Northern NY
    Yeah 3rd gen. I think it's the short version of the consoleimage.jpgthe passenger map light is intermittent. It just cut on when I opened the door then it flickered off just 2-3 seconds after it cut on.
    So weird. It's the second "bulb" (JDM Astar) and I've swapped the polarity thing for each.
    @rons23
  6. Apr 17, 2017 at 6:53 PM
    rons23
    Ron
    Kill Devil Hills
    Yeah that's the short console. The screws should be in the front and rear compartmenta. I have the long version and there were 6 total. I would think just 4 for that console.
    NewImprovedRon and PermaFrostTRD like this.
  7. Apr 17, 2017 at 6:55 PM
    PermaFrostTRD
    Northern NY
    Awesome. Thanks man. I'll check it out tomorrow.
    rons23[QUOTED] likes this.
  8. Apr 17, 2017 at 6:56 PM
    rons23
    Ron
    Kill Devil Hills
    Anytime
  9. Apr 17, 2017 at 9:27 PM
    csuviper
    Broomfield, CO
    No sounds like relay or something. With mine the light didn't work at all when the switch was blown.
  10. Apr 18, 2017 at 2:44 AM
    PermaFrostTRD
    Northern NY
    A relay? Great. Where might that be? Hahaha
  11. Apr 18, 2017 at 7:12 AM
    csuviper
    Broomfield, CO
    Not sure if there is one. Just sounds like that would be the case if only one light is shutting off but the others stay on. There is something in play that has a timmer for keeping the lights on for a certain amount of time before shutting off automatically when you shut the door right.
  12. Apr 18, 2017 at 4:56 PM
    PermaFrostTRD
    Northern NY
    Well gentlemen, the issue has resolved itself. I did absolutely nothing and it's working properly now. I'm guessing the ole Sky Silver overheard me discussing the possibility of electrical surgery and panicked and decided to function properly again.
    Thank you for your advice and information. @csuviper @rons23
    csuviper, NewImprovedRon and rons23 like this.
  13. Apr 18, 2017 at 5:15 PM
    rons23
    Ron
    Kill Devil Hills
    Did you locate the screws just for future reference?
  14. Apr 18, 2017 at 5:23 PM
    PermaFrostTRD
    Northern NY
    I did not. Didn't want to jinx and/or break anything. I'll take a closer look if it starts acting up again.
  15. Apr 18, 2017 at 5:24 PM
    rons23
    Ron
    Kill Devil Hills
    Gotcha. Well glad everything is back to normal.
  16. Apr 18, 2017 at 5:25 PM
    PermaFrostTRD
    Northern NY
    Yeah me too Ron. Thanks again.
  17. Jan 13, 2018 at 10:35 PM
    Happybg81
    Happybg81 New Member
    William
    13’ Balcked Out Rock Warrior DC
    Switched backup camera, interior led’s, backflip g2, smoke led taillights, rhino liner, leveling kit, black powder coated rw wheel rings, weathertech mats, under seat storage, evo one remote start, flowmaster 50 series, S&B CAI, Focal 6x9 front doors, Rockford Fosgate 6.5” rear doors, JL Audio dash tweeters, Kicker hideaway under rear seat
    I know this thread has been dead for awhile but hopefully someone can answer a question. I think my console is beyond repair. I’ve found several used ones for an ok price, but they all say w/o Bluetooth. You can clearly see the mic in the photos, an I missing something?
  18. Jul 18, 2019 at 10:51 AM
    Harlan_2nd Gen
    Harlan_2nd Gen New Member
    2007 XSP Double Cab
    Bed cover LED Low Beam, High Beam
    Has anyone done this mod on a Gen2?
  19. Oct 31, 2019 at 6:07 AM
    #49
    Harlan_2nd Gen
    2007 XSP Double Cab
  20. Jan 16, 2020 at 7:07 PM
    #50
    Hyhoslvr1
    Hyhoslvr1 New Member
    Hello,
    I have been gone for a minute. The Tundra is running well after some new shoes going to see what others have been doing here. But I too have the issue with the lights. Mine is in the rear. Every time I place a bulb in they blow the same 7.5 fuses. I too went to the auto part store and no fuses...wtw?? Going to take some advice and pull the fuse then see with a good flashlight to see if anything is in there. Place led bulbs in and replace fuse and pray for the best. Will let everyone know how this goes:fingerscrossed:
  21. Jan 25, 2020 at 7:47 PM
    #51
    Hyhoslvr1
    Did try once but it turned cold around here and i was a wimp but prayerfully its warmer after church tomorrow and i can have some success
  22. Jan 31, 2020 at 4:54 AM
    #52
    skan
    skan New Member
    2007 Toyota Tundra CrewMax
    275 60r20 toyo open country at3 on vision seven 20*9 +12 offset
    I should have seen this post before blowing the fuse. I will remove the fuse before replacing the led lights.
    Tom Sleight likes this.
  23. Jan 31, 2020 at 5:20 AM
    #53
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
    MY Tacoma did the same thing certain brand bulbs are your issue
  24. May 16, 2020 at 2:50 PM
    #54
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Hey Ron,
    What were the symptoms you were having with your lights? I have two that will not turn off unless the battery is disconnected. I replaced my year old auxtitos with the fyre flys because they would hyperflash. Now I wish I just left them alone haha
  25. May 16, 2020 at 4:02 PM
    #55
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Thanks, Ron. I’ll drop the console and report back. Appreciate the response
    NewImprovedRon likes this.
  26. May 17, 2020 at 6:49 AM
    #56
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I am having a similar issue on a 2008 Sequioa.
    Overhead interior lights no longer work, and the clock on the dash reads 1:00 each time the truck is started. Both issues occurred about the same time.
    I am at a loss, and have no clue where to start diagnosing an electrical problem like this other than the fuses.
    Which 7.5 amp fuse was blowing?
    I checked the fuse box under the hood yesterday, but I didn't see anything that stood out to me as "interior lights." I was pressed for time when I was searching though.
  27. May 17, 2020 at 7:18 AM
    #57
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I looked around the dash, and kick panel areas for an interior fuse box, and did not see one. I'm guessing it could be in the back by the hatch since it is a sequioa. I am not very fluent with it, and do not tinker as much as I do with my 1st gen
    Like I said in my original 10 minute inspection I was pressed for time. Once I have a chance I will dive into it in depth.
  28. May 17, 2020 at 2:55 PM
    #58
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @NewImprovedRon
    Finally had a chance to look at the engine bay fuse box in depth.
    Found a blown fuse in this location. (See picture #34, pulled 33 out to test the circuit. Looks like all things are go.)
    Installed LEDS while the fuse was blown. Super nice.
    Verified that the light switches still worked as proper. Super nice.
    Now I need an assortment of these "mini-me" fuses.
    Source for screenshots: https://www-autogenius-info.cdn.ampproject.org/v/s/www.autogenius.info/toyota-sequoia-2008-2017-fuse-box-diagram/amp/?amp_js_v=a3&amp_gsa=1&usqp=mq331AQFKAGwASA=#aoh=15897298097488&referrer=
    Used my web browsers "find in page" option to search for dome, or courtesy lights. Greatly sped up my search.
    I did not check to see if this fixed the clock resetting issue. I'm assuming both systems are tied into the same 7.5 amp fuse?
  29. May 18, 2020 at 5:37 AM
    #59
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I am not familiar with the Sequoia, or 2nd gen in all honesty.
    I am just starting to get my feet wet in that world as little things go wrong, and are mended.
    Thanks a bunch Ron!
    Cheers.
  30. May 18, 2020 at 7:41 AM
    #60
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Update:
    Fuse #34 according to the diagram provided seems to have also fixed the clock resetting back to 1 o'clock at each start up also.
    Now if only I could diagnose the radio turning itself on, and off. Sometimes the radio will have power and audio, but no information shown on the readout. Strange.
    There has been ZERO radio upgrades done that I'm aware of.
    I tried to use the search bar, but no luck.
    There is a service record for that by the dealership in 2012. The dealership updated records saying "No work was done."
